Acorn Atom and AtoMMC
RTB
Post by RTB » Tue Jul 10, 2018 3:57 pm
HI,
I have an Acorn Atom which has the BBC Basic board fitted.
I just wanted to check if anyone knows of any compatibiity problems if I were to add an AtoMMC alongside this board?
Thanks for your help
oss003
Re: Acorn Atom and AtoMMC
Post by oss003 » Tue Jul 10, 2018 6:22 pm
Hello RTB,
in a standard Atom, the AtoMMC board is addressed at the I/O area #B40x and the AtoMMC ROM at #Axxx or #Exxx.
The BBC board shuffles the addresses and the I/O area is moved to #7xxx which does not match with the AtoMMC board.
The MMCROM is an EXTENSION ROM addressed at #Axxx or #Exxx in a normal Atom but at #Dxxx in BBCmode.
So to get the AtoMMC board operational, the ROM should be reassembled to #Dxxx and making use of I/O addresses #740x.
Greetings
Kees
Post by tricky » Tue Jul 10, 2018 9:09 pm
Is the 6522 (white socket in the top left I think) required for the AtoMMC board?
Post by roland » Tue Jul 10, 2018 9:48 pm
As far as I know the via is not required for an AtoMMC. But I wonder if that bbc card works well without a 6522 :-k
Anyway RTB if you want to use that card, there is an improved version of the original MOS ROM at http://acornatom.nl/atomarch/acl2-12/mosrom. (You might have to skip the first 16 bytes of that file because it's an Atom-in-PC file). I'm quite sure that it needs a 6522 for the TIME statement to work.
256K + 6502 Inside
