Greetingsto all.
aerobaticant
Greetingsto all.
Post by aerobaticant » Fri Jan 24, 2020 7:37 pm
I have recently been inspired to resurrect my Acorn machines.
So far I've done PSU capacitor replacements on two BBC Model Bs (one Iss 4, one Iss 7), and a Master 128. and they're all working fine.
I've also got my Atom (Issue 4) up and running but with weird video noise issues.
Next step might be the Archimedes A310 that I bought new in 1989. It hasn't been used for about 12 years, although its monitor is working fine.
Ive also got two Electrons, although one of them has a dead ULA.
Wish me luck!
Multiwizard
Re: Greetingsto all.
Post by Multiwizard » Fri Jan 24, 2020 7:41 pm
Greetings from my little Dutch Atomic Attic, Wim... :-)
Post by DutchAcorn » Fri Jan 24, 2020 8:00 pm
Welcome and good luck! Shout out if you need help.
Post by davidb » Fri Jan 24, 2020 8:10 pm
Welcome! :D
Post by flaxcottage » Fri Jan 24, 2020 9:07 pm
Welcome. :D
mr-macrisc
Post by mr-macrisc » Fri Jan 24, 2020 9:30 pm
Welcome to the mad house :)
Post by tricky » Sat Jan 25, 2020 8:33 am
Hi, welcome, good luck.
Sounds like you will have already done the master and Archie batteries.
aerobaticant
Re: Greetings to all.
Post by aerobaticant » Sat Jan 25, 2020 11:38 pm
The Atom is a bit of a mess internally. I think it may have originally been a kit version. I've ordered replacement electrolytic caps to see if that helps with noise. But all the RAM appears to work and I've even managed to save and load to/from tape. I'll post pics to the Atom HW area at some point.
Batteries in the Master are now AA via a diode/resistor. :-)
The Archimedes is still awaiting attention!
Post by oss003 » Sun Jan 26, 2020 12:17 am
Welcome .... and enjoy the forum.
Post by roland » Sun Jan 26, 2020 8:58 am
Hi
Hi, welcome to this forum. Enjoy your visits.
A messy display can be caused by a bad C4, you've already ordered a new set of capacitors so that's fine. I also had an Atom were the small choke (L1) was bad. That is easy to test by just soldering a short piece of wire parallel to it.
And please take notice that the Atom has screen noise by design when the cpu accesses the video memory without waiting for the video fly-back.
Wish me luck!
Good luck!
Greetings from the south of the Netherlands
Post by daveejhitchins » Wed Jan 29, 2020 6:25 am
Welcome to the Forum, aerobaticant . . . Enjoy . . .
I've also got two Electrons, although one of them has a dead ULA.
Whatever you do PLEASE don't dump your dead Electron! - See here.
Return to “introduce yourself”
