MAME: Tube devices
Re: MAME: Tube devices
Post by hoglet » Mon Nov 13, 2017 4:25 pm
Just noticed something a little strange....
Your Client ROM trace doesn't seem to match the disassembly on JGH's site for v1.00:
http://mdfs.net/Software/Tube/ARM/v100.zip
And the SHA-1 sum is different:
dmb@greenhog:~$ wget http://mdfs.net/Software/Tube/ARM/Eval100.rom
dmb@greenhog:~$ sha1sum Eval100.rom
f0b184bb530615daa3fa2f557f1848be30ad3997  Eval100.rom
Where did it originate from?
It's not worth me trying to compare traces until we are running the same ROM!
Can you post it and I'll check it works in PiTubeDirect.
Post by hoglet » Mon Nov 13, 2017 4:34 pm
Ah, it's this one:
https://github.com/hoglet67/b-em/blob/m ... al_100.rom
Brazil version -.005 (8th August 1986)
I'm now slightly confused as to what this is exactly....
But it does seem to work OK in PiTubeDirect.
To make comparing traces easier, is there any chance you could make a new one:
- without any manual edits (yes, I know it will be big!)
- with a single *HELP and nothing else
Pernod
Post by Pernod » Mon Nov 13, 2017 5:47 pm
I didn't make any manual edits, this is what the MAME debugger produces by default. I see I can use noloop to disable loop detection.
The attached is using the same Brazil -.005 ROM, with a single *HELP. I now have 7 ROMs that all vary slightly, some more than others, and all have the same outcome.
It has to be something very subtle.
- If the ROM paging was incorrect it wouldn't start.
- If the RAM was incorrect it also wouldn't start and it even detects the correct amount.
- Maybe how the Tube is mapped from 8bit to 32bit? But wouldn't expect it to get as far as it does if this was the case.
trace_arm005nl.zip
(963.16 KiB) Downloaded 25 times
Post by hoglet » Mon Nov 13, 2017 6:08 pm
Thanks, I'll work with that trace for now.
It looks like it is actually from v100, as the reset vector jumps to 0x3001730
But that's fine, as we have a disassembly for this version.
Pernod
Post by Pernod » Mon Nov 13, 2017 7:25 pm
I tried changing how the device starts, by copying the ROM into RAM instead of paging it, and now it works. This isn't how the hardware works so I still need to find out why it failed before and fix it, but I now know where to look.
Thanks for the help, but no need to continue comparing traces.
Post by hoglet » Mon Nov 13, 2017 8:25 pm
Pernod wrote:I tried changing how the device starts, by copying the ROM into RAM instead of paging it, and now it works. This isn't how the hardware works so I still need to find out why it failed before and fix it, but I now know where to look.
That's interesting.... because we do the same in PiTubeDirect:
https://github.com/hoglet67/PiTubeDirec ... rm2.c#L184
One thing you might like to try is setting rd/wr watch points on the tube data registers:
- 1000004
- 100000C
- 1000014
- 100001C
You should see a trace like this:
Mem Wr watchpoint hit at cdf            : 1000004 = a       R1: Reset message
Mem Wr watchpoint hit at cdf            : 1000004 = d
Mem Wr watchpoint hit at cdf            : 1000004 = 41
Mem Wr watchpoint hit at cdf            : 1000004 = 63
Mem Wr watchpoint hit at cdf            : 1000004 = 6f
Mem Wr watchpoint hit at cdf            : 1000004 = 72
Mem Wr watchpoint hit at cdf            : 1000004 = 6e
Mem Wr watchpoint hit at cdf            : 1000004 = 20
Mem Wr watchpoint hit at cdf            : 1000004 = 52
Mem Wr watchpoint hit at cdf            : 1000004 = 4d
Mem Wr watchpoint hit at cdf            : 1000004 = 53
Mem Wr watchpoint hit at cdf            : 1000004 = 65
Mem Wr watchpoint hit at cdf            : 1000004 = 64
Mem Wr watchpoint hit at cdf            : 1000004 = 50
Mem Wr watchpoint hit at cdf            : 1000004 = 73
Mem Wr watchpoint hit at f3             : 1000004 = 34
Mem Wr watchpoint hit at f3             : 1000004 = 30
Mem Wr watchpoint hit at f3             : 1000004 = 39
Mem Wr watchpoint hit at f3             : 1000004 = 36
Mem Wr watchpoint hit at cdf            : 1000004 = 4b
Mem Wr watchpoint hit at 20000cdf       : 1000004 = 0
Mem Rd watchpoint hit at 28000bb6       : 100001c = 5       R4: Tube Release
Mem Rd watchpoint hit at 8000d86        : 100001c = 80
Mem Rd watchpoint hit at 3000d73        : 100000c = 80      R2: Reset Response - enter language ?
Mem Wr watchpoint hit at 20000d33       : 100000c = 6       R2: OSBYTE A=&87
Mem Wr watchpoint hit at 20000d33       : 100000c = 90
Mem Wr watchpoint hit at 20000d33       : 100000c = 0
Mem Wr watchpoint hit at 20000d33       : 100000c = 87
Mem Rd watchpoint hit at d73            : 100000c = d
Mem Rd watchpoint hit at d73            : 100000c = 3       Mode 3
Mem Rd watchpoint hit at d73            : 100000c = 20
Mem Wr watchpoint hit at 20000d33       : 100000c = 6       R2: OSBYTE A=&EC
Mem Wr watchpoint hit at 20000d33       : 100000c = 14
Mem Wr watchpoint hit at 20000d33       : 100000c = eb
Mem Wr watchpoint hit at 20000d33       : 100000c = ec
Mem Rd watchpoint hit at 20000d73       : 100000c = b8
Mem Rd watchpoint hit at 20000d73       : 100000c = 0
Mem Wr watchpoint hit at 20000cdf       : 1000004 = 17      VDU 23,255,...
Mem Wr watchpoint hit at 20000cdf       : 1000004 = ff
Mem Wr watchpoint hit at f3             : 1000004 = 0
Mem Wr watchpoint hit at f3             : 1000004 = 2a
Mem Wr watchpoint hit at f3             : 1000004 = 7f
Mem Wr watchpoint hit at f3             : 1000004 = ab
Mem Wr watchpoint hit at f3             : 1000004 = e
Mem Wr watchpoint hit at f3             : 1000004 = 38
Mem Wr watchpoint hit at f3             : 1000004 = ba
Mem Wr watchpoint hit at f3             : 1000004 = ff
Mem Wr watchpoint hit at f3             : 1000004 = aa
Mem Wr watchpoint hit at f3             : 1000004 = e0
Mem Wr watchpoint hit at f3             : 1000004 = b0
Mem Wr watchpoint hit at f3             : 1000004 = 1
Mem Wr watchpoint hit at f3             : 1000004 = 80
Mem Wr watchpoint hit at f3             : 1000004 = b6
Mem Wr watchpoint hit at f3             : 1000004 = fc
Mem Wr watchpoint hit at f3             : 1000004 = 78
Mem Wr watchpoint hit at cdf            : 1000004 = 17      VDU 23,255,...
Mem Wr watchpoint hit at cdf            : 1000004 = ff
Mem Wr watchpoint hit at d33            : 100000c = 4       OSBYTE A=&03
Mem Wr watchpoint hit at d33            : 100000c = 0
Mem Wr watchpoint hit at d33            : 100000c = 3
Mem Rd watchpoint hit at d73            : 100000c = 14
Mem Wr watchpoint hit at 20000d33       : 100000c = 6       OSBYTE A=&D9
Mem Wr watchpoint hit at 20000d33       : 100000c = d9
Mem Rd watchpoint hit at 20000d73       : 100000c = a2
Mem Wr watchpoint hit at d33            : 100000c = 0       OSRDCH
Mem Rd watchpoint hit at d73            : 100000c = 24
Mem Rd watchpoint hit at d73            : 100000c = 48      H
Mem Wr watchpoint hit at 20000d33       : 100000c = 6       OSBYTE A=&DA
Mem Wr watchpoint hit at 20000d33       : 100000c = ff
Mem Wr watchpoint hit at 20000d33       : 100000c = da
Mem Rd watchpoint hit at 20000d73       : 100000c = a3
Mem Rd watchpoint hit at 20000d73       : 100000c = 9
Mem Wr watchpoint hit at f3             : 1000004 = 48      OSWRCH H
Mem Rd watchpoint hit at d73            : 100000c = 22
Mem Rd watchpoint hit at d73            : 100000c = 45      E
Mem Wr watchpoint hit at f3             : 1000004 = 45      OSWRCH E
Mem Rd watchpoint hit at d73            : 100000c = 26
Mem Rd watchpoint hit at d73            : 100000c = 4c      L
Mem Wr watchpoint hit at f3             : 1000004 = 4c      OSWRCH L
Mem Rd watchpoint hit at d73            : 100000c = 28
Mem Rd watchpoint hit at d73            : 100000c = 50      P
Mem Wr watchpoint hit at f3             : 1000004 = 50      OSWRCH P
Mem Rd watchpoint hit at d73            : 100000c = 6
Mem Rd watchpoint hit at d73            : 100000c = d       <cr>
Mem Wr watchpoint hit at cdf            : 1000004 = a       Supervisor 1.00 ....
Mem Wr watchpoint hit at cdf            : 1000004 = 75
Mem Wr watchpoint hit at cdf            : 1000004 = 70
Mem Wr watchpoint hit at cdf            : 1000004 = 76
Mem Wr watchpoint hit at cdf            : 1000004 = 69
Mem Wr watchpoint hit at cdf            : 1000004 = 31
Mem Wr watchpoint hit at cdf            : 1000004 = 2e
Mem Wr watchpoint hit at cdf            : 1000004 = 30
Mem Wr watchpoint hit at cdf            : 1000004 = 45
Mem Wr watchpoint hit at cdf            : 1000004 = 78
Mem Wr watchpoint hit at cdf            : 1000004 = 74
Mem Wr watchpoint hit at cdf            : 1000004 = 28
Mem Wr watchpoint hit at cdf            : 1000004 = 36
Mem Wr watchpoint hit at cdf            : 1000004 = 68
Mem Wr watchpoint hit at cdf            : 1000004 = 4a
Mem Wr watchpoint hit at cdf            : 1000004 = 39
Mem Wr watchpoint hit at cdf            : 1000004 = 38
Mem Wr watchpoint hit at cdf            : 1000004 = 29
Mem Wr watchpoint hit at d33            : 100000c = 2       OSCLI
Mem Wr watchpoint hit at d5b            : 100000c = 48      H
Mem Wr watchpoint hit at d5b            : 100000c = 45      E
Mem Wr watchpoint hit at d5b            : 100000c = 4c      L
Mem Wr watchpoint hit at d5b            : 100000c = 50      P
Mem Wr watchpoint hit at 40000d5b       : 100000c = d       <cr>
Mem Rd watchpoint hit at d73            : 100000c = 7f      don't execute
Mem Wr watchpoint hit at 20000d33       : 100000c = 6       OSBYTE A=&87
Mem Wr watchpoint hit at 20000d33       : 100000c = 48
Mem Wr watchpoint hit at 20000d33       : 100000c = b4
Mem Wr watchpoint hit at 20000d33       : 100000c = 6       OSBYTE A=&EC
Mem Wr watchpoint hit at 20000cdf       : 1000004 = 17      VDU 23,255,... as above
Mem Rd watchpoint hit at 20000d73       : 100000c = 12
This might help you see where it's going wrong...
Pernod
Post by Pernod » Mon Nov 13, 2017 10:03 pm
It's now working with the ROM paging, yay! My problem was using 32bit handlers for the RAM, now using 8bit.
Now which ROMs are known to be good? I have 7 different versions.
ROM_SYSTEM_BIOS(0, "100jgh", "Executive v1.00 (6th June 1986)")
ROMX_LOAD("Eval100.rom", CRC(e59e469d) SHA1(f0b184bb530615daa3fa2f557f1848be30ad3997) // JGH
ROM_SYSTEM_BIOS(1, "101jgh", "Executive v1.00 (14th August 1986)")
ROMX_LOAD("Eval101.rom", CRC(d6ab1a06) SHA1(3b16cd35dd1d86932499728336547e37d5222ebc) // JGH
ROM_SYSTEM_BIOS(2, "005jgh", "Brazil v-.005 (8th August 1986)")
ROMX_LOAD("Brazil005.rom", CRC(d294f888) SHA1(5b051d0afad9b46a32801aa5ef262536adf2a921)// JGH
ROM_SYSTEM_BIOS(3, "100h", "Executive v1.00 (6th June 1986)")
ROMX_LOAD("ARM Evaluation System 1.00.rom", CRC(cb29a585) SHA1(15e15c78db34cfa22a83689be0de30704b7a4c67) // huininga
ROM_SYSTEM_BIOS(4, "101h", "Executive v1.00 (14th August 1986)")
ROMX_LOAD("ARM Evaluation System 1.01.rom", CRC(cab85473) SHA1(f86bbc4894e62725b8ef22d44e7f44d37c98ac14) // huininga
ROM_SYSTEM_BIOS(5, "100b", "Executive v1.00 (6th June 1986)")
ROMX_LOAD("ARMeval_100h.rom", CRC(ed80462a) SHA1(ba33eaf1a23cfef6fc1b88aa516ca2b3693e69d9) // BeebEm/huininga
ROM_SYSTEM_BIOS(6, "005", "Brazil v-.005 (8th August 1986)")
ROMX_LOAD("ARMeval_100.rom", CRC(7c27c098) SHA1(abcc71cbc43489e89a87aac64e67b17daef5895a) // b-em
I've tried most of the available software on the 6 ARM discs and looks good so far. Is there anything else I should be using to give it a thorough test?
Pernod
Post by Pernod » Fri Dec 08, 2017 1:51 pm
Something a little unusual ...
Post by jgharston » Fri Dec 08, 2017 10:01 pm
hoglet wrote:Just noticed something a little strange....
There are several versions of various versions(!) of the ARM Client ROM. For instance, the A500 we were looking at at ABUG is also Brazil 005/Supervisor 1.00, but a different "version". It looks very much like people built their own ROM set by including whatever modules they wanted. I think I now have three 005/1.00s, a 0.99 and two 1.01s.
Pernod
Post by Pernod » Thu Sep 20, 2018 7:30 pm
I'm playing with the ROMs for the Torch Communicator that are for the Master (ABM) and BBC 1770 (ABW), but can't get them to read a floppy. Has anyone used these ROMs on real hardware? Probably an emulation issue, but wondered if I need to do something different for the 1770 controllers.
The CBL and ABL ROMs work fine with the 8271, just 1770 variants I'm having trouble with.
This is MAME running a Master with Torch Communicator and ROM MCP v1.22 (ABM).
Post by jgharston » Fri Sep 21, 2018 12:13 am
I had Torches working back at Uni in the late 1980s, but they all had 8271 floppy hardware.
Pernod
Post by Pernod » Tue Sep 25, 2018 2:32 am
Been looking at the ReCo6502 and now have it running with either a 65C02 or 65C816.
Configuring the clock with the soft options also works, but still to implement the configuration links and some testing.
