Acorn Art Thread
Re: Acorn Art Thread
Post by lurkio »
pixelblip wrote:
Mon Mar 16, 2020 7:40 pm
Well done Lurkio and CRB.
Mainly well done to ctr.
I did see a problem in this. If you turn these gifs into BBC pics how you gonna know what is colour flashing and what isn't? You could save the frames of course and play 8 back in sequence but it's not the same as saving a picture with the flashing colours and animating it.
But that's exactly what ctr's program does and that's why it's so brilliant: it saves a picture with flashing colours and then his BASIC program $.ANI animates it!
For example here's one of your animated GIFs converted back to flashing-colour MODE2 BBC format with img2beeb.exe and then animated using $.ANI. Press the zero key to select the pic:
:idea:
EDIT: Admittedly the animation there looks a little bit jerky or cyclic for some reason..?
pixelblip
Post by pixelblip »
How on earth did you work that out CTR. That is genius. I take my hat off to you.
We sure have some talent here don't we......all of us together.
Post by lurkio »
Ooh, hang on -- I'm getting consistent crashes whenever I try to use img2beeb.exe to convert the bus animated GIF:
(Nostradamus and Summer Meadow convert without problems.)
ctr
Post by ctr »
I didn't notice you'd got it working until I'd nearly finished changing it to run on .net core. So in theory it should run natively on macOS now. Note that the instructions are quite different.
The animated bus works fine using the old version on Windows and using the new version.
Post by lurkio »
ctr wrote:
Mon Mar 16, 2020 11:08 pm
I didn't notice you'd got it working until I'd nearly finished changing it to run on .net core. So in theory it should run natively on macOS now. Note that the instructions are quite different. The animated bus works fine using the old version on Windows and using the new version.
Yep, the new version works perfectly for me on macOS. Superb!
=D> =D> =D>
EDIT: Actually, I'm now getting a crash on macOS whenever I try to convert Runner.GIF:
$ dotnet run
/Users/xxxxx/xxxxx/img2beeb/gifs/run.gif
Process terminated. Assertion failed.
   at img2beeb.Program.ConvertGifToMode2(String sourceFile, String outputPath) in /Users/xxxxx/xxxxx/img2beeb/src/Program.cs:line 95
   at img2beeb.Program.ConvertGifFolderToMode2(String source, String outputPath) in /Users/xxxxx/xxxxx/img2beeb/src/Program.cs:line 241
   at img2beeb.Program.ExceptionalMain(String[] args) in /Users/xxxxx/xxxxx/img2beeb/src/Program.cs:line 249
   at img2beeb.Program.Main(String[] args) in /Users/xxxxx/xxxxx/img2beeb/src/Program.cs:line 256
Post by lurkio »
lurkio wrote:
Mon Mar 16, 2020 11:27 pm
Looks like pixelblip applied a sneaky filter to the animated GIF that makes it impossible to auto-convert back to MODE2 format, even for ctr's amazing program!:
[-X
pixelblip
Post by pixelblip »
Yes Lurkio I got caught out there! That is the first time I have done that which was a bit naughty. Call it artistic license.
The glow effect looked so good I thought I'll put it in. Some of the animations use a few extra tricks ( the runner did ) so I bent the rules a bit there. Let's consider it a slap on the wrist ok and I promise not to do it again! :lol:
pixelblip
Post by pixelblip »
I hope this will make up for bit. Here's one I finished.
Galatic traveller
Post by lurkio »
pixelblip wrote:
Tue Mar 17, 2020 8:47 pm
Galatic traveller
Amazing! Here it is, animated in JSBeeb, together with some of your other recent works:
:idea:
fuzzel
Post by fuzzel »
Nice! The WIZ one would look good as a loader for my game.. I might just nick it!
Only joking of course..
pixelblip
Post by pixelblip »
The persistence of panic buying
pixelblip
Post by pixelblip »
You use that wizard pic for your game fuzzel if you want to. Art is there to be used and abused!
pixelblip
Post by pixelblip »
Awakening
pixelblip
Post by pixelblip »
Awakening
pixelblip
Post by pixelblip »
Extra Extra
pixelblip
Post by pixelblip »
Phenomenon II
pixelblip
Post by pixelblip »
Ufo
pixelblip
Post by pixelblip »
Herd immunity
pixelblip
Post by pixelblip »
Precipice
pixelblip
Post by pixelblip »
Half Life
pixelblip
Post by pixelblip »
Aperitif
pixelblip
Post by pixelblip »
I wonder whether to post art up that could be controversial and with dark humour.
Satire and sarcasm is not always palatable...but then art has always challenged the world around us good or bad....for better or worse.
Lardo Boffin
Post by Lardo Boffin »
pixelblip wrote:
Tue Mar 24, 2020 7:26 pm
Maybe create another ‘dark humour’ thread? People can then always not look at it.
Adventure Language on GitHub
Atom, issue 5
Elk
Post by lurkio »
Here are some more of pixelblip's animations, converted and displayed with the latest versions of ctr's programs:
:idea:
pixelblip
Post by pixelblip »
Well for now I won't post it. Perhaps we don't need continually reminding.
pixelblip
Post by pixelblip »
Fish
pixelblip
Post by pixelblip »
Perception
pixelblip
Post by pixelblip »
Seashell
pixelblip
Post by pixelblip »
Green Swimmer
pixelblip
Post by pixelblip »
You can't convert that Lurkio!
I had to use jiggery pokery. A bit of a cheat for now but it spices it up a bit. The colour cycling is BBC micro.
Really what I need is to be able to use mode 2 sprites....
Return to “off-topic”
