DataCentre RAMFS 1.04 Issues
Post by hoglet » Sun Feb 26, 2017 7:35 am
Hopefully Mark (RetroClinic) or someone else with source access to RAMFS can help here.
A friend has just bought a DataCentre and was trying to boot Panos from RAMFS (so it could eventually be installed on ADFS).
Panos doesn't boot from RAMFS, and complains of a corrupt system image.
After a bit of debugging, it appears RAMFS 1.04 doesn't correctly load files longer that 64KB; the highest byte of the length is ignored.
Is this a known issue, and is there anything we can do to get it fixed?
Re: DataCentre RAMFS 1.04 Issues
Post by jgharston » Sun Feb 26, 2017 2:27 pm
hoglet wrote:After a bit of debugging, it appears RAMFS 1.04 doesn't correctly load files longer that 64KB; the highest byte of the length is ignored.
Yes, this is a known issue as RAMFS is based on DFS 0.90 which doesn't load files longer than 64K. It's on my list of things to look at.
