connected BBC B to Internet no Hardware Modem
Rfairman
Post by Rfairman » Fri Sep 13, 2019 12:27 pm
I have connected my Beeb to a bbs on the internet using the hayes modem emulator BBS server
I am using Mini Office Communicate on the beeb and using a serial to usb cable
mini Office communicate is not ideal but it works
I attach the zip file for bbs server
I attach photo of beeb screen (traffic report for today) and screenshot of bbs server
regards
Richardexit
log
BBSServer-master.zip
(947.74 KiB) Downloaded 10 times
Re: connected BBC B to Internet success
Post by danielj » Fri Sep 13, 2019 5:30 pm
I think you want to get that in viewdata mode - it'll look rather better. Any comms ROM should do the trick?
Rfairman
Post by Rfairman » Fri Sep 13, 2019 9:11 pm
All suggestions welcome
I've tried a commstar rom but it clashes with my dfs
Is there any comms software on disc or rom that has a viewdatat mode
Mini office communicate is very basic and you can't back out of the display screen so you have to break and reload
so far I've been able to play an adventure game online ect
Regards
Richard
Post by jgharston » Sat Sep 14, 2019 1:15 am
Run in MODE 7:
REM > SimpleTerm
REM Simplest possible BBC serial terminal program
ON ERROR OSCLI "FX2":OSCLI "FX3":REPORT:PRINT:END
*FX229,1
*FX2,2
REPEAT
IF ADVAL(-1):OSCLI "FX3,3":VDU GET:*FX3
IF ADVAL(-2):OSCLI "FX2,1":VDU GET:*FX2,2
UNTIL FALSE
Post by danielj » Sat Sep 14, 2019 6:28 am
I use commstar with DFS quite happily - it should be fine with any. How does the clash manifest itself?
Rfairman
Re: connected BBC B to Internet no Hardware Modem
Post by Rfairman » Sat Sep 14, 2019 12:26 pm
It affected reading disks
Removed commstar from eeprom and problem went away
I might have at it in the wrong rom socket
Anyway now got Termulator
Works ok but still trying the best mode for Videotext
Post by Elminster » Sat Sep 14, 2019 1:20 pm
I load commstar 1.4 into sram from gotek using dfs, and then do othe4 stuff, so it should work.
Which version of commstar and which version of dfs?
Rfairman
Post by Rfairman » Sat Sep 14, 2019 3:18 pm
Thanks I was loading commstar into an eeprom
Now using Termulator with better results
Thanks for the help
Richard
