Printer Emulation..(ie ESC P printer emulation)
scruss
Re: Printer Emulation..(ie ESC P printer emulation)
Post by scruss » Sun Dec 09, 2018 2:31 am
I have a couple of Epson ROM dumps, and have been all over the Amstrad printer ROMS that are out there. Yeah, the character dots are stored in a weird format, the same as the ESC/P user defined character command. It might be easier to start with the Effects Eighty source code and pick out the pin matrices from the python.
I've been working on a TTF font family (vector, not bitmap) based on DMP rom data. As for completion, don't hold your breath.
Post by Coeus » Sun Dec 09, 2018 11:24 pm
I have just discovered I have a copy of the Epson FX Printer Operation Manual in my loft so I have fetched it down. In Appendix F the dot patters for the various characters are shown including variations for several languages.
scruss
Post by scruss » Mon Dec 10, 2018 4:23 am
Yeah, they're all in the FX Printer manual, volume 2. That's where the Effects Eighty author got them from
ThomasHarte
Post by ThomasHarte » Wed Jan 09, 2019 9:53 pm
If you promise not to look at any of the rest of the code, or at least not to judge me on it, you can also grab the FX-80 font directly from the ElectrEm code, where I recall retyping it by hand.
Format is a 256-entry array of arrays, each letter being 11*9 ints:
		{											// 77 M
			W, 0, 0, 0, 0, 0, 0, 0, W, 0, 0,
			W, 0, W, 0, 0, 0, W, 0, W, 0, 0,
			W, 0, 0, W, 0, W, 0, 0, W, 0, 0,
			W, 0, 0, 0, W, 0, 0, 0, W, 0, 0,
			0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
The 11 coming directly from the fact that the manual lays things out on a grid with six squares, but dots are permitted to be either in the centre of a square or on its boundary. So there are 11 potential strike positions per character per row.
With a helpful comment at the top:
#define W	1
// W doesn't mean anything, it just contrasts nicely with the 0s in this editor
... and a separate array of character widths, for proportional mode.
So you should be able to copy and paste all of that into a tool that compiles and outputs in your preferred format pretty quickly.
rwap
Post by rwap » Fri Feb 01, 2019 6:23 am
The Retro-Printer is now available for purchase - www.retroprinter.com
There are a few issues with the BBC, so I will start a separate thread for that.
In the meantime, out of interest, I thought I would run the captured test file from above through the ESC/P2 convertor.
I have made some recent changes to the PrinterToPDF also (as we spotted an issue with 9 pin printers (which use different line spacing calculations for ESC 3 and ESC A) - this convertor is the same one as used on the Retro-Printer itself but you need to be careful as to what configuration options you set - https://www.github.com/RWAP/PrinterToPDF
However, I can see that the above conversion has an issue with the page size. I therefore added an option to turn off the default paper margins (which are according to the ESC/P2 manual 8.5mm at the top and 13.5mm at the bottom)
I then got
Post by richardtoohey » Sat Feb 02, 2019 1:11 am
=D> That looks interesting! :D
On the web page you've linked to, the last three sections all fizzle out mid-sentence?
Post by jgharston » Sat Feb 02, 2019 4:50 am
Yes, I was starting to convince myself that the cold I had was affecting me more than I thought. ;)
rwap
Post by rwap » Sat Feb 02, 2019 7:17 am
So they do - they seem to be missing the "Read More...." link
