TOP853 Eprom programming 27128 roms
thedark
Post by thedark » Sat May 30, 2015 7:48 pm
i have troubles of programming eproms.
somehow it fails every time whet it is on 0005F (FF)
then it stops ...
this whas a working DFS rom reserved for Super MMC to burn in for the compact.
but after one week trying 20 eproms i have a black out.
can anyone help or know how to, i could not find any info on this matter.
Thanks for heling in advance..
tonny
-=[[ Music 5000 Stil Rulez On The Acorn Scene. ]]=-
poink
Re: TOP853 Eprom programming 27128 roms
Post by poink » Sat May 30, 2015 8:10 pm
http://primrosebank.net/computers/maint ... top853.htm seems to suggest reducing the write delay. Also, it sounds you might find 27C128 chips work better, as they use a lower programming voltage.
Post by 1024MAK » Sat May 30, 2015 10:18 pm
poink wrote:http://primrosebank.net/computers/maint ... top853.htm seems to suggest reducing the write delay. Also, it sounds you might find 27C128 chips work better, as they use a lower programming voltage.
I think you mean increasing the write delay...
All USB powered EPROM programmers suffer from being unable to supply enough power to program 21V and 25V EPROMs properly. In addition, not many properly support the 5.5V or 6V supply voltage recommended for some of the later EPROMs that can be fast programmed.
So as said above, use the 12.5V EPROMs. And keep backup copies of the data used to program your EPROMs, as they may not hold data for as long as you would expect when they have been programmed with a USB programmer.
thedark
Post by thedark » Sat May 30, 2015 11:08 pm
Wil an external psu help instead of an usbport
i have 1 21v 6x cmos and the rest is 12.5v
but i think that i better of with the otommer for bbc b
Post by 1024MAK » Sun May 31, 2015 3:19 am
If your EPROM programmer has an external power input, yes, use this.
I have a Willem programmer and this is able to correctly program 21V EPROMS when I use a 12V external PSU.
You may still have to change the timing as described in the link in the post above.
Oh, and always do a blank check first. When erased, every memory location in an EPROM should be &FF. The programmer can only change bits from ones to zeros. Erasing the EPROM is the only way to change each bit from zero back to a one.
If you have a EPROM programmer for the Beeb, yes, try programming your 21V EPROMs on it.
Note: I do not recommend Willem programmers like the one I have (or similar versions) for most people because there are a lot of jumper/link settings and it is easy to make a mistake.
thedark
Post by thedark » Sun May 31, 2015 7:51 am
On the main board is a solder on point for it.
if i use this do i have to disconnect the power on usb.
or do i put the 5v straight on the board.
i have parts to do this.
but i am not sure if its possible.
Edit: Added a picture of the inside.
right is a place for external power.
Post by 1024MAK » Sun May 31, 2015 10:46 am
Without knowing how they have "wired" up the circuit, it is just guesswork. So I don't know.
Just because there is provision on the PCB for a socket does not mean just adding a socket will help. The next question is: "What voltage and polarity would this socket accept?"
As I cannot find a schematic of the TOP853 programmer on the web, the only way to find out, is to reverse engineer it (map out the tracks, connection and components and draw a schematic up from scratch).
But before even thinking about that, first have you tried it on all of your computers USB ports? Some may be able to deliver more power than others.
Do you have an externally powered USB hub? If yes, use this with just the TOP853 (and the computer) connected and try again.
Also try programming the same EPROM with the same data multiple times to see if the programmer can get any further each time you try to program it.
Here are some links to people having the same or similar problems:
http://forums.arcade-museum.com/showthread.php?t=192978
http://www.vintage-computer.com/vcforum/
http://www.lemon64.com/forum/
http://www.eevblog.com/forum/
A site search unsurprisingly brings up lots of hits for TOP853 on www.eevblog.com/forum...
Good luck :mrgreen:
thedark
Post by thedark » Tue Jun 02, 2015 7:51 pm
got it to work...
question.
i have the compact who can hold two roms in an 27c256 eprom
but how do i put two roms in there.
whet i burn one rom in there its working good. but how do i burn the seccond in there?
any toughts out there?
bprosman
Post by bprosman » Tue Jun 02, 2015 9:08 pm
What did you do to get it to work ?
Usually when loading a file in the eprom programmer software you can give an offset. That should be $4000 for half a 27256
thedark
Post by thedark » Tue Jun 02, 2015 9:31 pm
installed a laptop with win XP
using 12.5v Eproms and reduced the write speed 2ms or 1ms
and set in the bios the USB2.0 to USB1.1 so it slow down.
