Acornsoft View versions
Lion
Post by Lion » Tue Jan 14, 2020 11:15 pm
Is the version of View supplied in the Master OS ROM the last version available for the Master? Or were there further updates?
Bonus question: Is there a version of View (or, actually, any word processor) that can use the extended RAM in the PiTubeDirect fast 6502 mode?
Re: Acornsoft View versions
Post by danielj » Wed Jan 15, 2020 8:57 am
The version in MOS3.5 is probably the final version. (B3.30)? Unless a later version was supplied on the welcome disc with the Master Compact?
I'm fairly sure the version in MOS3.5 will copy itself over the tube and run as Hi-View. I don't know if the version in 3.2 does? There was a Hi version of view that ran on the beeb too AFAIK.
Lion
Post by Lion » Wed Jan 15, 2020 8:13 pm
MOS 3.5 View reports 28926 bytes free with the tube disabled and 47943 with it turned on, so it's definitely using a few extra K.
PiTubeDirect provides a megabyte of banked RAM in this mode. I just wondered if any existing software would even know to look for it.
Post by danielj » Wed Jan 15, 2020 8:41 pm
Oh, goodness no. The banked thing wasn't a standard feature of the RAM on the coprocessors that were available at the time.
Post by jgharston » Wed Jan 15, 2020 11:11 pm
I'm fairly sure the version in MOS3.5 will copy itself over the tube and run as Hi-View. I don't know if the version in 3.2 does.
Yep it does, and it's written in 6502 code, not 65C12, so runs on the Beeb and relocates onto a 6502 CoPro on the Beeb.
Hopper
Post by Hopper » Sat Jan 18, 2020 7:12 pm
Where did Acornsoft View professional fit in?
Post by Pernod » Thu Feb 27, 2020 1:47 pm
There are various versions of VIEW:
View A1.4 - original BBC version (1982)
View A2.1 - updated BBC version (1984)
View D2.1 - Tube compatible version
View A3.0 - official VIEW3 release (1986)
View A3.0 pms - is this a hack?
View B3.0 - found in MOS 3.20
View B3.11 (also B3.1) - found on Compact Welcome disk
View I3.2 - found on Prodest 128S Welcome disk
View B3.3 - found in MOS 3.50
View Professional 1.0
View Professional 2.0
Anyone know whether my comments are correct?
Post by jgharston » Thu Feb 27, 2020 6:55 pm
Is there any logic to the version strings?
Post by Pernod » Thu Feb 27, 2020 7:57 pm
Well, I'm assuming the Ax.xx were the original BBC B releases and Bx.xx for Master series, but no idea where the D2.1 fits in.
I always thought Acornsoft released only two versions of View for the Model B, original View (A1.4 or A2.1?) and the later View3 (A3.0). Did maybe PMS release a modified version for use with their products?
Post by Pernod » Fri Feb 28, 2020 2:53 pm
I've updated my post with screenshots to include the versions that came with the Compact.
Version D2.1 contains text "Tube compatible version", so looks like an official updated A2.1.
So it's just the version A3.0 pms that is an unknown.
Wheel_nut
Post by Wheel_nut » Wed Mar 11, 2020 1:51 am
I tried to run View3.0 on my BBC B and it doesn't seem to work. I reverted to ViewA2.1 and it seems to work well.
Am I correct in deducing that View3.0 was only for the Master and later machines?
Edit: The MDFS repository lists the following versions. Any clues as to which Hardware these will run on?
ViewA140 VIEW 1.40 (C)1982 Protechnic
ViewA210 VIEW 2.10 (C)1982 Protechnic
ViewA300 VIEW 3.00 (C)1982 Acornsoft
ViewB210 VIEW 2.10 (C)1982 Protechnic
ViewB300 VIEW 3.00 (C)1982 Acornsoft
ViewB311 VIEW 3.11 (C)1982 Acornsoft
ViewD210 VIEW 2.10 (C)1982 Protechnic
ViewJ300 VIEW 3.00 (C)JGH+Acornsoft
Post by Pernod » Wed Mar 11, 2020 2:00 am
For BBC B you need A3.0, whereas B3.0 is Master only.
Wheel_nut
Post by Wheel_nut » Wed Mar 11, 2020 11:40 am
I downloaded ViewA3.00 from the MDFS site and it doesn't work on my BBC B. I also noticed that it is only 15k long rather than the normal 16k for a ROM Image.
Could I ask you to upload your ViewA3.00 Image and give me a linky to it please. I cannot find a working Image anywhere. :(
Post by Pernod » Wed Mar 11, 2020 11:51 am
https://acorn.huininga.nl/pub/roms/Acornsoft/View/
Wheel_nut
Post by Wheel_nut » Wed Mar 11, 2020 4:28 pm
Thank you Nigel. I have downloaded ViewA3.0 and am currently running it in Sideways RAM. The first surprise was that it is invoked by *VIEW rather than *WORD as with ViewA2.1. Having got past that gotcha, everything seems to be working as documented and I shall commit it to EPROM once I have decided where in the heirarchy to put it. Because I am using 27512 EPROMs with four ROM Images stacked in each Socket, this needs some planning. :roll:
Thank you again for your help. ... Robin
Post by Pernod » Wed Mar 11, 2020 5:55 pm
Yeah, not sure whether that version is official. There are two versions of A3.0 at http://bbc.nvg.org/rom/Acorn/apps/
The A3.0x uses *WORD and A3.0 uses *VIEW. Also the A3.0 contains some &EA NOPs so is probably hacked. I'd really like to know the history of these to confirm which is the official Acorn release and whether the other is a third-party release to avoid a conflict, maybe by Slogger?
Wheel_nut
Post by Wheel_nut » Wed Mar 11, 2020 9:10 pm
Hmmmmm .... Is it likely that ALL View3.0 versions are versions of the Master version, hacked to work on the BBC B? A dump of the ROM doesn't identify it as any Version. I suggest this because all of the discrete View documentation seems to top out at Version 2.1.
Ihaven't found any documented functions in View3.0 over that documented for View 2.1 so what would be the advantage of using View3.0? Are there any known bugs in View2.1?
Post by Pernod » Wed Mar 11, 2020 9:36 pm
I've seen View 3 advertised, which must be a BBC version as it's included by default in all Masters. The View B3.0 dumps are presumably just extracts from MOS 3.20. I also haven't found any standalone View 3 documentation.
Post by jgharston » Thu Mar 12, 2020 1:16 am
View B3.0 from the Master works on the Beeb, as that's the version I use (patched slightly as J3.0), and have been typing with it just an hour ago.
Wheel_nut
Post by Wheel_nut » Thu Mar 12, 2020 1:43 am
Hi jgharston and thank you for the pointers.
I have just downloaded ViewB300 and ViewJ300 from your MDFS site and will try them when the Sun comes up again :)
Some questions:
1) ViewB300 downloaded as a 16kB file but ViewJ300 downloaded as a 15kB file. Is this OK?
2) If ViewB300 from the Master works on the BBC B, What is the "Patch" on ViewJ300 and Why?
3) What is the benefit of using V3.00 over V2.1? Are there any functional or stability improvements?
Thank you again for your clarifications, ... Robin
Post by jgharston » Thu Mar 12, 2020 11:08 am
See http://mdfs.net/Apps/Text/Editors/
Extensions to VIEW
VIEW is extended as follows:
VIEW starts up with format/insert F-I instead of format/overwrite FJ-.
COUNT respond with 'xxxx words counted' instead of 'word(s) counted', as it
is very unlikely that you will actually count one word.
SAVE sets the load address to &FFFFFF00 so it is recognised as filetyped to
&FFF (Text) by RISC OS/Archimedes systems and HADFS.
READ converts LF/CR, CR/LF and LF to CR, so *SPOOL, Arc and PC text files
can easily by read in, and also allows top-bit set characters through.
Keyboard reading is extended to allow accented characters and various lines
and blobs to be entered. These are characters 128 to 223 in the character
set refered to in printer manuals as 'pc8'.
On startup the top-bit set characters are redefined to the 'pc8' character
set.
Wheel_nut
Post by Wheel_nut » Thu Mar 12, 2020 4:28 pm
WOW! You had me at "VIEW starts up with format/insert F-I instead of format/overwrite FJ-."
Now only if the Delete Key would work as a DELETE rather than a BACKSPACE key ... i.e Delete the character at the Cursor rather than the preceding character!
I also like the Save as a Txt file which I take to mean that I can edit the content on a PC. The rest is a bit above my pay grade #-o
VuewJ30 works in Sideways RAM. I have discovered that whereas ViewA30 works in an EPROM, it doesn't work for me in Sideways RAM.
I am going to persevere with ViewJ30 in Sideways RAM for now and blow it into EPROM once I have decided on the heirarchy of the ROMS.
Many thanks to you and Nigel for solving this riddle for me.
