Replacement black plastic BBC keyboard surround
Would you prefer a black surround...
Poll ended at Fri Dec 25, 2020 4:22 pm
With the ashtray perforation
3
50%
Without the ashtray perforation
3
50%
Total votes: 6
e668ecp
Re: Replacement black plastic BBC keyboard surround
Post by e668ecp »
Lets hope not!
vanekp
Post by vanekp »
The "ashtray" can always be cut out (from the back) with an exacto knife if its needed.
Peter.
marcelaj1
Post by marcelaj1 »
If you are going ahead with this I would like a couple.
e668ecp
Post by e668ecp »
Waiting on the supplier who has been ill
e668ecp
Post by e668ecp »
Supplier trying to find a printer for the led text
gavinlew
Post by gavinlew »
I’d be interested in a couple as well
Post by Coeus »
I'd love one. Preferably without the perforations as part of the reason I want my is that my 4 y/o has pressed out that bit but I don't have anything to put in the hole. (The other is that the lower right corner is cracking and bits starting to fall off.
marcelaj1
Post by marcelaj1 »
What sort of "glue" would be required - thinking this may be a 1 chance go, if its stuck on croocked you may be stuck with a mess :cry:
arkleyjoe
Post by arkleyjoe »
i'd also be interested in 2
Post by Coeus »
Coeus wrote:
Sat Jan 23, 2021 11:25 pm
Actually forget what I said as I see you've already opted for the one with the cut-out. As there is nothing I can reasonably do to prevent it being knocked out again, the price is too much for something that may need to replaced again in the future.
e668ecp
Post by e668ecp »
You could glue in some thin plastic behind the cut out before sticking it down
e668ecp
Post by e668ecp »
marcelaj1 wrote:
Sun Jan 24, 2021 7:13 pm
No idea as yet
Post by Coeus »
e668ecp wrote:
Mon Jan 25, 2021 4:22 pm
I can't see how that would work - if the plastic was strong enough wouldn't is create a hump where there is extra plastic underneath?
e668ecp
Post by e668ecp »
I've done it with very thin plastic and it works and doesn't show. But if you're not happy then don't buy one
e668ecp
Post by e668ecp »
Supplier says it will be sticky back like the original but if you don't think you can do it then don't buy one
KenLowe
Post by KenLowe »
Coeus wrote:
Mon Jan 25, 2021 7:56 pm
I guess you could glue something on the inside of the case that covers the hole, and then from the outside of the case you could fill the recess so it's flush with the rest of the case, and then stick on the new surround.
e668ecp
Post by e668ecp »
This isn't an easy project and it's looking like people are just going to moan about everything so I'm in two minds as to tell the supplier to call it a day. I'll give him a call tomorrow.
Lardo Boffin
Post by Lardo Boffin »
I’d still like one or two however they come but understand if you don’t want to progress.
Adventure Language on GitHub
Atom, issue 5
Elk
gavinlew
Post by gavinlew »
Hoping the negativity doesn’t mean this will be abandoned , I can definitely use 2 so far!
Post by RobC »
I'm interested in at least a couple - hope this goes ahead but understand if you don't want the hassle :(
tom_seddon
Post by tom_seddon »
I'd be interested in one! I've got an issue 3 case that's been missing its surround for years...
--Tom
e668ecp
Post by e668ecp »
Project still on but people who have been negative will not be supplied with one, I'm not having hassle for something I'm trying to do to help improve our BBC's
marcelaj1
Post by marcelaj1 »
e668ecp wrote:
Mon Jan 25, 2021 9:02 pm
I still would like a couple.
Sticky back plastic I can cope with, in the past I had a bad experience with contact adhesive which left me with a worse result than what I was trying to cover up.
arkleyjoe
Post by arkleyjoe »
I'd still very much like a couple please.
stevecwilliams
Post by stevecwilliams »
Me too.. I could use 2 =D>
marcelaj1
Post by marcelaj1 »
https://www.thingiverse.com/thing:2840551
bigi
Post by bigi »
Good effort trying to sort this out bud - there have been a few attempts down the years that have gone quiet, so be great if yours come off! =D>
Definitely interested in a couple myself - this isn't an exact science and I think a few people on here are forgetting that this isn't your bulk production off the shelf screen cover...it's a very very bespoke one off design for a 40+ years old machine. it will require a level of expertise (and bravery!) to do, and yes you might end up trashing one and needing a second attempt....but at the end of the day if you don't try you'll never know will you? :D
rharper
Post by rharper »
I have put myself down for two of these, however I have tried another method successfully.
I have a replacement surround that I have used as a template to draw around on black card, alternatively measuring, drawing straight lines then rounding the corners can be accurate enough.
Cut out the card + 3 holes for LEDs +/- ZIF socket. Use PVA to glue it on AND, once fixed, on the top to give it a sheen + protection.
Probably not as good as the plastic but serviceable.
Ray
Raycomp
shakesc
Post by shakesc »
I'm interested in 1 please if available
BBC Master , Electron
e668ecp
Post by e668ecp »
Update is that they are nearing completion. I am awaiting a photo of the first production.
One issue is who to use for shipping as they will need to be flat and sent in flat cardboard backed envelopes
