Acorn ANSI C Release 2
Pernod
Post by Pernod » Wed Nov 01, 2017 11:47 am
Here's Acorn ANSI C Release 2.
Acorn ANSI C Release 2 (1988).zip
(312.4 KiB) Downloaded 57 times
dhg2
Re: Acorn ANSI C Release 2
Post by dhg2 » Fri Mar 16, 2018 7:12 pm
Hello,
I've been trying to get this to work, but I've not been able to get it to compile anything. Here's what's happened when I've tried:
What might I be doing wrong? I've changed the directory to ADFS::disk.$, but there's probably a lot of other stuff I don't know about that you're supposed to do as well.
Is there a PDF version of the manual for this?
- Patrick
Regards,
- Patrick
Pernod
Post by Pernod » Fri Mar 16, 2018 7:18 pm
I've not actually used it, but I'm gonna guess you're trying to write to a read-only floppy.
flibble
Post by flibble » Fri Mar 16, 2018 7:54 pm
dhg2 wrote:What might I be doing wrong? I've changed the directory to ADFS::disk.$, but there's probably a lot of other stuff I don't know about that you're supposed to do as well.
Due to risc os not having file extensions, and the compiler kind of requiring them you have to fake it
imagine a project with the following files on windows/unix
thing.c
thing.h
you need to create a c, h, and o directories so
c.thing
h.thing
o
that should work
flibble
Post by flibble » Fri Mar 16, 2018 8:16 pm
Incidentally release 3 and 5 work on risc os 3.1 too, and I've got scans of the manuals and ADFs
https://4corn.co.uk/articles/acornc3/
https://4corn.co.uk/articles/acornc5/
