New meber from the Netherlands.
Remklep
Post by Remklep » Wed Dec 04, 2019 10:17 am
Greetings to all.
Started on Acorn machines back in 1982 when the school I attended had Acorn Atoms.
Shortly after they bought a couple of Electrons and in 1984 upgraded to model B+'s with monochrome monitors, an Econet server was also installed, all B+'s were connected to the network.
There was also one B+ with dual Cumana drives and a color monitor.
In 1985, being a 15 year old student, the school director offered me the "job" of system admin.
Yes I was a computer-nerd :D
I played many many hours of Elite on that B= with the Cumana drives and color monitor...
A couple of years ago I purchased a B+ 64Kb from eBay with 2 Cumana drives and played Elite from the original 30 year old 5.25 floppy.
Right up till the moment the caps in the PSU gave out and released the magic smoke.
They have been replaced, but somehow it damaged the Cumana drives as neither will read discs anymore.
They seem to work fine, but no matter what 5.25 floppy I put in them they all report disc error 18.
So I bought a Gotek and installed the HxC firmware on it.
A Pi3 Tube emulator is also incoming.
BBC Model B+ 64K, 128K Memory Mod, RetroClinic External PiDirect with Raspberry Pi 3B.
BBC Master 128, RetroClinic Internal PiDirect with Raspberry Zero, TurboSPI MMC, RobC's VideoNuLa, Gotek Floppy Emulator.
Re: New meber from the Netherlands.
Post by davidb » Wed Dec 04, 2019 10:38 am
Welcome! :D
cmorley
Post by cmorley » Wed Dec 04, 2019 10:43 am
Welcome :)
I think the Acorn BBC range is quite popular in The Netherlands :D
Post by Elminster » Wed Dec 04, 2019 11:05 am
Welcome, you are lucky in that the Netherlands is one of the few countries outside the UK that does meet-ups. I am sure you can find some one to have a look at those drives.
oss003
Post by oss003 » Wed Dec 04, 2019 11:11 am
Welcome, enjoy the forum .......
Greetings (also from the Netherlands)
Kees
Multiwizard
Post by Multiwizard » Wed Dec 04, 2019 11:25 am
Greetings from my little Dutch Atomic Attic, Wim... :-)
Post by flaxcottage » Wed Dec 04, 2019 2:36 pm
Welcome. :D
The B+ is a great machine.
Post by daveejhitchins » Wed Dec 04, 2019 4:40 pm
Welcome to the Forum, REMKLEP . . . Enjoy . . .
Post by tricky » Wed Dec 04, 2019 5:52 pm
Welcome,
you may have only got the heads dirty and spread it around, but maybe not :(
Post by CMcDougall » Wed Dec 04, 2019 9:00 pm
welcome R :)
Post by roland » Wed Dec 04, 2019 10:41 pm
Welcome to this forum,
Enjoy your visits here. Once a year we have our Techsat (announced on this forum) so you can meet some of us in person.
Disc error 18 means "sector not found". The controller failed to find the required sector.
Often a bad or unformatted disc but it can also be an error in the disc controller circuit. Did you try another drive to eliminate the drive as a cause?
Greetings from the South of the Netherlands,
Roland
Remklep
Post by Remklep » Wed Dec 04, 2019 10:52 pm
Roland
I have 2 Cumana drives, they both show the same error, no matter what disc I put in them.
be it the original Elite disc, Stop Press disc or one of the 50 or so Games Collection discs I have.
Before the caps of the PSU went up in smoke, both drives worked flawlessly.
Now they don't, even though the drives seem to be making all the normal sounds when putting a disc in and typing "*."
Post by DutchAcorn » Thu Dec 05, 2019 4:44 am
Welcome to Stardot! :D
About the drives:
- You have a gotek working on the interface port of the BBC so the Beeb hardware should be fine
- It is a dual drive (right?), it is unlikely that both drives developed the exact same fault at the same time.
So if you have eliminated faulty floppies as a cause I’d suspect the floppy drive cable (and/or connectors).
gidandridge
Post by gidandridge » Thu Dec 05, 2019 9:38 am
Welcome to Stardot!
Like you I also ended up being the "sysadmin" for my schools Econet. Happy times! :)
I am sure your dual Cummana drives are repairable. Would be good to get them going again. Every little precious bit of beeb hardware needs to be preserved. :D
If you are willing to dismantle it and post photos to the forum I am sure the folks on here will try and help! As DutchAcorn says you would have to be very unlucky for both drives to fail at the same time with the same fault. It would be a good to check the ribbon cables and connectors!
Enjoy the forums!
Gav.
Gav. :D
BBC Model B Sidewise ROM Board, GoSDC, Datacentre, Hybrid Music 5000
Acorn Electron Plus 1, AP6, GoSDC, Slogger Pegasus 400
Multiwizard
Post by Multiwizard » Thu Dec 05, 2019 9:51 am
how many Atoms did this school have/use? :shock:
Were these Atoms used for education? :-k
Greetings, Wim... :-)
Remklep
Post by Remklep » Thu Dec 05, 2019 11:59 am
We had about 5 Atoms and 10 Electrons, which were all replaced around 1983 by BBC Model B.
There were about 20 B's hooked up to the Econet Server.
This was for Computer Class at the Kamerlingh Onnes School in Groningen.
TimoHartong
Post by TimoHartong » Wed Jan 22, 2020 8:35 pm
Van harte welkom
xlazaro
Post by xlazaro » Thu Jan 23, 2020 11:39 am
Hi from another newbie! :D
Acorn BBC Micro model B and a lot of other 8-bit computers to take care of.
