Pi-based Co-Pro on the cheap - 100MHz 6502 for £10? (now 290MHz)
- BeebMaster
- Contact:
Re: Pi-based Co-Pro on the cheap - 100MHz 6502 for £10? (now 274MHz)
I tried that already (see "workaround" waffle above) but it doesn't quite work:
You can't get past it printing the first four characters of the error message: However, if you start BASIC first: It does work, and I can start ARMBASIC from the additional command I added: 6502 BASIC has been copied at &8000 But, after this it's OK because the next CTRL-BREAK does the "This" bit again, and pressing BREAK gets back to the Supervisor prompt (or ARMBASIC in my hack) so any program already in Native ARM RAM isn't overwritten.
The hang on "This is not a language" looks like a a bug (very likely a missing transition from the tube state machine):
https://github.com/hoglet67/PiTubeDirec ... -isr.c#L96
I created a github issue for it a couple of days ago:
https://github.com/hoglet67/PiTubeDirect/issues/73
I'm mid-way through a bout of decorating, so I'm not going to be able to look at this for a few days.
An out of nowhere question, is there an ARM assembler with VFP available for the co-pro? Even something written in BASIC would work well enough for what I need.
I'm trying to port over some code I did for RISC OS using the inline assembler. I don't want to cross-assemble from my Linux machine, I want to assemble on the M128 itself.
Master 128 with DataCentre and RPi co-pro.
RPi B+ & 3B+ both running RISC OS.
Poorly A4000 (battery damage, partially repaired).
- BeebMaster
- Contact:
I've just been looking at the BASIC source, if we alter the value of VARS in /hdr/Workspace from 8700 to, say, F800, this should move PAGE up to &10000. However I can't compile it:
pi@raspberrypi:/media/BMNFS/BBC/32-Bit/BASIC Source ISW Dev/BASIC $ make
Makefile:43: AAsmModule: No such file or directory
make: *** No rule to make target 'AAsmModule'. Stop.
- BeebMaster
- Contact:
I think I've got to the bottom of the filing system error when loading ARM BASIC:
File server monitor comes in very handy. On the face of, it looks like *BASIC is being issued after ARM BASIC is loaded:
However, this isn't what's happening at all: The command line interpreter isn't correctly truncating or flushing the buffer, so "BASIC" is in fact left over from "*DIR ARMBASIC". This only seems to happen with BASIC, which takes an optional parameter as part of the command line, so it's using the remnants of what is in the buffer to try to find a file to CHAIN.
- Contact:
I currently have a PiZero connected internally on my master but I want to connect up my pi3b. What ribbon cable would I need?
Is it just a regular 40 Pin GPIO Ribbon Cable ? (https://thepihut.com/products/40-pin-gp ... -gertboard)
Appreciate any guidance
Not answering your question exactly, but I have a pi4 inside my master and it fits fine on the same adapter board. Is there an obstacle to doing the same with a pi3b?
(You're right to ask about a cable, I think, in the sense that you do need to be very careful that it connects the right way around and doesn't short everything together. I think you might need one made up for the purpose.)
That male to female ribbon cable will work fine. The important thing is to not just use a standard ribbon cable with female both ends and then stick a set of header pins in one end of the cable in an attempt to make your own male to female cable. This will swap the upper and lower row of pins when compared to proper male to female ribbon cable and will cause the problems that BigEd has mentioned. I guess you could use two female / female ribbon cables with 2 sets of headers. The second cable and header would correct the pin translation that happens in the first cable. It's not something I've tried.Muddyfunster wrote: ↑Fri Sep 11, 2020 11:26 pmIs it just a regular 40 Pin GPIO Ribbon Cable ? (https://thepihut.com/products/40-pin-gp ... -gertboard)
- BeebMaster
- Contact:
I can't compete on prices, as I don't have access to the talents of a Chinese gulag, but I can do 40-way male-female, female-female, male-male ribbon cables (also 20, 34 and 50 way) of any length. I just made up a couple of these type of cable of 3ft length, and they work fine with Ken's Pi adapter. (Actually it was plugged into my existing 12" cable, so about 4ft altogether). I haven't tried on other types of adapter and it wouldn't be suitable for a real cheese wedge where the cable length is very limited.
- Contact:
Thanks gents for the replies re: the cable, much appreciated.
In my Master, the PiZero goes right on to the leveller (retro clinic) no issues.
But the Pi3, the USB sockets get in the way, plus a cable means I wouldn't need to keep de-casing it every time.
Out of interest BigEd, is there much performance increase with the Pi4 vs a Zero? I mostly mess around with the 6502 cores doing mandlebrot sets and stuff like that using the Nula.
BeebMaster, appreciate the offer, My adapter is the retroclinic one, if your cable works with that I'd be happy to take one (just let me know your non-gulag price
). 2ft would probably be ample.
Thanks again.
Thanks again.
- BeebMaster
- Contact:
I think the trouble with putting a ribbon cable between the Pi and the Retroclinic internal Tube adapter is that the Pi is going to be flopping about and could come into contact with the adapter or other internal parts of the Master.
I think I will try it though, I do have a Pi3 and a Retroclinic internal Tube adapter so let's see if I can make a short cable that might be suitable.
- Contact:
I was thinking more of keeping the pi outside the case and having a longer cable, maybe routed out via the cart slot that I don't use (I have the Nula rom sitting in the other).
Ah, I see. I've got a sundby.com adapter board which must be just a couple of millimeters different, and the USB bits just sit over the edge.Muddyfunster wrote: ↑Sat Sep 12, 2020 2:38 pmIn my Master, the PiZero goes right on to the leveller (retro clinic) no issues.
Here are Dominic's timings from upthread:Out of interest BigEd, is there much performance increase with the Pi4 vs a Zero? I mostly mess around with the 6502 cores doing mandlebrot sets and stuff like that using the Nula.
So, yes, a Pi 4 should be a lot quicker, for anything which isn't limited by host I/O.
I put a sheet of paper down, or put a paper envelope over the thing.BeebMaster wrote: ↑Sat Sep 12, 2020 2:53 pmI think the trouble with putting a ribbon cable between the Pi and the Retroclinic internal Tube adapter is that the Pi is going to be flopping about and could come into contact with the adapter or other internal parts of the Master.
Mind you, a Pi 4 might not do well if it doesn't have some air around it.
- BeebMaster
- Contact:
Yeh, I reckon a Pi4 will go ablaze inside a Master, I have a 12V PC fan blue-tacked to the top of my Pi4.
The good news is a 3ft cable also works with the Retroclinic internal adapter (with Pi Zero).
So, externally for the internal Tube we could pass a cable through the Domesday SCSI slit at the back with a couple of folds and sit it on the top:
Or through the cartridge slot:
Both of those would work with a 12" cable.
- BeebMaster
- Contact:
So much for the tape measure! 12" is a just a bit short for coming out of the back, it won't reach the lid, but it's nice for a cartridge escape:
- Contact:
Great
Coming out the back might have been a bit more problematic as that's where I have my rom switcher rotary dial located on the doomsday/modem cut out.
Cartridge port seems fine, I'm planning to run a USB extension out of there too from my datacentre so I don't have to faff around adding ssd's
Please let me know how much I owe you for the cable and I can paypal you and PM you my address.
Thanks again guys
Thanks again guys
- BeebMaster
- Contact:
- Contact:
Cable works perfectly - Thanks Beebmaster.
Unfortunately my Pi3 is dead.
I hooked up the zero first of all, using the cable, turns out I didn't have the cable on 100% correctly and had missed the final row of pins. Once corrected, the Pi Zero fired up first time as normal. All good. (probably lucky here not to short anything).
Ran the timing benchmark, all good.
Connected up my Pi3b - nothing. Checked the orientation, all good.
Tried firing the Pi3b up on it's own - nothing.
Conclusion - The Pi3b is has shrugged off it's digital coil. I've had it since release so that's a few years and all kinds of odd projects with it.
Oh and in no way do I attribute the Pi3 dying to the cable. The cable is great (I'll be coming back for one for my beebsid at somepoint - once I built it).
Still, it's a reasonable wife approved (tm) excuse to upgrade to a Pi4
- BeebMaster
- Contact:
You can tell her you will need a spare Pi4 as well, just in case. And it will reduce the unit postage cost, hopefully go down well with Mrs Muddy.
- Contact:
BeebMaster wrote: ↑Tue Sep 15, 2020 2:27 pmYou can tell her you will need a spare Pi4 as well, just in case. And it will reduce the unit postage cost, hopefully go down well with Mrs Muddy.
I did some testing earlier this year with various Pis and costed per CA point, see attached excel sheet.
- Attachments
- Copy of Tube Speed.xlsx
- (10.85 KiB) Downloaded 32 times
Re: Pi-based Co-Pro on the cheap - 100MHz 6502 for £10? (now 290MHz)
As the extra memory isn't used, the Pi4 can just be the cheapest ( 2Gbytes @ £35) Also some people have over clocked the Pi4 for extra performance
The cores written in c show the greatest performance increase with the Pi4 e.g lib6502
- Contact:
Pi 4 arrived today, works fine (testing running various pi4 builds of stuff) but the Beep refuses to recognise it via the CoPro interface.
I'm using a fresh sd card with Fer-De-Lance on it. I've tried the same SD card & same software in the zero and it works fine.
I'm connecting the cable with the same orientation as I do on the Zero.
Bit puzzled.
Bit puzzled.
First, check your configuration. If you are using PiTubeDirect on the internal Tube on a Master, and nothing on the external Tube, then it's actually best to use *CONFIGURE EXTUBE. (This setting just controls the order in which the two tube ports are probed; it's always better if PiTubeDirect is on the port that is probed last).Muddyfunster wrote: ↑Thu Sep 17, 2020 1:45 pmPi 4 arrived today, works fine (testing running various pi4 builds of stuff) but the Beep refuses to recognise it via the CoPro interface.
Second, does the LED on the Pi 4 light up at all? Try pressing ctrl-break a few times, and see if the LED flickers at all?
I've had similar problems in the past when using a cable between the level shifter and the RPi. I've always found it to be more reliable if the RPi is close coupled to the level shifter. However that is with the under keyboard version, not the Master internal version. I don't have a Master internal level shifter to test that with.
- Contact:
Thanks guys,
Dave's suggestion worked perfectly (kicking myself for not trying it first! doh!). A couple of CTRL Breaks and all is good with the Pi4.
My Pi 3 that I thought was dead, turns out it was a bad SD card and it works again (Lazarus style! Wife is super impressed... ).
It steadfastly refuses to talk to the beeb though, using the same cable and sd card as the Pi 4. LED lights up when connected but no flicker on CTRL Break.
Not a big deal as I can use the 4 when needed and have the zero as a daily driver.
Thanks again all.
Thanks again all.
I also have an old Pi 3B that will run Raspbian and Kodi fine, but refuses to even boot PiTubeDirect. It has a couple of damaged GPIO pins (zapped with static most likely).Muddyfunster wrote: ↑Thu Sep 17, 2020 4:26 pmMy Pi 3 that I thought was dead, turns out it was a bad SD card and it works again (Lazarus style! Wife is super impressed... ).
- BeebMaster
- Contact:
Here's a weird thing. I was just about to have a go using my "ADFSImager" to try to make a backup of my defect-ridden Rodime Acorn Winchester Disc, so I loaded ADFSImager from floppy with Pi Tube running (Native ARM) and I got "Bad program". Same with the 6502 Tube.
I checked, and it loads fine with no Tube or on my internal Turbo co-processor.
A bit of investigation and I found that a lot of spurious &FFs were being inserted into memory:
That looks to be something going wrong between host & Tube communication, as the test program is already there in the Tube memory at start up, but when the host is being used (via the ADT ROM *MEX command) the RAM is corrupted. Similarly transferring from host from disc to Tube was giving "Bad program" with FFs littered through it when examining the memory.
Checked all the cables, SD cards, put the fire marshal on standby etc. Then I realised - the Winchester Disc was connected to the 1MHz bus (via a couple of extension cables) but not powered on. Disconnected it and:
Back to normal!
With the Winchester plugged in and switched on this doesn't happen, everything works normally, it's only when it is plugged in but powered off.
Back to normal!
