left and right brackets on beebem
Microboy
Post by Microboy » Fri Jun 08, 2018 6:26 pm
on a basic PC, a bracket looks like this: [
on the Beebem emulator, that is replaced by an arrow facing left and one facing right
this is annoying for two reasons
1: the BBC tutorial uses the brackets and not arrows
2: it's difficult to imagine an assembly program filled with Arrows and Basic code
Re: left and right brackets on beebem
Post by tricky » Fri Jun 08, 2018 6:35 pm
Brackets are arrows in mode 7
Post by Elminster » Fri Jun 08, 2018 8:44 pm
As tricky said, that is correct behaviour on real hardware. Change to one of the other modes. Mode 7 I find quite hard to write programs in anyway.
The beebwiki covers all the modes
http://beebwiki.mdfs.net/MODE_0
Microboy
Post by Microboy » Sun Jun 10, 2018 1:58 am
mode 8 seems to work. thanks for the help
sweh
Post by sweh » Sun Jun 10, 2018 3:17 am
By default, the Beeb has MODE 0->7. Mode 8 would be the equivalent of mode 0. (There's a theoretical mode 8 documented in the AUG, which is achieved by direct programming of the video chips, but it's not a supported mode).
With the Beeb, Modes 0->6 are bitmap fonts, and so the [ character shows up as a [. Mode 7 is a Teletext character mapped mode, and in that mode the [ shows as an arrow. Similarly the \ character shows as a "1/2" half symbol. However this is just how it looks; it's still the same character.
Rgds
Stephen
Microboy
Post by Microboy » Mon Jun 11, 2018 12:42 am
I do have one more question. how do i save a game to tape or disc?
Post by Elminster » Mon Jun 11, 2018 8:24 am
Assuming a BASIC program. If using an emulator you need to select where the disk is from the menu. In a reall Beeb you would just insert a real disk.
Set to disk, check what is on it and save:
*DISC
*CAT
SAVE "FILENAME"
Microboy
Post by Microboy » Mon Jun 11, 2018 5:37 pm
thank you
