US BBC micro restoration - help (and PSU) needed
Post by steve3000 » Sun Aug 28, 2016 1:43 pm
I picked up my first ever American-spec BBC micro a few weeks back and finally had some time yesterday to start exploring it. It's in need of some serious repair - so I'm starting a thread, in the hope that one day I'll get this up and running :)
Thankfully I knew about the condition before purchasing - this computer was purchased by the previous owner in the early 90's with a view to using it as a second computer, but he had 'problems' with the PSU. He could not recall what the 'problems' were (I'd guess possibly just conversion to UK voltage?) but apparently it needed to be replaced, which never happened, so this became a donor machine to keep his other BBC running until the late 90's - hence the missing ICs. He's not seen the PSU has since the early 90's and suspects it was binned at the time. :(
Time for some 'before' pictures.
On arrival, at first glance it looks to be in great condition:
Outside
Apart from some missing ICs, at a glance, the inside kindof looks OK...
Inside
...until you take a closeup look around the TV modulator!
Closeup
The corrosion-like mess in the third picture looks very concerning, but having washed and scrubbed the PCB yesterday I suspect this is actually the result of the Beeb having been used as a mouse-toilet for the last few years! :shock: In fact, after cleaning there doesn't appear to be too much track damage, but the modulator may have to go. More pics of the cleaned machine, later today.
For now, I need some help - does anyone have details and schematics of the US beeb? In particular what changes are needed to convert back to UK spec? (so I can check if this has been done - but as it still has the US operating system chip, I guess not?).
Also, I'm fairly certain I can get hold of missing chips (pics from Chris' Acorns should help identify these) - but I'm more worried about the PSU and what can be done to source a replacement, because I'd doubt anyone has a spare US beeb PSU lying around... Any thoughts?
Re: US BBC micro restoration - help (and PSU) needed
Post by daveejhitchins » Sun Aug 28, 2016 1:52 pm
The power supplies are universal, in that there's a 115V link to make for that Voltage. Contact Mark, at Retroclinic, he'll have a spare power supply. He may have some/all of the ICs you need too - and maybe a replacement modulator.
The fun will start when you have everything assembled and turn on for the first time . . . Good luck and don't forget to keep everyone undated with your progress.
Post by steve3000 » Sun Aug 28, 2016 2:47 pm
daveejhitchins wrote:The power supplies are universal, in that there's a 115V link to make for that Voltage. Contact Mark, at Retroclinic, he'll have a spare power supply. He may have some/all of the ICs you need too - and maybe a replacement modulator.
Hi Dave, I had hope that was the situation, but unfortunately not. The US Beeb PSU had a different casing design which forms part of the rf shielding that encases the pcb.
See here: http://chrisacorns.computinghistory.org ... BBCUSC.jpg
Unfortunately the original beeb PSU just doesn't fit (I've tried :() and if it did, it would be open on the right hand side exposing the live psu components.
Post by daveejhitchins » Sun Aug 28, 2016 3:00 pm
steve3000 wrote:but unfortunately not.
:oops: Ooops! . . . What do I know . . . Mark may be able to help, anyway?
Post by steve3000 » Sun Aug 28, 2016 3:31 pm
daveejhitchins wrote::oops: Ooops! . . . What do I know . . .
Haha, well I had assumed the same too, and had got a far as pulling the psu and most of the ICs out of my issue 3 beeb to try on the US Beeb, when I noticed the problem!
I'll rig up a bench supply to test the US Beeb some time later this week, but will drop Mark a line in case he had some ideas, and still hope to find an original US PSU as a long term solution... :)
Post by steve3000 » Tue May 29, 2018 8:47 pm
Well fast-forward almost two years, and I now have one of these: viewtopic.php?f=41&t=5594&p=203516#p203516
...so time to resurrect this resurrection thread :)
First a comparison between the American Beeb PSU (left) and the UK Beeb PSU (right):
Post by steve3000 » Tue May 29, 2018 8:53 pm
As you can see from the photo at the top of the thread, the insides of this US Beeb were a little nasty, having been used as a mouse-toilet for several years!
I cleaned the PCB up back in 2016, with a nice soak in hot soapy water and a good scrub, but forgot to post the result, so here it is:
And close-up:
But we're still missing 4 important ICs: 6502, 6522, 6845 and VidProc
Post by steve3000 » Tue May 29, 2018 8:57 pm
After fitting the American Beeb PSU, and a quick loan from my working issue 7 beeb - we have all the missing ICs and a source of power :D
I couldn't find a really clear picture of an American Beeb online (at least not one where I could easily read the IC numbers!), so hopefully this will fill the gap:
Only one thing left to do (after fitting the 0v cables and keyboard)... Power on!
VectorEyes
Post by VectorEyes » Tue May 29, 2018 9:09 pm
The suspense!... :)
Post by steve3000 » Tue May 29, 2018 9:09 pm
So first thing I did, was to switch on without a monitor connected, as I didn't have one nearby at the time...
And Brrrrrr-BEEEP! :D :D :D
It works! =D>
...or at least it worked...briefly...!
Plugging a monitor in revealed the following:
Not bad I guess for the first time powered up in 25+ years (this computer was used as a donor computer in the 90's when previous owner had issues with the PSU - hence missing ICs, but it may also have had fault(s) at the time...).
Looks like a RAM fault with Bit 6 of the upper 16kb, but what could be causing the instability of display in MODE 7 (inverted colour and raster-bar background lines)? Other modes looked fine, up to the start of the upper 16kb, when partly broken vertical lines were present - indicating the bit 6 issue, but no background effects...
Anyhow, the computer no longer functions :( sadly it only booted up 3 times, and now gives a long Beeeeeeeeeeeeeeep of doom. Possibly relating the above memory issue or further issues?
Post by tricky » Tue May 29, 2018 10:47 pm
Might it have had its ULA swapped at some time?
Does it even have/need the invention mod?
Post by steve3000 » Wed May 30, 2018 6:28 am
Good question. Fitted a ULA to get it running.
No idea if it has or needs the mod - pcb is a different layout which might make it difficult to tell, and dates from 1983, if that helps? What do I need to look for?
Re: US BBC micro restoration - help needed
Post by steve3000 » Wed May 30, 2018 10:00 am
Also, does anyone know of any fault-finding information for the US Beeb?
The PCB layout is completely different, along with the IC numbering and link numbers, and very few chips are socketed - similar to issue 7 beebs. So if there's a list somewhere of US Beeb IC numbers or link numbers, that would be really useful.
I'm assuming the circuit itself is pretty similar, if not identical, given that it runs normal Beeb software...(at least I'm hoping it will, when it is working!?).
Post by tricky » Wed May 30, 2018 1:05 pm
Some of the ULA models have inverted output compared to another, but I don't know which are which. I believe the mod is to flip the invert signal coming in, but I could be completely wrong about all of this.
I think my"debug OS" room image would still work, but I don't know how the RF and composite encoders in a us beeb will like pal 50p timings. I can't find the link, but if you can burn an eprom, it displays different modes while playing sound and toggling the cassette relay and LEDs for the first few seconds. It's most useful for spotting dodgy ram chips.
Post by 1024MAK » Wed May 30, 2018 1:42 pm
More info on the Video ULA / Videoproc here.
flynnjs
Post by flynnjs » Sun Jun 03, 2018 9:48 pm
I know for a fact the ROMSEL circuitry is different to a regular beeb as
I found when repairing my German Beeb (same as a US Beeb).
I was unable to find a schematic. I guess it would be fairly easy to at
least make a IC number translation table for the 90+% which is the
same as a UK Beeb?
Post by steve3000 » Tue Jun 05, 2018 10:31 pm
same as a UK Beeb?
Ah, that makes sense - I've already started a list of ICs and links, mapping them back to those on an original Issue 7 beeb - most of the ICs are easy, but the links are more challenging! In fact I think the MODE 7 issue I have may be due to incorrect link settings for the VidProc, but I can't find what the links should be anywhere. I've tried looking at all the photos of US beeb PCBs I can find online, but none are high enough resolution to see all the links and determine their positions.
Do you have a high resolution picture of your working German beeb PCB with links in place? This could be really useful. [-o<
Post by 1024MAK » Wed Jun 06, 2018 10:43 am
It's likely that 95% of the circuitry of a USA Beeb is the same as a U.K. Beeb.
If you assume the above, you could printout a A3 (or larger size if you can) copy of the U.K. Beeb schematic, then use a multimeter on the continuity range, Mark each connection on the schematic as you go. Of course, this will not be totally accurate if there are extra connections...
This of course would take a long time. So you may want to start off by tracing the connections for the links first.
flynnjs
Post by flynnjs » Sun Jun 10, 2018 7:53 am
It may be that this PCB is only laid out for later versions of Vidproc just
like the UK beebs that had the "hidden" wire on the underside.
I'll take one when I get chance.
Post by klintworth » Tue Jun 12, 2018 5:31 pm
Here's a photo of a Canadian Beeb motherboard. I swapped it out with an issue 4 UK board which is working well in the North American case with 115V power supply. Hope this may help! Paul :D
BBC B Issue 4, BBC B UNB09 Issue1 (USA), Electron, BBC Master Compact, A7000+(Castle Peak Performer)
Post by klintworth » Tue Jun 12, 2018 5:39 pm
And here's a photo of the UK motherboard in the North American case with 115V power supply. All working well! :D
Post by klintworth » Tue Jun 12, 2018 5:50 pm
And I put the speech ROMS in the UK motherboard - no Kenneth Kendall, it speaks with an American accent! :lol:
KenLowe
Post by KenLowe » Tue Jun 12, 2018 8:46 pm
Those are impressive GND wires!
Post by klintworth » Tue Jun 12, 2018 9:53 pm
Maybe big GND wires to do with all the shielding
Post by steve3000 » Tue Nov 20, 2018 10:42 pm
Still not fixed my US Beeb...
However, I was recently forwarded some scans of a 9-page document about how to prepare re-imported US spec BBC computers back to UK spec. Great to see some original documentation mentioning some of the differences between the UK and US spec. Shame there is no circuit diagram though!
See attached. :D
Interesting to see this was prepared by Geryhound Marketing Ltd. - perhaps they were involved in the re-importing of these back to the UK?
US_UK BBC Configuration Notes v1.0.zip
(2.67 MiB) Downloaded 18 times
Post by steve3000 » Wed Nov 21, 2018 11:07 pm
Some more internet searching today brought up some information on the US beebs from the 8bs site... As well as some pictures of a US beeb, there is an advert from Greyhound Marketing, selling these unused BBC computers at £150 each! The advert is not dated, but the scan of the configuration document I posted above mentions the Nov 1991-Feb 1992 RS catalogue, so this would place those converted US beebs on sale around late 1991...
I think I do recall seeing an advert like this around that time, but dismissed it because it sounded a bit odd that someone would be selling unused beebs 10 years late... And as I would have just got my first Archimedes around then, I wouldn't have been looking too much for 8bit hardware at the time...
