Building Rolands new Atom design...
Re: Building Rolands new Atom design...
Post by hoglet » Fri Apr 03, 2015 6:44 pm
Some progress on the Keyboard front, using a "donor" Beeb type-1 Keyboard.
This was following the same approach that Charlie's mate used:
https://plus.google.com/photos/+Cliffor ... 9384453345
This took about 2 hours in the garage with my metal files to "adjust" the metal plate. At least on the type-1 keyboard it's just aluminium.
But the end result is quite a close match. And the red shift and return keys are kind-of growing on me.
It's a bit like a Prophet:
Did the Prophet have a different OS? Or were the two keyboard modes done in hardware?
Next work item is the PCB to connect all the switches together into a matrix.
I've just about got it laid out, single sided:
I need to add in the connector, which might be a bit tricky but there is room for wires between the keys if necessary.
I also did some experiments with toner transfer PCB making today, and they were an abject failure. So back to the UV process.... I'll need to order a piece of board that's big enough, which means waiting until next weekend :( But that gives me more time to check for mistakes. I would be a bit miffed if I put it all together, and found some of the keys were swapped.
What's everyone else who doesn't have a sacrificial Atom doing for a keyboard?
Post by roland » Fri Apr 03, 2015 11:22 pm
They use this: https://youtu.be/062H5nApij0 8)
But your keyboard really looks great =D> Who knows, you might run into a set of shift keys one day...
Post by oss003 » Sat Apr 04, 2015 10:04 am
Wow, this 'hoglet'-keyboard looks awesome!!!
Especially with the red keys.
Post by 1024MAK » Sat Apr 04, 2015 2:18 pm
oss003 wrote:Wow, this 'hoglet'-keyboard looks awesome!!!
Some would say that is the key feature :lol:
I've ran out of suitable new words to describe Dave's work. I'm now convinced he has a time machine...
So Dave, well done, excellent work yet again 8)
Makes me jealous, as I can't do much hobby stuff this weekend as I am working 12 hour nights Friday to Sunday :(
Post by hoglet » Sat Apr 04, 2015 7:35 pm
Here's the final artwork for the keyboard PCB:
I'm going to order some big sheets of photo sensitive PCB from Mega this week, and try to get this finished next weekend.
Post by oss003 » Wed Apr 08, 2015 7:57 pm
Hi guys,
at last ..... some action!! Before I want to start with the keyboard, I first wanted to get the motherboard working. I finally completed my new 2015 'Roland style' Atom motherboard and powered it up. The leds on the Godil flashed and ....... the screen stayed black :(
Then I powered the Atom up again and I got a CLEAR4 screen with some dots in the left corner. It looks like ACORN ATOM is printed but I can't see it because the screenmode stays in CLEAR4. It's a strange behaviour, sometimes the characters are placed with a frequency of ca.1 char/sec and sometimes they appear at the normal speed but always in CLEAR4. You can see the Atom at powerup at: https://youtu.be/vbEbWKrSfEs
Until now I checked the clock signals, 4mHz and 1mHz and they are looking fine. I think I have to connect a logic analyser to see if the R/W, NWDS and RWDS signals are ok. For now I don't have a clue why the Atom boots in CLEAR4....
The white dots are from the youtube screen and the green dots are from Atomulator with ACORN ATOM in CLEAR4.
Here are some pictures of my Atom, Atom component side:
Atom solder side:
Modification to change pin 23/24 PIC controller:
Post by hoglet » Wed Apr 08, 2015 8:13 pm
Kees,
I'd suspect a fault around the 8255, where the write to set the screen mode is malfunctioning.
Some things to check:
1. Does the 8255 function correctly in a normal Atom?
2. What's the voltage on the 8255 PA4...PA7 measured on the 8255 pins?
3. Do you seethe 8255 CS signal being asserted after reset?
Post by oss003 » Wed Apr 08, 2015 8:18 pm
Hi Dave,
hoglet wrote:1. Does the 8255 function correctly in a normal Atom?
Yes, I have more 8255's but they all give the same result
hoglet wrote:2. What's the voltage on the 8255 PA4...PA7 measured on the 8255 pins?
All high
hoglet wrote:3. Do you see the 8255 CS signal being asserted after reset?
Have to check
Post by hoglet » Wed Apr 08, 2015 8:25 pm
It might be worth removing the address decoder CPLD and checking none of the contacts in socket are bent inwards. This can prevent then making contact with the CPLD. If this were happening to the nB00x signal, then writes to the 8255 would not happen. PA7..4 being high is the power up state, so it looks like for some reason the write is broken.
Post by oss003 » Wed Apr 08, 2015 8:55 pm
the CS signal is toggled at powerup.
Wait a minute... NWDS is about 2,5V and is reflected on the RST. Looks like a shortcut somewhere. I'll check it.
Post by oss003 » Wed Apr 08, 2015 9:35 pm
Ok guys,
I think I found Phil's missing track on his board, it caused a shortcut on my board....... :lol: :lol:
Problem solved, up to the next phase ..... :wink:
Post by roland » Wed Apr 08, 2015 9:47 pm
Hi Kees,
I agree that the problem is in accessing the 8255 so focus on that. Besides that, I noticed two other issues:
1. You have a 2014 board, not 2015
2. If you look at the end of the line on your Atom there is a white rectangle which is not on the Atomulator screen, annotated in red:
If you get the normal text screen and there are still characters on there then check the 74xx245 in the video area. That might be faulty. This looks like my G and @ problem like I had when I build my first 2014 model. It turned out to be a defective 245.
Greetings,
Roland
Post by oss003 » Wed Apr 08, 2015 9:50 pm
Hi Roland,
well, the problem was a shortcut between the NWDS and the RST.
It's working fine now!!
Post by roland » Wed Apr 08, 2015 9:54 pm
Nice =D>
However, IIRC Phil has a 2015 board, so on every five boards there is one faulty board which is 20% faulty. I think I have to find another supplier for the next batch.....
How's Chuckie Egg running on your Atom?
Post by oss003 » Wed Apr 08, 2015 9:55 pm
Well as I mentioned before, the next phase is adapting the keyboard so I can't type in anything yet.
Post by roland » Wed Apr 08, 2015 10:03 pm
I'm a little bit too enthusiastic. The reason I ask is that TheCorfiot and I noticed some noise on the screen when playing Chuckie Egg. I managed to get rid of it by replacing the SY6502 by a MPS6502A. This made the noise in Chuckie Egg disappear but now I have a little noise when doing *CAT. If I replace the video buffers by 74LS types than I have no noise in text mode but then it is back in Chuckie Egg (with both CPU's).
I can't explain this....
Post by hoglet » Wed Apr 08, 2015 10:11 pm
Roland,
Is the noise like the old Atom screen noise, or like the GODIL/SID audio induced noise, or something else?
Just so I know what to look out for when I have a working keyboard.
Post by roland » Wed Apr 08, 2015 10:17 pm
The noise is more like the old Atom noise but only within the graphics area, not at the border.
PhilYoung
Post by PhilYoung » Wed Apr 08, 2015 10:26 pm
roland wrote:Nice =D>
Nope, it's a 2014 version. How many of the 2015's have been built so far do you know.
Phil Young
Post by roland » Wed Apr 08, 2015 10:57 pm
There are four 2015 models built (including Hoglets) and they all seem to work. The fifth is being build but no status info so far....
PhilYoung
Post by PhilYoung » Thu Apr 09, 2015 8:39 am
roland wrote:There are four 2015 models built (including Hoglets) and they all seem to work. The fifth is being build but no status info so far....
The first batch was a Friday afternoon job then.....
Phil Young
Multiwizard
Post by Multiwizard » Thu Apr 09, 2015 7:20 pm
It looks real good Kees... =D>
Nice way of swapping pin 23/24 of the PIC controller... :D
Greetings, Wim... :-)
Post by hoglet » Sat Apr 11, 2015 7:59 pm
Hey guys,
The keyboard is now done....
The only problem was I slightly over exposed it, which resulted in two of the finest tracks getting over cooked:
A bit of drilling, then a first check that everything fits:
In go the wire links:
At this point, I actually tested all the keys worked by shorting each pad in turn.
Then the final assembly:
Post by hoglet » Sat Apr 11, 2015 8:00 pm
And the end result is pretty smart:
Post by 1024MAK » Sat Apr 11, 2015 8:50 pm
Looking Good 8) =D>
Post by oss003 » Sat Apr 11, 2015 9:02 pm
Thanks Dave for witnessing the birth of a new Atom ....... =D> =D>
Nice job!
Post by roland » Sat Apr 11, 2015 11:39 pm
Only a few smilies to express my feelings: :o 8) =D>
This is excellent. I'll keep my eyes open for the missing key caps!
Post by hoglet » Sun Apr 12, 2015 8:03 am
Thanks Mark, Wim, Kees and Roland - far too many hours went into this!
roland wrote: This is excellent. I'll keep my eyes open for the missing key caps!
Thanks, but I'm sure spare Atom key caps are rarer than hen's teeth.
The key caps I would like to improve are:
- Shift (x2)
- Return
- Rept
- Up/Down (can probably live with this)
- Left/Right (can probably live with this)
I was thinking of trying to do something with white water-slide decal inkjet transfers.
