Today I received.....
lcww1
Re: Today I received.....
Post by lcww1 » Sat Apr 14, 2018 11:56 am
AUN Manager’s Guide Iss. 2 Sept’ 1993
Scan to follow ........ :D
Post by 1024MAK » Sat Apr 14, 2018 12:26 pm
mattdy4 wrote:An "untested" BBC Model B Issue 2 with Sideways ROM (+RAM?) Board.
Nice 8) . If you want the contents of the EPROM chip with the uncovered window not to decay, it's best to cover the window with either a paper label or black insulation tape.
mattdy4 wrote:Also got an EEPROM programmer with it
Do you mean an EPROM programmer?
mattdy4
Post by mattdy4 » Sun Apr 15, 2018 6:54 pm
Yeah I noticed that. I'm guessing that whatever is/was on it wasn't that important to the previous owner
I had to Google to realise there is an actual difference. You learn something new every day!
Reason: Edited to remove excessive quote tags
Lardo Boffin
Post by Lardo Boffin » Mon Apr 16, 2018 9:18 pm
A very nice boxed issue 4 beeb with all the leaflets and original guarantee (and an Acorn cassette player)! Not fully tested yet but boots up fine and all keys work.
I now have a boxed beeb for each of my kids once they are old enough. They *will* get into retro computers!
Its not quite as yellow as it looks...
BBC model B 32k issue 4, 16k sideways RAM, Watford 12 ROM board, Viglen twin 40/80 5.25" discs, Acorn 6502 coproc
BBC Master, Datacentre + HDD, pi co-proc
Post by 1024MAK » Tue Apr 17, 2018 1:02 pm
Today...
Another box of delights from Dave H :D
AP5 kit with nice case
Thanks Dave =D>
Post by daveejhitchins » Tue Apr 17, 2018 10:03 pm
1024MAK wrote:Another box of delights from Dave H :D
Glad it arrived intact.
I'll take this opportunity to raise a potential problem for AP5 kit units:
The 2 x 20 way connectors, for the User Ports, are new - old stock. I've noticed, when I've been building them, that the pins have become 'aged'. So I've been pre fluxing them and activating with my heat gun, before soldering. So I'm recommending something similar for kit builders. e.g. Check they're soldered correctly!
Thanks - Dave H :D
crj
Post by crj » Tue Apr 17, 2018 10:37 pm
mattdy4 wrote:
1024MAK wrote:If you want the contents of the EPROM chip with the uncovered window not to decay, it's best to cover the window with either a paper label or black insulation tape.
Actually, wouldn't an EPROM be OK in practice if it was inside a Beeb that was kept closed? I doubt much light would get in there!
Post by 1024MAK » Tue Apr 17, 2018 11:22 pm
Yes, if no, or very little light can get in, it does not matter. But it does depend on which case he has (different cases have different sized slots at the rear). And where it is kept. And this assumes the lid is fitted most of the time.
lcww1
Post by lcww1 » Wed Apr 18, 2018 6:04 pm
Fresh from OSHPark:
simoni’s Arch 2nd floppy pcbs
See this thread for details: viewtopic.php?f=16&t=14874
marcusjambler
Post by marcusjambler » Mon Apr 23, 2018 9:08 pm
This is my weekend haul...
Stuff from Wakefield show... It was great to meet people :D
And I was gifted a pile of Archimedes software and books by an old school friend.
So many new toys :D
Is any of it MIA ?
Marcus
crj
Post by crj » Tue Apr 24, 2018 4:41 pm
Finally, some melatonin:
I'm hoping this will fix my sleep disturbance and give me my life back. If it does, hopefully that in turn will mean more energy devoted to retrocomputing projects. (-8
pau1ie
Post by pau1ie » Wed Apr 25, 2018 6:32 pm
Thanks to a suggestion from prime I received some solder. Couldn't they have found a bigger box though?
Solder... And the box it came in.
lcww1
Post by lcww1 » Wed Apr 25, 2018 6:51 pm
pau1ie wrote:Thanks to a suggestion from prime
I took the same advice recently and bought some of this solder - I have to say it’s by far the best solder I’ve ever used :D - thanks Prime! - I think I’ll stock up on some more.....
pau1ie
Post by pau1ie » Wed Apr 25, 2018 7:33 pm
I think this is probably as much solder as I will ever use!
Last week I was chuffed to receive this. The price was pretty reasonable, and I was expecting the green first edition. According to Elminster earlier in the thread, this is "much more rare", so I was pleased to receive the updated version!
Assembly Language Programming by Ian Birnbaum
Post by Elminster » Wed Apr 25, 2018 8:28 pm
pau1ie wrote:I think this is probably as much solder as I will ever use!
The green first ed usually appears more often. I have both just in case, there was some useful extra stuff in the Orange one if memory serves me.
Post by richardtoohey » Thu Apr 26, 2018 8:52 am
Elminster wrote:I have both just in case
Same here. And the Electron version. But in my case, not sure of "just in case" of what? #-o A good book, though, one of the ones I used BITD to understand assembly (wouldn't say I ever mastered it!)
Post by 1024MAK » Thu Apr 26, 2018 12:45 pm
                                WAIT FOR RICHARD NOT BUSY
FF10  2C 01 B8  BIT #B801       Busy ?
FF13  30 FB     BMI #FF10       ..yes, wait for Richard to be not busy
:mrgreen:
Post by richardtoohey » Fri Apr 27, 2018 6:41 am
Need to get the book out to review that code :P
Wish I knew what I was doing when I'm busy because I don't seem to achieve that much ... #-o :-k ](*,) :-({|=
Today I received my new AP5 from Dave H (it looks nice and its very solid), but I'm too lazy to take a photo. [-X
EDIT: hey, there's some plagiarism going on here! Mods, mods, where are you?!?
viewtopic.php?f=44&t=15007&p=201731#p201716
Lardo Boffin
Post by Lardo Boffin » Mon Apr 30, 2018 9:59 am
Got this from eBay - looked interesting. One of many beeb games I had never heard of.
At some point I may even get chance to see if it works!
Edit - tested and working although my Master only seems to be able to run the 40 track side. The 80 track side loads and then goes wierd with flickering colours on the top half of the screen.
pau1ie
Post by pau1ie » Mon Apr 30, 2018 10:37 am
Of course I am obliged to point out that anyone can play that online at:
bbcmicro.co.uk - UIM (Ultra Intelligent Machine)
Post by 1024MAK » Mon Apr 30, 2018 11:16 am
Steel yourself for some good news...
Just arrived minutes ago, another package from Dave H. :D
Parcel containing EUPURS and Pegasus cases
I don't have time to open the box yet, that will have to wait until later...
Thanks Dave =D>
Post by Pernod » Mon Apr 30, 2018 11:29 am
Lardo Boffin wrote:Got this from eBay - looked interesting. One of many beeb games I had never heard of.
Fun fact: The title screen was drawn by me in AMX Super Art.
Lardo Boffin
Post by Lardo Boffin » Mon Apr 30, 2018 1:03 pm
pau1ie wrote:Of course I am obliged to point out that anyone can play that online at:
:D
Lardo Boffin
Post by Lardo Boffin » Mon Apr 30, 2018 1:05 pm
I wish I had artistic talent. :mrgreen:
z0m8ied0g
Post by z0m8ied0g » Mon Apr 30, 2018 2:05 pm
Its like Elite under the sea.
rharper
Post by rharper » Tue May 01, 2018 4:06 pm
Two GoTeks arrived a couple of weeks ago, also LED and OLED screens, switch and rotary switch soon after. The LED needed some resistors but soon all were set up as second drives on my Electrons' Plus 3 drives, replacing 3.5" HD drives.
They are powered from molex 3.5" splitters connected to the Plus 3 floppy drive connector.
Ray :)
Raycomp
gazzaD
Post by gazzaD » Sat May 12, 2018 10:35 am
Finally got bored of using T-Pieces to build up my Econet, and made up some boards that let me build the main bus out of RJ45 patch leads...
The boards from OSH Park:
And assembled:
Gareth
lcww1
Post by lcww1 » Sat May 12, 2018 11:22 am
Very nice! =D>
Reminiscent of these - http://www.beebmaster.co.uk/Econet/PBSockets.html, which I’d been wondering about copying.
Would you be prepared to share your pcb design on the OSHPark site? I’d like to build some of these for my growing Econet.
IanS
Post by IanS » Sat May 12, 2018 11:28 am
gazzaD wrote:Finally got bored of using T-Pieces to build up my Econet, and made up some boards that let me build the main bus out of RJ45 patch leads...
Nice idea, I did something similar (with only 2 sockets) viewtopic.php?f=41&t=5594&p=157254#p157254
My clock (based on the now "standard" Simon Inns design), also has an RJ-45 - viewtopic.php?f=3&t=11196&p=160889#p159071
My pin-out is based on the original Phil blundell design - http://www.beebmaster.co.uk/Econet/PBSockets.html
It looks like yours are using a different pin-out. I suspect it's unlikely you'll ever try and plug your boards into other RJ-45 Econet implementations.
But if people like this idea, can we agree a standard?
(I must get around to actually getting some t-piece replacement PCB's made - http://www.beebmaster.co.uk/Shows/Bolto ... 16-30.html)
gazzaD
Post by gazzaD » Sat May 12, 2018 1:13 pm
It turns out I've managed to leave a ground pad isolated, despite having a ground plane across most of the board base, so not quite ready for sharing yet. I'll fix that at some point next week, and publish the design once I've has a set come back I know is correct. Given the size of the boards, it's only $16 for 3.
My Cat5 pinout is based on the published Econet wiring colour code for blue and orange, mapped to the Cat5 EIA-TIA568A scheme
5-pin DIN number	Signal		  Colour					Cat 5 Pin
1						Data+			White/orange			3
4						Data–			Orange			  	 6
2						Ground			(other copper)  	 1,2,7,8
5						Clock–	     Blue				     4
3						Clock+	     White/blue			  5
Gareth
