High Score Challenge S10 - R6 - Nevryon
Post by KarateEd » Mon Oct 08, 2018 8:13 pm
Season Ten: Round Six
Nevryon by Topcat96
:arrow: Round One starts at 9pm on Monday the 8th of October and ends at 9pm on Monday the 22th of October
:arrow: http://www.bbcmicro.co.uk/game.php?id=1183
Link to Overall High Score Table...http://stardot.org.uk/forums/viewtopic.php?f=46&t=15435
This is a very nicely programmed game for the Beeb......Hope you like it......
Re: High Score Challenge S10 - R6 - Nevryon
Post by FourthStone » Tue Oct 09, 2018 7:05 am
This one is nice, lots of options and brutal game play. I died many times without knowing what struck me and the the fixed obstacles are difficult to destroy while still gunning for the moving baddies..
At the end of my game it prompted to continue with 3 credits remaining, I didn't continue but what is the comp ruling on this?
Settings I used (default), happy to change if people want to:
Skill: Timid
Speed: Medium
Start Screen: 1
Colour and low res
Place holder score: 5440
Post by sydney » Tue Oct 09, 2018 7:18 am
IMO continues are a no-no.
Post by FourthStone » Tue Oct 09, 2018 7:49 am
Agreed, plus I read through the instructions and it says score gets reset to zero on continue so no advantage other than doing practice runs on that level.
Post by KarateEd » Tue Oct 09, 2018 5:07 pm
Well, I'm not too good at this one..... 1610
No Continue is correct, we don't do continuation on HSC games. I think continue in this game just starts you off where you finished but with 0 as your score. Either way, we don't do it......good call Sydney.....
Post by KarateEd » Tue Oct 09, 2018 5:32 pm
I think if you see game play from other machines, there are bullets or spheres coming from some of the fixed objects. That may be what are taking your ship down. I've had it happen to me but it happens so fast I can't tell exactly what happened.
And yes, you are using the settings we should all be using for this game. They are the default. It doesn't say clearly how to start the game but 3 space bars then and enter at the 'ship' screen and you then need one more space bar when it prompts you.
Post by KarateEd » Tue Oct 09, 2018 7:20 pm
Well, a bit better..... kind of am starting to get it a bit..... 4,870
Post by tricky » Tue Oct 09, 2018 7:46 pm
6120
I also tried HI-RES which seems a little less jerky, but it might just be that things move in smaller chunks.
I keep dying within the same few pixels, just where the gun on the floor fires round blobs diagonally at you.
(This game makes me want to go back to Jeltron)
Post by CMcDougall » Tue Oct 09, 2018 9:20 pm
loved the BITD, one of my favs!
so good I completed it a few years ago, 8 levels of needing power ups on every level :o
this game was so good overall, I always thought it was on my old 286PC with EGA graphics board & 10MB hard disc :oops:
first go, got me 6,930 8)
6930 Col
Post by chrisn » Tue Oct 09, 2018 9:27 pm
I never played this before, great game. I didn't know the Beeb had an R-Type copy! Here's my first attempt... 2930
Post by KarateEd » Tue Oct 09, 2018 11:41 pm
Well, nice on real hardware.... and the game style is starting to set in..... 6,460
Post by KarateEd » Tue Oct 09, 2018 11:53 pm
Post by KarateEd » Wed Oct 10, 2018 1:17 am
And a bit better on real hardware - BBC Master from RetroClinic - 8,430
Post by KarateEd » Wed Oct 10, 2018 1:32 am
And a bit better on the emulator - 9070
Post by KarateEd » Wed Oct 10, 2018 3:55 am
Got through level 1 - 11,610
Post by FourthStone » Thu Oct 11, 2018 9:22 am
Level 2 is hectic! Haven't worked out a good pattern yet, however one tip is that if you have to fly through an obstacle do it fast to lose less energy bars.
This score was on 'hi-res' mode which appears to be mode 2 screen at half width.
Score: 12850
Post by KarateEd » Fri Oct 12, 2018 4:08 am
Well, I got a tiny smidge higher score but hardly worth mentioning, so I will....12.110
Post by KarateEd » Fri Oct 12, 2018 6:18 am
Alright.... new high score - 14,120
Post by KarateEd » Fri Oct 12, 2018 6:23 am
Post by CMcDougall » Fri Oct 12, 2018 8:38 pm
had another blast, got to level2 again 10,300
looking at my completed level8 score, it was 19,410 but may be I used continue, just to mension it 8)
col 10,300
Post by chrisn » Sat Oct 13, 2018 9:40 am
A little better, but still on level 1... 7580
Post by tricky » Sat Oct 13, 2018 2:01 pm
Small improvement: 8040
I got all the way through level 1 on my first ship and then didn't get much further.
I do find the collision rather annoying, bullets hitting you that don't actually collide and not picking up power-ups, even though you fligh straight through them.
I think HI-Res is mode 1, with low res being mode 5.
Post by FourthStone » Sat Oct 13, 2018 8:16 pm
Second look and I think you're right...
Post by KarateEd » Sun Oct 14, 2018 5:18 am
A bit better, still am having trouble with both levels. 2 is quite difficult to see the pattern for me but I suppose I'll keep at it....15,320
Post by klintworth » Mon Oct 15, 2018 8:02 pm
My starting score: 3420
BBC B Issue 4, BBC B UNB09 Issue1 (USA), Electron, BBC Master Compact, A7000+(Castle Peak Performer)
Post by FourthStone » Fri Oct 19, 2018 8:54 am
The only way I seem able to get a higher score is to get to the end of level 1 and die intentionally which seems counter to the rules but reminds me of Wouter's idea that any way to get a high score should be permissible without actual cheating like hax and the like.
Otherwise I am at a standstill with this game as getting through the first level without losing a life is straightforward but then level 2 seems actually impossible to me at this time no matter how many attempts tried.
Ugh, bring on the next game... ](*,)
Post by KarateEd » Fri Oct 19, 2018 4:05 pm
I hear ya FourthStone.... my high score came because I was inept at getting through the first level pretty nearly every time. I'd lost so much 'life force' that a single bullet would get me. Once I got 'into the zone', high scores went out the window,.
I'm now unable to improve on my score at all because of the same reason you give. I can fairly easily get through level one now, usually within the first 3 attempts but once I hit level 2, it's all over, very little score improvement. This is one of those games where when you succeed, you do worse score-wise.
It's a tough one for sure.
Post by sydney » Fri Oct 19, 2018 5:29 pm
I totally understand why that seems to be the solution but I think it affects so few games that allowing it for the ones that need it could spoil otherwise fine games. In this instance if we allowed killing yourself intentionally at the end of level one then everyone would do it and we'd all have the same score so it's equally pointless.
The problem isn't with the competition format or the rules - it is that the game isn't suited to competitive play due to the difficulty of later levels. At least we know to not allow this game in future if it's really that bad.
Edit: This is probably why it has 'Continues', the software house realised it was too difficult so had them put in so people could see more of the game.
Post by FourthStone » Fri Oct 19, 2018 6:30 pm
I think this is correct.
The devs have ratcheted up the difficulty at the start of the second level so much that even if you do get a few power ups you're energy is usually sitting at one or less bars meaning the inevitable stray bullet causes much hair pulling and swearing, sort of makes me want to break the game... maybe one last try :lol:
Post by FourthStone » Fri Oct 19, 2018 7:29 pm
I had a few practice runs on level 2 and somehow managed to make it through, then had a proper run and made it to level 3 with 2 lives... maybe on a super lucky run further progress could be made... too many tries for today though.
Score: 14960
