Games with problems
feedback, questions and discussion relating to www.bbcmicro.co.uk
Re: Games with problems
Post by sweh » Thu May 07, 2020 1:10 am
vanekp wrote:
Wed May 06, 2020 8:45 pm
160*LOAD HELL1
170*TAPE
180CALL&4A72
which probably then makes the BASIC ROM the default ROM fixing the problem mentioned by Sarah.
You probably don't need *TAPE because BASIC will already be paged back in to run the CALL command. Unless the program makes a filesystem call before reading &8000...
A simple test:
   10FOR A=0 TO 2 STEP 2
   20P%=&2000
   30[OPT A
   40LDX #0
   50.LP
   60LDA &8000,X
   70STA &3000,X
   80INX
   90BNE LP
  100LDA &F4
  110STA &3100
  120RTS
  130]
  140NEXT
  150*SAVE BAR 2000+100
If you "*RUN BAR" then it will put the DFS ROM contents into &3000. But if you "*LOAD BAR" then "CALL &2000" then the BASIC ROM contents are at &3000.
Funky!
Michael Brown
Post by Michael Brown » Thu May 07, 2020 8:41 am
Hi All,
The main reason why I did not add *TAPE originally is because there is a machine code LDA#&8C at &4A26 in HELL1.
So would simply...
160 *LOAD HELL1
170 call&4A72
...do the job?
regards,
Mick.
vanekp
Post by vanekp » Thu May 07, 2020 11:00 am
oh there is I did not see that when I looked in the code, so I must have missed that but yes then the *TAPE is not required.
it also will do no harm but just be careful as there is code sitting above the basic program hell-ho.
Peter.
Michael Brown
Post by Michael Brown » Thu May 07, 2020 2:06 pm
Now amended the copy on my D041.
Mick.
Return to “the complete BBC games archive”
