Please could someone build a new beebdroid
Re: Please could someone build a new beebdroid
Post by tricky »
I think I found it from a "sped up version" that used wire frame for the keyboard.
Stainy
Post by Stainy »
Are you able to share it??
Possibly? :)
Post by tricky »
I have this APK for the wire-frame version in my dropbox no login should be required.
It does have the bug that was the reason for my original request and this thread, annoyingly, it mostly affects my games!
I won't pass on the b-em based one without the author's consent.
Stainy
Post by Stainy »
But when I try to install it it says "appears to be corrupt' :(
Stainy
Post by Stainy »
I finally got it installed on my GPD XD+. ( silly Admin thing in security was blocking it )
But I get no sound.. and there`s no settings to speak of...
derek
Post by derek »
tricky wrote:
Sun Mar 10, 2019 10:13 am
I downloaded the new beebdroid and installed on a Samsung SM-T530 Galaxy Tab 10, it work much better than the plsystore version.
I like that local ssd files can loaded anb self written programmes can be saved easily.
Regards,
Derek
Stainy
Post by Stainy »
I get no sound on my LG V20 and GPD XD+ :(
Warwick
Post by Warwick »
I've been working on a fork of Little Fluffy Toys' Beebdroid on GitHub - user sleekweasel - over the past couple of months.
It complies under Android Studio and fixes the position independent code issue that probably stopped most people working on it.
It also makes it work properly with Bluetooth keyboards for programming (taking over the 'no keyboard' mode) which does weird things to the shift key, though it would be easy enough to create a new no keyboard mouse if that's a problem.
I've also restored the machine image save/restore code and have plumbed adval 1 and 2 into the mouse x and y coordinates, though it needs some trickery to avoid mixing last x with the current y (I'm planning to set the lower bit as a simple timestamp).
There's an APK under the releases tab.
Post by tricky »
Not sure about position independent code, my main problem was the bug in the ARM ASM for I think a sbc ZP,X instruction (or something like that).
Warwick
Post by Warwick »
tricky wrote:
Tue Jan 07, 2020 7:48 pm
There's a patch for that; I haven't encountered anything triggering it, but it was on my radar to check. Kenton has reached out to me, so hopefully we'll update on the play store (and probably Amazon, since it's deeply amusing to have a Beeb appear from the Firestick, and use a Bluetooth keyboard with it).
If you look in my GitHub - sleekweasel - you'll find a couple of APKs in releases. Give me a test case for the SBC instruction, and I'll get a fix up.
kenton
Post by kenton »
Heads-up that I've got a new laptop with Android Studio running for the first time in five years, and I've got the rocks-and-gems Mole Miner compiled, rudimentarily changed and republished to Play Store so you can at least play it on modern hardware compliant with modern Play Store policies. I think I might have lost Michael S. Repton's second levelpack source code, which would be a tragedy - I'll have a really good hunt for that. Anyway... I'm gonna spend a bit of time working on modernising it enough so it's playable for the next few years. Once that's done, I'll be onto Beebdroid.
Warwick
Post by Warwick »
In case anyone other than Kenton - hi Kenton - is following this, I've made progress with the 64 bit ports, which will allow us to post the newer version to Play (64 bit support is a requirement for anything with native code). 64 bit architectures reach the BASIC prompt with identical CPU traces to the 32 bit implementations, so the official opcodes are probably correctly implemented.
I'm starting to wire up the RS232 system, for easy ASCII interface to some Android text fields - *fx5,2 and *fx2,1 - and then I plan to run the 65C02 compliance tests, to check the 64 bit ports (and I may as well run them Vs the 32 bit ports too)
The ADVAL command now tracks touches on the screen in addition to the Bluetooth mouse, and I've moved the Alt keyboard magic around a bit. I have three Bluetooth keyboards, and found one with funny key mapping, so I may provide duplicates later. My favourite innovation is Right Alt acting as the Copy key.
I've posted a ReadMe at my SleekWeasel GitHub.
kenton
Post by kenton »
Do a pull request on the original github?
Post by lurkio »
kenton wrote:
Sat Dec 05, 2020 2:06 am
Do you and/or Reuben have any plans to resurrect the iOS Beeb emulator? It was brilliant!
:?: [-o<
kenton
Post by kenton »
lurkio wrote:
Sat Dec 05, 2020 2:34 am
:?: [-o<
Beeb stuff is back in the plans. We're on it ;)
