A3000 restoration
shakesc
A3000 restoration
Post by shakesc » Sat Jul 07, 2018 4:19 pm
Hello from a new old boy
I was pretty much a Beeb man originally but decided to try a A3000 off the usual auction site
Pretty pleased with it in that the dreaded battery wasnt in too bad shape. I have replaced that with the CR2032 style one off the Amiga site that someone had recommended. This is a nice little package and avoids regularly desoldering to replace. All good so far
It has the original OS (3.0?) and boots to a screen like this
I dont have a mouse yet and looking to get an adapter
I've bought what should be OS 3.11 ROMS. I fitted them, moved LK20
I only get the blue / red screen flashing and nothing else
Tried Delete power on, no joy
Put the old ROMs back and and it boots back to the previous screen (In case it helps I havent yet plugged the floppy back in)
I did a quick bus of the CMOS chip and OV and 5V seem good
Grateful for any thoughts
Re: A3000 restoration
Post by IanS » Sat Jul 07, 2018 4:28 pm
That is RISC OS 2.
I think you need to change more than just LK20, check page 28 - http://chrisacorns.computinghistory.org ... ctions.pdf
The floppy can be useful, as it may blink an error code if some other problem is found.
shakesc
Post by shakesc » Sun Jul 08, 2018 8:30 am
missed moving one of the links, now boots to RISCOS 3
Onwards to the mouse :)
shakesc
Post by shakesc » Sun Jul 08, 2018 10:48 am
Just wondered if anyone had tried these
MKIV Amiga USB mouse adapter RIGHT MOUSE BUTTON FIX
eBay item number:121715285463
Looks like it should just convert the protocol to USB
I was looking at adding a header for an Amiga mouse similar to the article https://www.thefuturewas8bit.com/acorn_ ... conversion
This feels like a neat way of going USB
aotta
Post by aotta » Sun Jul 08, 2018 9:07 pm
Amiga and Atari have different pinout than Archi's one... you should by a smallymouse2 adapter, or make one yourself..
Personally, i made my mouse adapter for the A3000 with an arduino nano and porting smallymouse2 code. If you are interested and like soldering cable, i can share the .ino files.
shakesc
Post by shakesc » Sun Jul 08, 2018 9:50 pm
that sounds good
I have a few nano's knocking around and happy to take a run with the soldering iron
aotta
Post by aotta » Mon Jul 09, 2018 10:53 am
that sounds good
So attached the sketch for Smallymouse in Arduino (one or nano).
For pinouts (4 wires in ps2 mouse, 9 wires in Archi side) you can refere to comments inside ino files, and have a look to this 2 rilevant topics:
viewtopic.php?f=3&t=13180
viewtopic.php?f=16&t=9334
Some tips: for Archi cable, i bought a couple of Genesis2 9 pin minidin... from China with couple of pounds.
And for usb mouse, i use the famous green PS2toUSB adapter, you'll find it easy and cheap.
Good soldering
SmallyMouse_Arduino.zip
(5.48 KiB) Downloaded 13 times
shakesc
Post by shakesc » Mon Jul 09, 2018 8:40 pm
thanks
just waiting for my connectors etc to arrive and will give it a go
