Tape CSW files -not working on other sites
Re: Tape CSW files -not working on other sites
Post by CMcDougall » Tue Jun 02, 2015 10:16 pm
vanekp wrote:with these switches it makes a propper hq.uef
I tried that, still does not work, gets to block 2B, then Data? and crashes....
BUT, if you use BackToLife (.CSW to .WAV) I can confirm it loads back into a actual real beeb \:D/
as the original tape does not :lol: (sideB was closest to working :x )
vanekp
Post by vanekp » Fri Jun 05, 2015 7:17 pm
:lol: I got told how to do it by the expert years ago when he was running the acorn preservation site and I was doing conversions of the software I had at the time.
:wink:
Post by CMcDougall » Thu Jul 16, 2015 8:54 pm
Revs -Acornsoft 1985
(CSW of this in first post (pg1 top))
full manual scan here : http://www.mediafire.com/download/15b1p ... Revs01.zip
revsUEFhq.zip
UEFhq
(30.42 KiB) Downloaded 214 times
Revs 4Tracks -Acornsoft 1985
(CSW of this in first post (pg1 5th from top))
revs4TracksUEFhq.zip
UEFhq
(24.13 KiB) Downloaded 215 times
Fab Four Volume 1 -ASL 1989 : (CHAIN"" 1st game (S/P), *RUN (O/T) 2nd game)
sideA
FabFourVol1a-ASL1989-Sphere2 OmegaOrb.zip
CSW
(453.66 KiB) Downloaded 222 times
UEF
(41.93 KiB) Downloaded 221 times
sideB
FabFourVol1b-ASL1989-Psycastria2 Thunderstuck2.zip
CSW
(408.58 KiB) Downloaded 218 times
UEF
(40.2 KiB) Downloaded 221 times
Did not bother with a UEFhq of these, as no 'streams' or extra blank space between the files. Can make it, if requested.... Thanks to MatthewThompson for not throwing in the bin, & at me instead =D>
Disc version here: http://www.stairwaytohell.com/bbc/archi ... abFour.zip
Post by CMcDougall » Thu Mar 31, 2016 7:32 pm
Bullseye by TV Games / Domark / Central and previously released by Macsen:
inlay A and tape
inlay B
recorded same both sides 8mins 20secs, left channel strong, right useless
BullseyeA.zip
uef
(21.38 KiB) Downloaded 171 times
BullseyeAhq.zip
UEFhq
(22.07 KiB) Downloaded 169 times
BullseyeAcsw.zip
csw
(276.35 KiB) Downloaded 172 times
BullseyeB.zip
uef
(21.55 KiB) Downloaded 169 times
BullseyeBhq.zip
UEFhq
(22.25 KiB) Downloaded 169 times
BullseyeBcsw.zip
csw
(243.24 KiB) Downloaded 169 times
Post by lurkio » Thu Mar 31, 2016 7:54 pm
CMcDougall wrote:Bullseye by TV Games / Domark / Central and previously released by Macsen:
Great! Smashing! Super!
(Sorry.)
Post by CMcDougall » Thu Jun 30, 2016 10:09 pm
Zalaga - Aardvark 1983
This needs to be *RUN, only works on bEm22 as BeebEm414 can't cope with the tape protection loader...
says V2.2 on last file
ZalagaBuef.zip
UEF
(11.54 KiB) Downloaded 206 times
ZalagaBhqUEF.zip
hqUEF
(11.91 KiB) Downloaded 205 times
ZalagaBcsw.zip
csw
(122.91 KiB) Downloaded 209 times
here are the ones from AcornPreservation.org, the site does not exist now,
and not all 262 of them worked, hence this thread! :D
grab my upload here 57mb : https://www.mediafire.com/?h13hsx7m6c4msh7
AtariSoft 1984 - Pole Position CSW here :
viewtopic.php?f=1&t=11465#p143397
keys below & instructions:
inst
Commie_User
Post by Commie_User » Thu Aug 11, 2016 10:30 am
BOOM-Shankar!
With the Beeb as spicy as this, it should have been illicit!
Post by CMcDougall » Mon Jul 31, 2017 5:12 pm
ELITE - Acornsoft 1984 - Version 1 - electron
ELITEelkAcsw.zip
csw
(211.87 KiB) Downloaded 168 times
ELITEelkAhq.zip
HQuef
(24.6 KiB) Downloaded 169 times
ELITEelkA.zip
uef
(24.06 KiB) Downloaded 168 times
Post by CMcDougall » Mon Aug 28, 2017 10:06 am
Electron :
Cybertron Mission - Program Power 1983
Frenzy - Micro Power 1984
Positron - Program Power 1983 (or Gary Partis Soft)
luckily, on all these, game recorded twice on side A, and blank on side B
so 2nd game copy worked first time, as 1st copy had the dreaded usual wind up start of tape
media
inst
enjoy! 8)
PositronELKcsw.zip
csw
(66.05 KiB) Downloaded 165 times
PositronELKhq.zip
uefHQ
(6.24 KiB) Downloaded 164 times
FrenzyELKcsw.zip
csw
(118.59 KiB) Downloaded 168 times
FrenzyELKhq.zip
uefHQ
(9.02 KiB) Downloaded 164 times
FrenzyELK.zip
uef
(8.71 KiB) Downloaded 164 times
cybertronMissionELKcsw.zip
csw
(104.38 KiB) Downloaded 162 times
cybertronMissionELKhq.zip
uefHQ
(9.11 KiB) Downloaded 165 times
cybertronMissionELK.zip
uef
(8.81 KiB) Downloaded 162 times
Post by CMcDougall » Sun Jan 07, 2018 12:24 pm
Five A Side Socca -IJK 1983 (or Star Soccer in the first loader by D M Smith) - Electron
cov
this is a weird one, completely different from the BBC version, as that has 4 files to load (SOCCA, DATA1, DATA2 & DATA3)
now, when trying to load this Electron version (SOCCA, DATA1, ? (Locked))
into a BBC, it hangs on end of block 1A00, as if tape not long enough.. :? (? is load1781 call3100 len1B7E)
so wonder if the electron ULA can handle this last locked *RUN file, and the BBC can't :shock:
in the generated .TXT file, we have :
The following block size is 280
THE EMPTY BLOCK FLAG IS WRONG.
Found :          ? 19	Checksum ok
31 data blocks written.
Carrier tone written, length 2140 waves.
Baud rate of the preceding data was 1321.596
Found :          ? 1A	Checksum ok
32 data blocks written.
Carrier tone written, length 2144 waves.
Dummy byte in carrier tone is &2A.
Carrier tone written, length 4 waves.
Dummy byte in carrier tone is &0D.
Dummy byte in carrier tone is &00.
Dummy byte in carrier tone is &81.
Baud rate of the preceding data was 1322.521
THE FIRST BYTE OF THE NEXT BLOCK IS NOT '*'.
The following block size is 7
DATA BLOCK WRITTEN WITH A BAD CHECKSUM OR NON-STANDARD BLOCK.
33 data blocks written.
MISREAD A BLOCK.
Carrier tone written, length 2 waves
anyways, one to ponder on!
The .UEFhq does not work on BeebEm414 or bEm22
But, does work fine on ElkulatorV1 ,
the .CSW does not, but put here anyways to play back to elk using BackToLife .CSW<>.WAV
(not tested as yet..) EDIT: Working 8)
fiveAsideSoccaELKbHQ worksElkulatorV1 ONLY.zip
UEFhq
(4.68 KiB) Downloaded 157 times
fiveAsideSoccaELKbCSW noWork.zip
CSW no work
(77.17 KiB) Downloaded 154 times
Post by CMcDougall » Sun Feb 18, 2018 1:53 pm
^ 6 folk not figures that out then :?
next up, just one file, sideB made a working CSW, sideA made a UEF & hqUEF
BugByte Galaxy Wars
different from the STH .SSD version, as asks "Level (1 to 4) ?"
and the high score layout is also different showing scores per levels
*T.
galaxyWarsB-bugByte1983.zip
uef
(9.93 KiB) Downloaded 159 times
galaxyWarsB-bugByte1983hq.zip
hq
(10.25 KiB) Downloaded 158 times
galaxyWarsB-bugByte1983csw.zip
csw
(114.37 KiB) Downloaded 153 times
Post by CMcDougall » Tue Feb 27, 2018 10:46 pm
Deaths Head Hole - Peaksoft 1983
find story & instructions here:
http://peaksoft.co.uk/peaksoftstory/
http://archive.worldofdragon.org/index. ... _Head_Hole
media, as diff from Dragon /Spec /etc
just one basic file,
*T.
PAGE=&E00
CH.""
DeathsHeadHole-PeaksoftB.zip
uef update to v2.3
(7.31 KiB) Downloaded 154 times
DeathsHeadHole-PeaksoftBcsw.zip
csw
(137.81 KiB) Downloaded 149 times
Post by CMcDougall » Tue Feb 27, 2018 10:55 pm
Gideons Gamble - Superior 1983
*T.
*RUN
GideonsGamble-Superior1983hq.zip
UEFhq
(17 KiB) Downloaded 154 times
GideonsGamble-Superior1983csw.zip
csw
(247.51 KiB) Downloaded 151 times
Post by CMcDougall » Tue Feb 27, 2018 11:01 pm
Caveman Adventure - Program Power - D Carlos - V10 - 12 Jan1983
or Neanderthal Man :?
EDIT: found keystrip! :)
F keystrip
*T.
PAGE=&E00
CH.""
CavemanAdventure-ProgramPower.zip
uef v2.3
(9.05 KiB) Downloaded 152 times
CavemanAdventure-ProgramPowerCSW.zip
csw
(124.05 KiB) Downloaded 149 times
Post by CMcDougall » Tue Feb 27, 2018 11:08 pm
Eldorado Gold - Program Power - 1982
*T.
PAGE=&E00
CH.""
EldoradoGold-ProgramPowerHQ.zip
uefHQ
(10.73 KiB) Downloaded 152 times
EldoradoGold-ProgramPower.zip
uef v2.3
(10.35 KiB) Downloaded 151 times
EldoradoGold-ProgramPowerCSW.zip
csw
(155.19 KiB) Downloaded 148 times
Post by CMcDougall » Tue Feb 27, 2018 11:12 pm
Felix And The Fruit Monsters - Program Power - 1983
*T.
CH.""
FelixAndTheFruitMonstersCSW.zip
CSW
(113.87 KiB) Downloaded 151 times
FelixAndTheFruitMonstersHQ.zip
uefHQ
(7.7 KiB) Downloaded 153 times
FelixAndTheFruitMonsters.zip
uef v2.3
(7.44 KiB) Downloaded 151 times
Post by CMcDougall » Sun Apr 15, 2018 7:28 pm
beeb version on sideA, elk on sideB:
:? will update when I re-find Elk version CSW , must of deleted in err... #-o
BrianJacksSuperstarChallenge-Martech1985elk.zip
E uef
(12.92 KiB) Downloaded 146 times
BrianJacksSuperstarChallenge-Martech1985Ehq.zip
E uefHQ
(13.32 KiB) Downloaded 150 times
BrianJacksSuperstarChallenge-Martech1985csw.zip
B csw
(175.59 KiB) Downloaded 150 times
BrianJacksSuperstarChallenge-Martech1985hq.zip
B uefHQ
(13.66 KiB) Downloaded 149 times
BrianJacksSuperstarChallenge-Martech1985.zip
B uef
(13.15 KiB) Downloaded 148 times
Post by CMcDougall » Wed Apr 18, 2018 10:08 pm
Podd - ASK - Acornsoft
the one in STH is different :
http://www.stairwaytohell.com/filesearc ... rch=Search
and says by "softech Services" :?
ss ldr
I got the tape only, and says for Beeb & Elk :
Beeb & Elk
my one has longer files (but add to &4600), same both sides of tape, luckily as sideB/2 made these! \:D/
*T.
CH.""
Podd-ASKbCSW.zip
csw
(155.8 KiB) Downloaded 148 times
Podd-ASKbHQ.zip
uefHQ
(11.36 KiB) Downloaded 150 times
Podd-ASKb.zip
uef
(10.95 KiB) Downloaded 148 times
Post by CMcDougall » Wed Apr 25, 2018 10:31 pm
Draw - Micro Power 1983 electron , T J Balls 1982, v4.1P, Copy : *TJB
recorded twice sideA, blank on sideB
never looked at this before, file "DEMO" contains a few nice pics! :D
I , DEMO , R , 13
*T.
PAGE=&E00
CH.""
Draw-MicroPower1983elkCSW.zip
CSW
(148.28 KiB) Downloaded 147 times
Draw-MicroPower1983elkHQ.zip
uefHQ
(8.62 KiB) Downloaded 149 times
Draw-MicroPower1983elk.zip
uef
(8.27 KiB) Downloaded 150 times
Post by CMcDougall » Sat Apr 28, 2018 6:07 pm
Galactic Commander - Micro Power 1983 electron
all work, but not on emulators, being ElkulatorV1 :?
when loading the CSW it has to be at tape speed slow.
It also 'crashes' after screen splash :shock: due to loading file COM1 @900
to get round this :
LOAD"COM2"
*L. COM1
RUN
bizzare, as works on a real elk :D
GalacticCommander-MicroPower1983elkCSW.zip
CSW
(124.49 KiB) Downloaded 147 times
GalacticCommander-MicroPower1983elkHQ.zip
uefHQ
(9.07 KiB) Downloaded 147 times
GalacticCommander-MicroPower1983elk.zip
uef
(8.71 KiB) Downloaded 149 times
Post by CMcDougall » Tue May 01, 2018 6:53 pm
Jet Power Jack - Micro Power 1984 : electron
again per MP recorded twice on SideA, blank sideB
*T.
CH.""
JetPowerJack-MicroPower1984elkCSW.zip
csw
(113.87 KiB) Downloaded 145 times
JetPowerJack-MicroPower1984elk.zip
uef
(8.6 KiB) Downloaded 146 times
JetPowerJack-MicroPower1984elkHQ.zip
uefHQ
(8.93 KiB) Downloaded 147 times
Post by CMcDougall » Fri May 04, 2018 6:49 pm
Commando - Elite - Electron
here is the original (not re-release Encore version)
also known as "Space Invasion" :shock:
(see insert : http://www.stardot.org.uk/forums/viewto ... 72#p202095 )
sideB was better to make the files, even though sideA sounded better :?
I have checked both sides, and are same,
after stealing a block from sideB (on actual beeb loaded) to confirm file COMSCR
Commando-Elite1985ElkCSW.zip
csw
(232.28 KiB) Downloaded 146 times
Commando-Elite1985ElkHQ.zip
uefHQ
(19.51 KiB) Downloaded 149 times
Commando-Elite1985Elk.zip
uef
(18.98 KiB) Downloaded 149 times
Post by CMcDougall » Wed May 09, 2018 8:23 pm
Thrust - Superior - 1986 electron (at mo) & beeb....
this was a first, the elk version worked straight away, but beeb side failed! :shock:
might have another go with a CSW laters...
Thrust-Superior1986elkCSW.zip
csw
(204.65 KiB) Downloaded 142 times
Thrust-Superior1986elkHQ.zip
uefHQ
(19.57 KiB) Downloaded 143 times
Thrust-Superior1986elk.zip
uef
(19.01 KiB) Downloaded 143 times
Post by CMcDougall » Fri Feb 08, 2019 10:40 pm
Electron Invaders - Micro Power 1984 / program power
ldr scr
*T.
CH."" 8)
ElectronInvaders-MicroPower1984.zip
uef
(6.92 KiB) Downloaded 5 times
ElectronInvaders-MicroPower1984hq.zip
HQ uef
(7.18 KiB) Downloaded 6 times
ElectronInvaders-MicroPower1984csw.zip
csw
(90.79 KiB) Downloaded 5 times
