On the subject of horizontal software scrolling games
Post by tricky » Sat Nov 19, 2016 9:15 pm
At this point, this should probably be on RetroSoftware in a software development thread!
Carrying on from "Super Mario on the BBC?" viewtopic.php?f=1&t=12020&start=90 I thought I would take another look at Scramble. I do like a blast every now and then, but the beeb versions while good, either scroll too fast or scroll at an uncomfortable frame rate.
I had a quick look around for a map to see how big it was and how much memory it would require and to see if it would even be feasible. The only map I could find was not the arcade original, so I got sidetracked creating one!
I discovered that the game should scroll one mode 1 or mode 4 pixel per frame, not two as I had though, so mode 5 is probably out, leaving mono probably.
I got a video of it being played in mame, then used VirtualDub to resize and trim it so that it exported the right hand 4 pixels of each frame as thousands of TGAs. I was hoping to just grab the right pixel and stitch them together, but the video wasn't completely stable.
The dashes are where a non scrolling star appears, the streaks are the flying saucers and the little blobs the fireballs.
Attached is the code that I used to make the attached map - nothing to run on the beeb yet, but hopefully someone will find it interesting.
I also fixed the broken Tga::compare function (it was OK before it got optimised to memcmp!). tga2equb is the stitcher (remember I said I usually start with that code and repurpose it).
How the stitcher works.
The stitcher works by looking up from the bottom right pixel of the map so far, the bottom of the magenta at the start of the map and then scans up until it finds another colour. I then copy a 4x8 pixel block with the colour change in the middle on the right. From the same height on the four pixel wide strip that I am trying to append, I copy the same 4x8 section. To deal with the points where the palette changes, I replace the colour below the line with red, the ground line green and everything else blue (or some order!).
Using the same method I colour the copy of the new bit of strip and then try to match them up, first trying 1 new pixel, then none, and finally 2.
Once I find the overlap, I was just copying the new bit, but that means on the next check the bits under the line and the lines will not match each other in the map, so I changed to copying the whole new strip.
My plan for the next section of map it to search for the brick floor and later ceiling and use those to fit the new strip.
Scramble.zip
(7.47 KiB) Downloaded 61 times
Re: On the subject of horizontal software scrolling games
Post by oss003 » Sat Nov 19, 2016 9:48 pm
Scramble was also one of my favourites in the 80's :D
Looks like the background is build with just a few blocks, these are the graphics of the game:
I also found a site with a lot of ZX Spectrum maps: http://www.zx-spectrum.cz/maps-direct.php
Post by tricky » Sun Nov 20, 2016 8:07 am
Thanks.
I wonder why mame thinks the vertical resolution (with the monitor turned portrait) is 768, I've seen it a few times, but usually all the graphics have their pixels elongated.
I've seen some of those maps before, but never found the index page. The spectrum version would be a good start for a memory saving version as someone else has already shrink everything to fit the reduced horizontal (compared to some home micros) and vertical resolutions.
Post by tricky » Sun Nov 20, 2016 9:40 am
Added some code to tga2equb to spot the colours used in bricks and got to the end of the video, need a better video or to get to the end myself!
I don't think I had noticed that you can see starts through the gaps between the bricks.
Scramble.zip: No beeb software. tga2equb was copied from hscroll, which must have been an old version as BLACK was actually transparent white! Added write region. Warning Tga::operator = is bitwise!
EDIT: I thought it would be easier to fit the bottom instead of finding the bricks, but 4 pixels isn't enough for this, so fixed the few issues manually!
Map updated.
Scramble.zip
(4.71 KiB) Downloaded 57 times
Post by Rich Talbot-Watkins » Sun Nov 20, 2016 6:06 pm
How do you imagine this working on the Beeb then? Mode 1, and just plotting changed edges of the landscape? Haven't done the calculations but my instinct is that wouldn't work quickly enough, along with all the sprites which would need continually updating...
Post by tricky » Sun Nov 20, 2016 7:53 pm
I'm not sure if it would work, but probably mode 4 :(
At 16x8 tiles, there are 117 including sprites in the parts of the map that I have converted so far without the extra combinations of what is next to them.
The bricks would have to be changed to solid colour, the sprites could be part of the landscape and then maybe patched as blank or BIT when moving or destroyed.
After doing the mario level, I'm pretty sure it could be drawn, but the sprites are definitely a worry and mode1, would need to be done more like I did the ground in the mario demo as well as going to 224x208 (play area is 224x200) unless the score and status were vertical :shock:.
For mode 1, some of the micro detail in the landscape tiles would probably have to go (maybe an industrial theme).
e.g. There are several types of each diagonal, which give nearly the same outline.
I mainly though that it was interesting to post as there was no proper scramble map and the way of mapping it seemed novel :D
Post by tricky » Mon Nov 21, 2016 8:22 pm
In mode 4, it requires about twice as many tile pairs, so double the tile memory.
Mode 1, it is about the same number of pairs as mode 4, but as there are only four copies, it is about the same memory as the SMB level.
I have included the rockets, fuel and whatever the other things are, so it would draw as the attached image, but with 4 colours.
The worst case frame is less than half the worst case mario frame, so mode 1 seems feasible.
The two pages wide do add a twist, but I like the idea of not having to handle the wrapping when drawing sprites.
Because there would be twice as many lda/sta sets (columns) in mode 1, either the map would need decoding differently or the improved way of handling things scrolling on and off would need implementing.
As I think there is only ever one target per column, it should be possible to swap which character is being scrolled in place.
The map is at least 3 times longer, so SWR would probably be required.
What do people think? Still no promises :roll:
Pernod
Post by Pernod » Mon Nov 21, 2016 8:51 pm
You're map ends at the point I used to die :lol: How did Rocket Raid and Moon Raider do it, or were their maps shorter?
Post by tricky » Mon Nov 21, 2016 9:30 pm
I'm not sure how accurate their maps were, but one scrolled too fast and the other only scrolled every few frames.
Post by tricky » Tue Nov 22, 2016 8:55 pm
Four colour map of attached level would be 9K, so probably 10K by the time the rest is mapped, 5K more for the tiles and 12K + status area for the screen.
Since the game force scrolls, a bit more data could be embed in the map to reduce the work of repacking the draw code, which would probably push into SWR, but that would leave plenty of room.
EDIT: Using a map more like RichTW was suggesting on the SMB thread, you could probably half the 9K.
Post by oss003 » Wed Nov 23, 2016 5:47 pm
Hi Tricky,
just had a look at the F14-Tomcat map. I have converted this game to the Atom and 1 level is 'only' $800 bytes.
The background even has parallax scrolling. I know it's a vertical scroller but the size of a level isn't that big.
https://youtu.be/KDU-Wqjm0ak
Post by tricky » Thu Nov 24, 2016 7:39 am
Nice one Kees that looks like it would go nicely in the virtical shooter framework I am doing over at RS. At 2k per section and 4 sections totaling less than the scramble map, it is about the same screen lines per byte, but does have rather more detail ;)
I think the scramble map could probably be reduced down to about 3k, but it needs to be stored to make assembling the draw code quick enough to be done in the spare time from two 50fps frames.
I might try to code something up tonight.
Kees, did you have a go at the stars? I must check the Atom screen memory layout, as I think it might even be easier on the Atom.
Post by oss003 » Fri Nov 25, 2016 5:32 pm
I'll have a look at the stars program.
The Atom screen memory map is much easier to use than the BBC screen memory map.
8000 - 8001 - 8002 ........ 801F
8020 - 8021 - 8022 ........ 803F
97E0 - 97E1 - 97E2 ........ 97FF
So 32 bytes per line and 192 lines per screen.
Time for an Atom demo ......... ;)
Post by tricky » Fri Nov 25, 2016 6:32 pm
That's great, only beaten in my mind by having all the bytes in vertical columns 256 bytes deep.
You won't even need half the stars code then, which won't save many CPU cycles, but will save some space.
Post by oss003 » Fri Nov 25, 2016 9:57 pm
Yep, stars is working ....... :)
https://youtu.be/FwW7AlomENI
Post by tricky » Sat Nov 26, 2016 8:38 am
It's a bit hard to tell from that video ;)
If you make it 1280x720p50/60, YouTube will keep the 50/60 Hz. It doesn't need to fill the area, so you can still keep the steam acceptable.
Post by oss003 » Sat Nov 26, 2016 9:01 am
Which program are you using to record the video because I use CAM Studio but the recorded framerate is only 12 frames/sec at a resolution of 518 x 433??
Post by tricky » Sat Nov 26, 2016 10:08 am
I usually use the video feature in beebem, but also use virtual dub on windows to capture an area of the screen, having set the desktop rate to 50hz for b-em.
I would have thought that any emulator could be persuaded to write out a stream of PNGs out similar, which can then be converted to a video- soundtrack separate.
Post by oss003 » Sat Nov 26, 2016 10:56 am
Wouter Ras his DOS emulator had this option but Atomulator not.
IIRC David Boddie added this feature to Elkulator so maybe it can easily be added into Atomulator, I'll have a look.
@David, did you finish this project?
http://www.boddie.org.uk/david/www-repo ... 01-23.html
Post by davidb » Sat Nov 26, 2016 12:07 pm
I couldn't figure out the palettes to use with B-Em and Arculator. :( It may be a lot simpler with Atomulator if it is like Elkulator. :)
Post by oss003 » Sat Nov 26, 2016 12:09 pm
Hi David,
The Atom has a static palette and Atomulator looks like elkulator.
Are the sources available?
Post by davidb » Sat Nov 26, 2016 1:15 pm
All my commits can be found in a Mercurial repository. I would guess that you would make changes to the video.c file in Atomulator that I made to the ula.c file in Elkulator. I dump raw video and audio data to files that I process afterwards because I found that compressing individual frames was quite processor-intensive.
Post by tricky » Mon Dec 12, 2016 9:42 pm
Just a little audio test ;)
scrambl.zip
just the intro then silence
(1.89 KiB) Downloaded 67 times
Post by oss003 » Wed Dec 14, 2016 9:52 pm
Sounds good tricky, is it a sample?
Post by tricky » Wed Dec 14, 2016 11:13 pm
No, the same "music" player as in the last few demos and Frogger.
Only uses first two tone channels:
ALIGN &100
.VOL_MACROs : .track2 : .track3 : EQUB 0
.VOL_MACRO0 : EQUB &19, 0
.VOL_MACRO3 : EQUB &19, &28, &17, &19, &28, &17
.VOL_MACRO4 : EQUB &19, &28, &27, &26, &15, 0
.VOL_MACRO2 : EQUB &19, &28, &17, &19, &28, &17
.VOL_MACRO1 : EQUB &19, &28, &27, &26, &25, &24, &23, &22, &11, 0
.track0 EQUB SET_SND_LEN + 24 * SND_LEN_DIV, SET_VOL_ENV + (VOL_MACRO1 - VOL_MACROs) * VOL_ENV_DIV, 3, SET_SND_LEN + 16 * SND_LEN_DIV, SET_VOL_ENV + (VOL_MACRO2 - VOL_MACROs) * VOL_ENV_DIV, 3, 0, SET_VOL_ENV + (VOL_MACRO3 - VOL_MACROs) * VOL_ENV_DIV, 3, SET_SND_LEN + 8 * SND_LEN_DIV, SET_VOL_ENV + (VOL_MACRO4 - VOL_MACROs) * VOL_ENV_DIV, 2, 3, 1, 3, 2, 3, 2, 3, 1, 3, 2, 3, 2, 3, 1, 3, 2, SET_VOL_ENV + (VOL_MACRO1 - VOL_MACROs) * VOL_ENV_DIV, 1, 0, END_TRACK ;; 31 31 bytes
.track1 EQUB SET_SND_LEN + 24 * SND_LEN_DIV, SET_VOL_ENV + (VOL_MACRO1 - VOL_MACROs) * VOL_ENV_DIV, 2, SET_SND_LEN + 16 * SND_LEN_DIV, SET_VOL_ENV + (VOL_MACRO2 - VOL_MACROs) * VOL_ENV_DIV, 2, 0, SET_VOL_ENV + (VOL_MACRO3 - VOL_MACROs) * VOL_ENV_DIV, 2, SET_SND_LEN + 8 * SND_LEN_DIV, SET_VOL_ENV + (VOL_MACRO4 - VOL_MACROs) * VOL_ENV_DIV, 4, 2, 3, 2, 4, 2, 4, 2, 3, 2, 4, 2, 4, 2, 3, 2, 4, SET_VOL_ENV + (VOL_MACRO1 - VOL_MACROs) * VOL_ENV_DIV, 3, 0, END_TRACK ;; 31 31 bytes
.snd_reglo EQUB 0, &01, &0A, &02, &04
.snd_reghi EQUB 0, &15, &1F, &19, &2A
The volume macros could really do with a tweak - auto converted mostly from an AY-3-8910 .VGM
It's about 100 bytes, but could be tweaked some more.
DemoTunes.zip
four tunes - auto converted - still needs work
(9.57 KiB) Downloaded 72 times
Post by tricky » Fri Dec 16, 2016 7:35 am
Last batch of auto converted tunes for now.
I need to add splitting them into sections as the current system has a limit of 255 bytes per channel.
MoreDemoTunes.zip
(8.82 KiB) Downloaded 70 times
Post by tricky » Wed Apr 04, 2018 7:40 pm
I converted my simpler maps to tiles for software scrolling, seems positive:
You can see them in The Bank Holiday thread.
stage0 4 tiles (the flat bit you start on when you start a new life.
stage1 57 tiles
stage2 101 tiles
stage3 63 tiles
stage4 10 tiles
stage5 15 tiles
stage6 10 tiles
Tiles here are 8x8 blocks that allow that pair of adjacent 4x8 blocks to scroll efficiently (as my SMB demo below)
http://youtu.be/cvoTZyCKWhU view in 720p+ to get 50Hz video.
Each "tile" requires 16 * 4 bytes, stages 1-3 share similar tiles, as do stages 4-6, but stages 1-3 could use far less combinations.
Post by tricky » Sun Apr 15, 2018 4:48 pm
By changing the wiggly landscape to horizontal, vertical and diagonal lines, I have it down to 31 tiles for all levels.
This means 1KB for landscape tiles and the levels total less than 4KB:
0: 7 bytes (one screen wide flat section that you start a new ship on).
1: 910 bytes
2: 1264 bytes
3: 747 bytes
4: 674 bytes
5: 187 bytes
6: 80 bytes
With 16KB for arcade resolution MODE 1, that leaves plenty for gameplay, sprites and drawing code (enough to trade for drawing speed if necessary).
