How to convert tape to UEF
vanekp
Re: How to convert tape to UEF
Post by vanekp » Wed Dec 27, 2017 12:12 pm
Lol yes they are in hex its the 4th last block in the file (counting in decimal :wink: ) you can see/hear its shorter than the other blocks.
I Used *OPT2,0 to ignore errors and loaded it in on my BBC can do the same with the uef or csw file on BeebEm.
It them left the missing data at 0's and i then filled that bit in with ? and checked the basic line numbers/length tied up so that it could be listed.
Peter.
pau1ie
Post by pau1ie » Wed Dec 27, 2017 5:54 pm
OK, I recorded it on a faster computer on Windows, and it works. So from this I can learn it helps to have the audio!
Thank you all for your help.
Edit: I uploaded the UEF here.
vanekp
Post by vanekp » Wed Dec 27, 2017 6:40 pm
we all live and learn, and glad you managed to sort it out.
Peter.
vanekp
Post by vanekp » Tue Jan 16, 2018 9:06 pm
Okay I have never tried to convert electron tapes to UEF are they different to BBC (I did not think so)
As when I run makeuef I just get 100's of errors does not matter if I use -w 0 180 or not
i.e.
MakeUEF V2.3.
Command line:
-i Camelot(SuperiorSoftware)(E)[Side1].csw
Date (D/M/Y) and time:
16/01/2018   22:01
Phase shift changed to +0.
Expected baud rate is 1229.
Gap written, length 3.015034 seconds.
Carrier tone written, length 9554 waves.
Baud rate of the preceding data was 1232.028
The following block size is 111
THE DATA BLOCK HAS BYTES FOLLOWING THE CHECKSUM.
DATA BLOCK WRITTEN WITH A BAD CHECKSUM OR NON-STANDARD BLOCK.
1 data blocks written.
BLOCK NUMBER 00 MISREAD.
Security waves written, length 14 waves, as follows:
L,S,S,L,L,L,S,S,S,S,L,L,S,S,
The security waves start with a wave.
The security waves end with a pulse.
Baud rate of the preceding data was 1231.507
Gap written, length 0.0002947846 seconds.
POSSIBLE DROPOUT - THE GAP IS LESS THAN 0.02 SECONDS.
Security waves written, length 13 waves, as follows:
L,L,L,L,L,L,S,S,L,L,S,S,L,
The security waves end with a wave.
Carrier tone written, length 12 waves.
Baud rate of the preceding data was 1235.091
THE FIRST BYTE OF THE NEXT BLOCK IS NOT '*'.
The following block size is 13
2 data blocks written.
MISREAD A BLOCK.
Security waves written, length 145 waves, as follows:
L,L,S,S,L,L,S,S,S,S,L,L,L,S,S,L,S,S,L,L,S,S,S,S,L,L,L,S,S,L,S,S,L,L,S,S,L,L,L,L,S,S,L,S,S,L,S,S,S,S,S,S,L,S,S,S,S,L,L,S,S,L,S,S,L,L,S,S,L,S,S,L,L,S,S,L,L,L,L,L,L,S,S,L,L,S,S,L,S,S,S,S,L,S,S,L,L,L,S,S,S,S,L,L,L,L,L,L,S,S,L,L,S,S,L,S,S,L,L,L,L,L,S,S,L,S,S,L,S,S,L,S,S,L,L,S,S,L,L,S,S,L,S,S,L,
Carrier tone written, length 8 waves.
Baud rate of the preceding data was 1233.423
and with -w 0 180
MakeUEF V2.3.
Command line:
-i Camelot(SuperiorSoftware)(E)[Side1].csw -w 0 180
16/01/2018   22:02
Expected baud rate is 1223.
Gap written, length 3.012653 seconds.
Baud rate of the preceding data was 1561.062
Carrier tone written, length 9552 waves.
Security waves written, length 2 waves, as follows:
L,L,
Baud rate of the preceding data was 1232.048
Gap written, length 0.006190476 seconds.
Security waves written, length 10 waves, as follows:
S,L,S,S,S,S,L,L,L,L,
Baud rate of the preceding data was 1248.113
Gap written, length 0.002154195 seconds.
Security waves written, length 9 waves, as follows:
S,L,S,S,L,L,L,L,L,
Baud rate of the preceding data was 1252.841
Gap written, length 0.00537415 seconds.
Security waves written, length 11 waves, as follows:
Baud rate of the preceding data was 1262.405
Gap written, length 0.01027211 seconds.
The wave looks good to me
and the BBC side worked without a problem
MakeUEF V2.3.
Command line:
-i Camelot(SuperiorSoftware)(B)[Side2].csw -w 0 180
11/01/2018   00:32
Expected baud rate is 1201.
Gap written, length 3.069546 seconds.
Carrier tone written, length 11803 waves.
Baud rate of the preceding data was 1201.134
The following block size is 286
Found :    CAMELOT 00	Checksum ok
Carrier tone written, length 1904 waves.
Baud rate of the preceding data was 1201.132
Found :    CAMELOT 01	Checksum ok
Carrier tone written, length 1924 waves.
Baud rate of the preceding data was 1201.125
Found :    CAMELOT 02	Checksum ok
3 data blocks written.
Carrier tone written, length 1922 waves.
Baud rate of the preceding data was 1201.127
Found :    CAMELOT 03	Checksum ok
4 data blocks written.
Carrier tone written, length 1902 waves.
Baud rate of the preceding data was 1201.126
The following block size is 140
Found :    CAMELOT 04	Checksum ok, last block flag
5 data blocks written.
1 ordinary files written.
Carrier tone written, length 13900 waves.
Security waves written, length 1 waves, as follows:
S,
Baud rate of the preceding data was 1201.161
And one got any tips what I am doing wrong ?
Thanks Peter.
Post by CMcDougall » Tue Jan 16, 2018 10:31 pm
http://www.stardot.org.uk/forums/viewto ... 30#p190758
going by my last one recently,
I think software houses did not care much about the brilliant elk users :(
Myself have found many don't work easily, especially if the beeb version is on sideA & elk on sideB , or even blocks missing at ends of tapes like Quest -SSoft :x
Your wav looks ok, but needs to be at about 75-85% not just 40% peak. (Read my instructions again at start of thread :wink: )
I always use a new player like my Sony hifi stereo walkman fed by batterys, not an old mono player that's had its heads sandpapered for 33+ years and its elastic band is stretched !
Maybe that's why yours says 286 mine 280 for block size.
Does your original wav playback to an elk or beeb? If not could try playing the right channel to the elk or a LR mix to confirm.
Also try sideB (IF it has) or copying the original tape on hifi decks to a good blank TDK D90, then rip from that (as time IS running out for these original crap cheap C15 tapes!)
vanekp
Post by vanekp » Sun Feb 11, 2018 1:43 pm
O forgot to come back on this post.... thank for your advice, yes it seems with electron tapes you need to record it at a higher level was told by preservation.org (when they where alive) to record at around 30% but doing it at a higher level seems to have helped I now managed to copy all of them without a problem, so thanks again.
Peter.
