aotta wrote: ↑Sun May 12, 2019 10:42 am
I'm still testing the board (and maybe i don't know how to use it
), so:
- the extra ram is not showed by *ROMS but it works, and BeebAid shows correctly the slots as RAM;
- i had to reset (@+BREAK) the board once, since i got "Language?" after some time;
- i can't get AMX SuperArt Working: Roms are loaded while booting but "*pointer" is not found. Tried several *osmode options too.
Is it normal?
So...
1. Is normal. Only the 4 preconfigured banks show as RAM. I am hoping to write a utility that will allow you to specify your additional RAM banks, so that *ROMS does report these banks, but I've not done that yet.
2. Is not normal. However, it is possible that some programs may corrupt the private RAM area that stores the IBOS parameters. You can always save and restore the parameters with *CSAVE <filename> and *CLOAD <filename> to avoid having to manually reconfigure all your parameters after a reset.
3. I'm not sure about AMX SuperArt.
I've got the ROMs (AMXSP & AMXSPS - I think?), but never known how to use them. I assume I also need some disk based program too? If you can give me some pointers, I can check it out
Edit 1: Think I'm actually talking about a different AMX utility called Stop Press! Anyway, if you could post up a copy of the ROMS / Disk Image, or point me to where I can download them, I can take a look.
Edit 2: I've just located and downloaded AMX SuperRom 3.41 from
here and installed that to RAM bank 4. I get a valid response to *POINTER. If I do *POINTER ON followed by *ART it starts up the ART program.
