Model B+ MMC install help required
r05sco
Post by r05sco » Tue Mar 24, 2020 5:25 pm
Evening all,
I seem to have a little more free time at present and looking to get a few projects completed before #2 child arrives in mid April.
Took off the cover of what I thought was a BBC Model B, turns out it's a B+.
I have seen threads relating to the install on B's order of chips but not sure what IC to stick the MMC into.
Also the chip without a cover, what's that one? Should it be uncovered like that? Please excuse my ignorance, I'm still learning.
Any help would be most appreciated.
Regards and stay safe,
Ross
marcusjambler
Re: Model B+ MMC install help required
Post by marcusjambler » Tue Mar 24, 2020 5:42 pm
Oooh thats interesting... A B+ with factory fitted 8271 :D
The ROM with the naked window is most likely the DFS and no... It should have a sticker over it.
It might be an idea to erase it and re-program
Wheel_nut
Post by Wheel_nut » Tue Mar 24, 2020 7:08 pm
The MMC ROM should be "above" the DFS in the order. I am not familiar with the B+ socket positions but a *Help will tell you what you have and the heirarchy.
Stay safe.... Robin
#2 BBC Model B Issue 7 + 8271 DFS + Dual Floppy + Speech + PiTubeDirect on KenLowe's Tube Level Shifter
#3 BBC Model B Issue 7 + 8271 DFS + Cumana Single Floppy
Post by CMcDougall » Tue Mar 24, 2020 7:20 pm
better to use the MMFS B+ version, so can use the useless printer buffer ram so keeps page down to &E00
take out the unstickered eprom ( it will be DFS 1.2 or 0.9, then put it else where) then pop your MMC ROM in its place.
I have a B+ too, pics are in laptop #-o
can upgrade it to 128k easily, if good with soldering ram chips stacked together 8)
r05sco
Post by r05sco » Tue Mar 24, 2020 8:38 pm
Thanks for all the advice. Would definitely consider upgrading to 128k at some point, also the KK speech chip install.
Will pop the MMC in tomorrow and give it a whirl.
Many thanks,
Ross
