Model B+ boot problems
RetroClarence
Post by RetroClarence » Tue Jun 30, 2020 9:36 am
Hi all
I'm new here so thanks for allowing me in.
I recently became the proud owner of a Model B+. However, it has a problem. When I switch it on, I get a continuous tone with the cassette motor LED lit. There is no onscreen display and the keyboard is unresponsive.
The machine has a RetroClinic DualOS MOS chip. That was seated fairly securely but I have tried removing it. The pins look in good shape and I've reseated it securely to the board and the same thing is happening.
I believe that this is a familiar problem. Are there any other obvious potential fixes I can try?
Many thanks in advance for the help.
Chris
egel
Re: Model B+ boot problems
Post by egel » Tue Jun 30, 2020 9:53 am
Have you checked the keyboard cable? Is it in the right place? Shifted one place gives weird effects.
marcusjambler
Post by marcusjambler » Tue Jun 30, 2020 10:30 am
Hi Retroclarence
Please post some photos of the PCB.
I've had two issues with B+ tone of death. ( Excluding possible keyboard issues )
Dead CPU and faulty RAM.
Both fairly easy to diagnose but would require desoldering and socketing new ICs.
However thats jumping the gun at this stage.
Marcus
Post by danielj » Tue Jun 30, 2020 10:34 am
I would add in "dead system 6522" to the list fairly near the top!
Post by flaxcottage » Tue Jun 30, 2020 1:22 pm
Welcome, Chris. :D
I had a similar problem with my B+. It turned out to be faulty RAM. Mark at Retroclinic diagnosed and fixed it and installed the correct DFS too. Later I had a faulty user 6522 VIA. :(
The problem with the B+ is all that solder keeping the chips in place - cheaper in manufacture, more reliable but awful to swap chips out.
stephen_usher
Post by stephen_usher » Tue Jun 30, 2020 1:39 pm
I've just recently had to swap out yet another of the Hitachi RAM chips in my B+ 128K. I just died whilst in storage in the last couple of months.
I would have struggled to diagnose the issue without an oscilloscope. IMHO it's THE essential tool for retro-computing maintenance, along with a multimeter.
KenLowe
Post by KenLowe » Tue Jun 30, 2020 2:26 pm
RAM issue with me too on my B+. I thought I had posted about it on here, but it was actually discussed on the BBC Micro mailing list:
http://mdfs.net/Archive/BBCMicro/2008/04/19/084952.htm
RetroClarence
Post by RetroClarence » Tue Jun 30, 2020 8:23 pm
Thank you for the suggestions and tips so far.
I've attached some photographs of the PCB, does anything jump out?
shakesc
Post by shakesc » Tue Jun 30, 2020 8:27 pm
Well the RAM and 6522 are socketed so they have been replaced in the past
BBC B+ 128K
marcusjambler
Post by marcusjambler » Fri Jul 03, 2020 8:21 am
What test gear do you have Chris?
RetroClarence
Post by RetroClarence » Mon Jul 06, 2020 8:57 am
Hi Marcus
None unfortunately. I'm going to send it away for diagnosis and, hopefully, repair.
Post by Kazzie » Mon Jul 06, 2020 9:53 am
Given that the B+ has so many parts soldered directly to the board, there's relatively little that you can do without proper testing equipment.
Best of luck on the repair. :)
Post by 1024MAK » Mon Jul 06, 2020 10:46 am
Not entirely true. Tricky’s test ROM is useful.
And on this B+ board, various chips including the DRAM chips are in sockets.
The biggest question is, is this a failed repair effort, or has it failed since this work was done?
If the former, then fault finding may be very time consuming even with the right test gear.
Post by Kazzie » Mon Jul 06, 2020 11:29 am
Quite right, I'd forgotten that!
