How to start games with Atomulator ?!
Sebiohazard
Post by Sebiohazard » Sat Aug 17, 2019 11:31 am
Hello everyone :)
I am a beginner with Acorn machines, I already managed to emulate the Acorn Electron & BBC but the Atom poses a problem ...
1. With the emulator Atomulator the command
*TAPE
& command
*DISK
does not work ... Why ?
2. The games I find on the internet do not have extensions ??? I do not know how to load them ?
Thanks for your help :)
Re: How to start games with Atomulator ?!
Post by oss003 » Sat Aug 17, 2019 12:08 pm
to switch to disk, you have to type the command *DOS and you have to enable the diskrom in the menu.
You also have to load a diskimage for a drive in the menu.
AtoMMC, an SD card filesytem, is auto booted when Atomulator is started. Type *CAT to list the files on SD card.
The best way to start is downloading the Atom Software Archive and unpack it in the MMC directory. Then press SHIFT-F12 to start the menu. All programs can be started from the menu.
https://github.com/hoglet67/AtomSoftwar ... e/releases
Post by hoglet » Sat Aug 17, 2019 12:22 pm
Which version of Atomulator are you using? The latest (v1.28 for windows) from here?
http://atomulator.acornatom.co.uk/
The comes pre-configured to use the AtoMMC file system, which means you can install the Atom Software Archive that includes almost every known Acorn Atom program in it.
Here is a direct link to the latest beta of the Atom Software Archive:
https://github.com/hoglet67/AtomSoftwar ... 1Beta5.zip
Unzip this to the mmc directory, which should already exist in your Atomulator installation. This may take a while, as there are over 4000 files.
Start Atomulator as normal, then press Shift-F12 (F12 is the same as BREAK on a real Atom). This should launch the Atom Software Archive menu system. You can also manually lauch the menu by typing *MENU.
In the Menu system, select the approriate chapter. Once in the chapter, use < and > to change page. Use S to search. Or press ? for further help.
Post by oss003 » Sat Aug 17, 2019 12:26 pm
To enable the tape filesystem, press CTRL-F12 and the 300 baud file system is active. Now you can load a tapeimage from the menu (CSW or UEF file).
Sebiohazard
Post by Sebiohazard » Sat Aug 17, 2019 1:25 pm
Thank you all for your responses :)
If I type
*DOS
I have this ... I do not know how to have DOS ?
Another problem games do not have extensions (see capture) ???
How to run this game thanks for your help :)
Post by oss003 » Sat Aug 17, 2019 2:40 pm
To run Astrobirds:
- unpack ASTROBIRDS in the MMC directory
- start Atomulator
- type *RUN ASTROBIRDS
You don't need DOS to run this game.
Please install the Atom Software Archive, all games are included.
Sebiohazard
Post by Sebiohazard » Sat Aug 17, 2019 2:51 pm
Hi oss003 & thank you for your help :)
I would like to emulate the Acorn Atom as originally I would like to find the DOS & the original game ASTROBIRDS in UEF or SSD format it is possible ?
& start the game with the original commands to understand how it works :) is it possible ? On the Acorn BBC emulator I tried it works.
Thank you !
Post by hoglet » Sat Aug 17, 2019 3:15 pm
Well, if you really want to go the difficult route....
Here's is a ZIP file containing a disk image that includes Astrobirds:
games1.zip
(51.85 KiB) Downloaded 38 times
Unzip that file anywhere you like.
In Atomulator you then need to:
1. Go to Settings / RamRom and uncheck RAM/ROM DiskROM Enabled. This disables the AtoMMC ROM and enables the original DOS ROM.
2. Go to Disc / Load Disc :0/2 and choose games1.dsk
3. On the keyboard:
*DOS
*CAT
LOAD "ASTROBI"
RUN
The default keyboard mapping reflects the positions of the keys on a real atom, as far as is possible. This unfortunately makes Astrobirds rather unplayable.
You can find a collection of correctly fomatted disk images here:
https://github.com/hoglet67/Optima/tree/master/disks
But honestly, using the Atom Software Archive is much easier!
Sebiohazard
Post by Sebiohazard » Sat Aug 17, 2019 7:00 pm
A big thank you hoglet for these precious & accurate explanations it's very nice :)
1. The game works but I can not find the keys to play :) can we play with a controller ?
2. Are the Atom Software Archive games different to play properly on the keyboard ?
3. Where do you find games in TAP & DSK format ?
Again thank you very much for your help & sorry for my english I use Google translation :)
[EDIT] I love the emulated sound of floppy drive & I love to write command lines as if I really have an atom !
Post by hoglet » Sat Aug 17, 2019 8:05 pm
The keys end up as:
- Left: Up arrow
- Right: Control
- Fire: Fire
You can't play this game with a joystick (the original Atom didn't have a joystick)
Atomulator does let you redefine the key mapping, but it's always a compromise on a modern PC keyboard.
There are some joystick conversions of some games, but not many.
I'm not aware of any comprehensive archives of Atom Software.
That's why we created the Atom Software Archive.
Do at least give this a try - it contains all the original software.
Post by hoglet » Sun Aug 18, 2019 11:29 am
I'm sorry, it turns out what I said yesterday was wrong.
The Atom Software Archive does have a version of Astrobirds that uses a joystick controller:
In fact, there are over 60 games that have been modified to work with a joystick controller. You can find them all by searching for the term JS (select chapter G "All Titles", then S for search, then slowly type J S then hit return).
I've just tested this and it works very well.
In Atomulator, you need to enable Settings / Joystick / Keyboard Matrix to make it work.
Post by CMcDougall » Sun Aug 18, 2019 12:04 pm
The most comprehensive tape games are here :
viewtopic.php?f=44&t=10601&p=129095&hil ... ef#p129106
Wish someone would send me 30 more again ! :lol:
Post by roland » Sun Aug 18, 2019 12:46 pm
Well, there are more that 100 games on tape here: viewtopic.php?f=57&t=16275
The AGD games have a tape version as well.
@Hoglet: can you please update the Atom Archives with all the new AGD games when you have a spare moment?
Post by hoglet » Sun Aug 18, 2019 1:06 pm
Sure... I'll do this some time next week.
Post by oss003 » Sun Aug 18, 2019 1:46 pm
and disk images ..... ;)
Sebiohazard
Post by Sebiohazard » Sun Aug 18, 2019 2:05 pm
Hello hoglet & thank you again for your help :)
I tried Atom Software Archive by following your instructions & the games work with the joystick thanks it's more pleasant :)
By cons it's a pity that the sound of the floppy drive is not activated...
I still had a question... I discovered on the forum this emulator it can launch games in TXT format where can I find them ?
It also has one thing that I like very much ... it's the scanlines mode :) Atomulator does not have this option ?
Thanks again for your help this forum is great !!!
Post by hoglet » Sun Aug 18, 2019 2:11 pm
Sorry, the only authentic effect that Atomulator supports is Settings/Video/Snow to minic Atom screen noise.
Sebiohazard
Post by Sebiohazard » Sun Aug 18, 2019 3:05 pm
OK damage for the scanlines ... & for the emulator where to find games in TAP format ?
Post by oss003 » Sun Aug 18, 2019 3:12 pm
For Atomulator you need CSW or UEF files as tape image.
A lot can be found in the zip files here: viewtopic.php?f=57&t=16275
Sebiohazard
Post by Sebiohazard » Sun Aug 18, 2019 3:23 pm
OK thanks but I was talking about http://floooh.github.io/virtualkc/ it only accepts games in TAP and TXT format...
How to do ?!
Post by oss003 » Sun Aug 18, 2019 4:01 pm
You can find some TAP files here: http://www.stairwaytohell.com/atom/wouterras/
And the TXT files are Basic programs.
Sebiohazard
Post by Sebiohazard » Sun Aug 18, 2019 6:17 pm
I can not launch games with this emulator http://floooh.github.io/virtualkc/index.html
The basic commands do not work (*TAPE *DISK *CAT *DOS LOAD"" CHAIN)... even the C64 does not work ...
Someone has already managed to launch games with ?
Post by hoglet » Sun Aug 18, 2019 6:52 pm
The Atom Emulation with floooh/yakc is quite basic...
They have included the DOS ROM, but have not emulated the FDC chip, so *DOS just hangs.
You need to treat it as a tape only Atom.
I was able to load/run Chuckie Egg from a TAP file.
Sebiohazard
Post by Sebiohazard » Mon Aug 19, 2019 12:00 am
It's a shame because the interface is well done & there is CRT mode & scanlines 8)
Post by hoglet » Sun Aug 25, 2019 2:55 pm
There's now a V11Beta 6 available that adds AGD packs 29-41 bringing us up to date.
Post by roland » Sun Aug 25, 2019 10:22 pm
Thank you 8)
I will download the new version this week.
