Wanted: ready to run, on Mac & Win, H2testw - SD card test
Post by daveejhitchins » Sat Dec 30, 2017 10:31 am
As most people will know :? I'm not good when dealing with anything that involves the "command line" on Windows or Mac OS!
I need to test a few (lot!) of 1GB Micro SD cards. I'd like to use H2testw, however, it needs compiling. I've tried, honest, but failed miserably :roll:
If someone could compile these for me, Please [-o< I'd be ever so grateful =D> :)
Link to H2testw
Re: Wanted: ready to run, on Mac & Win, H2testw - SD card test
Post by lurkio » Sat Dec 30, 2017 10:55 am
Okay, so this isn't what you asked for, but have you tried installing the Homebrew package manager and then using that to install F3 (a Mac alternative to H2testw)?
I'm bad at manually compiling stuff on the Mac too, and I find that Homebrew is a good way to avoid it!
:idea:
Post by CMcDougall » Sat Dec 30, 2017 12:02 pm
https://www.sdcard.org/downloads/
could use this proggy, it does lots & speed tests 8)
mjforbes
Post by mjforbes » Sat Dec 30, 2017 1:10 pm
CMcDougall wrote:https://www.sdcard.org/downloads/
Can recommend this as well - my DSLR has a habit of seemingly "mangling" SDHC cards to a point where the camera itself and Windows cannot/will not read or reformat them - somehow, this little prog does the trick nicely, and 'revives' the card so it's not chucked away.
M.
"We're happy as fish, as gorgeous as geese, and wonderfully clean in the morning."
Post by daveejhitchins » Sat Dec 30, 2017 2:23 pm
@Col. - I already use that formatter for all my SD cards - But thanks.
@Lurkio - OK, installed HomeBrew OK (I think!) - F3 install was "brew install F3" Did something :shock: - But none of the F3 commands seem to work :oops:
Stuck! Re read everything ](*,)
Post by lurkio » Sat Dec 30, 2017 3:26 pm
daveejhitchins wrote:@Lurkio - OK, installed HomeBrew OK (I think!) - F3 install was "brew install F3" Did something :shock: - But none of the F3 commands seem to work :oops:
What do you get when you do this?:
What do you get when you just enter the command f3read on its own?
Have you tried this instead?:
Post by daveejhitchins » Sun Dec 31, 2017 8:08 am
lurkio wrote:What do you get when you do this?:
/usr/local/bin/f3read /usr/local/bin/f3write
lurkio wrote:What do you get when you just enter the command f3read on its own?
Usage: f3read [--start-at=NUM] [--end-at=NUM] <PATH>
lurkio wrote:Have you tried this instead?:
I'll have a look today - Mrs H allowing :roll:
Post by daveejhitchins » Sun Dec 31, 2017 1:40 pm
Thanks lurkio, sorted :D =D>
