A3020 IDE Hard disks setup (revisited)
RichardP
Post by RichardP » Thu Nov 08, 2018 6:34 am
Hi All,
Apologies for another Hard disk thread, I just didnt want to hijack someone elses. I replaced the 80MB hard disk in my A3020 with a 80GB one I had spare - formatting it as one of the 'Standard' disks works but when I use !HForm and select 'Other' I get an error.
HFORM failed: Number too big at line 1820
I do read there are patched version but I dont seem to find much information relating to it. Is there a way to format the drive as 512MB ? (Is that the maximum?)
Richard
Re: A3020 IDE Hard disks setup (revisited)
Post by flaxcottage » Thu Nov 08, 2018 6:50 pm
2Gb is the limit for formatting with !HForm on an A3020 and then you will only get about 500Mb.
RichardP
Post by RichardP » Fri Nov 09, 2018 9:07 am
Is there any way to force !HDForm to use the maximum HEADS/TRACKS/SECTORS it can handle instead of just bailing out?
Richard
Post by flaxcottage » Fri Nov 09, 2018 10:02 am
Some report using a Raspberry Pi or RISC-PC to format larger disk sizes and that these work in RISC-OS 3.X. I have never tried this myself.
I believe the 500Mb-ish limit is a function of the ADFS.
If a Wizzo ROM is installed this will allow a 2Gb card to be partitioned into 4 x 500Mb drives. One of my A5000s has this installed. I know you have an A3020 but I believe that the Wizzo ROM can be loaded as a relocatable module.
Ottly
Post by Ottly » Fri Nov 09, 2018 1:16 pm
If I recall correctly its a basic program so you can modify it. I recall modifying the sectors, heads, etc. for one of the defined hard drives in the program to settings I wanted and it worked.
FYI: You can also load the Wizzo rom on the A3020 which will let you have 4 partitions of 512Mb running on the built in IDE controller.
hubersn
Post by hubersn » Fri Nov 09, 2018 3:23 pm
Has anyone tried a recent !HForm version on RISC OS 3.1? How is the "LBA" flag handled in the "old" world of RISC OS 3.1? Can RO 3.1 ADFS handle LBA addressing?
hubersn
