Trying to install !FTPc but need acornssl module
Post by Rod C » Sat Aug 29, 2020 3:25 am
I'm aiming to set up ftp between my Win7 notebook and ARM610 RPC running Risc OS 3.50.
When I run !FTPc I get Error: File system.modules.network.url.acornssl not found.
Can anyone suggest where I can get the module? Searching has only taken me to dead links.
This problem was also raised here but perhaps not resolved?
viewtopic.php?f=41&t=19340&p=268828&hil ... sl#p268828
Daveo wrote:
Tue May 12, 2020 3:19 am
Ok. I've found the program that needs AcornSSL and it's called !FTPc.
paintings
Re: Trying to install !FTPc but need acornssl module
Post by paintings » Sat Aug 29, 2020 7:28 am
If you can't find it anywhere else, it's hiding inside !Boot.Resources.!System.350.Modules.Network on the "Nightly Beta HardDisc4" archive on the ROOL website: https://www.riscosopen.org/content/downloads/common
Be sure to grab the .ZIP version of the archive, as the self-extracting version won't unpack under RISC OS 3.5.
Post by Rod C » Sat Aug 29, 2020 12:48 pm
Thanks for that. I got the module from the zip archive and put it where it needed to be. Now I have !FTPc running. I have a lot to learn here so that's a big step forward for me. Next to get things set up on the Windows PC.
