Managing ROMs installed in a BBC B
Wheel_nut
Post by Wheel_nut » Fri Feb 14, 2020 7:52 pm
I have been using the *UNPLUG function of Advanced Disc Toolkit (ADT) to disable ROMS installed in my Beeb but the "Unplug" doesn't seem to survive a Break. After unplugging a ROM, a *ROMS display shows the service and Language flags overwritten with Asterisks but pressing Break seems to restore the flags.
What I am trying to do is to disable the DFS ROM whilst I am using MMFS primarily to access the Games Compendium on the SD Card and allow the games to load with PAGE reset to 0E00. I would like this state to prevail until either a Ctrl-Break or until the Computer is switched Off and On again.
I have seen references to "ROM Manager" somewhere but cannot seem to find anything relevant on the Board.
#3 BBC Model B Issue 7 + 8271 DFS + Cumana Single Floppy
Re: Managing ROMs installed in a BBC B
Post by lurkio » Fri Feb 14, 2020 8:23 pm
Try the *KILL command in the Advanced ROM Manager 1.13C here:
Or here:
Post by flaxcottage » Fri Feb 14, 2020 8:26 pm
The Advanced Computer Products ROM Manager will do what you want.
Its *KILL command will survive BREAK and CTRL-BREAK. A *FX200,2 + CTRL-BREAK or switch off - switch on are needed to restore the ROM.
The manual and ROM image are attached.
Some one was quicker than me but of a similar mind. :lol:
Advanced Rom Manager.zip
(23.73 KiB) Downloaded 6 times
Remklep
Post by Remklep » Fri Feb 14, 2020 9:06 pm
Have you tried sticking the DFS ROM in a lower priority slot than the MMFS ROM?
Danny
BBC Model B+ 64K, 128K Memory Mod, RetroClinic External PiDirect with Raspberry Pi 3B.
BBC Master 128, RetroClinic Internal PiDirect with Raspberry Zero, TurboSPI MMC, RobC's VideoNuLa, Gotek Floppy Emulator.
Wheel_nut
Post by Wheel_nut » Fri Feb 14, 2020 9:20 pm
Thank you Lurkio and Flaxcottage. I followed the quoted thread and also the two download linkies and now have three options:
Advanced Disc Investigator 1.20 and Advanced ROM Manager 1.13C and Advanced ROM Manager 1.00 (1986)
Do you have any preference for one of these? Can I assume that Advanced ROM Manager 1.13C is the latest stable level?
p.s. ... and full documentation! Now thats novel. =D>
Wheel_nut
Post by Wheel_nut » Sun Feb 16, 2020 7:05 pm
Lurkio and Flaxcottage, I have installed ARM1.13C and am delighted that I can *KILL the DFS ROM and after a Break, it resets Page to 0E00. I am using ZMMFS which resides in Sideways RAM so I can now run games from the compendium which would not previously run with Page set at 1900 or higher. Also unlike the ADT *UNPLUG command, the *KILL prevails after a Break. Shift-Break and Ctrl-Break and until the Beeb is switched Off and On again.
Danny, Yes, the MMFS really has to be in a Higher order Bank to be able to intercept the DFS commands that it emulates. I have modified my Mainboard ROM Sockets to accept 27512 EPROMS in the lower 3 sockets and put a 32K Static (Sideways) RAM in Socket 101, so my standard installation now has ONE EPROM containing:
BASIC2
ZMMFS1.44
DFS
ARM1.13C
