Some more notes...
- I’ve now added unknown OSWORD handling so I will shortly also be adding new OSWORD numbers for all the I2C functions in the rom - it’s already done in fact but I need to do a bit more testing for those.
- There will of course be an identical Elk version, I just haven’t tested the latest changes on a real Electron yet.
- For the screen-shots above, I’ve used BeebEm with some RTC emulation - just saying in case things look a bit static!
- The ASCII/BCD character string produced by *NOW$ and by OSWORD 14 Type 4 does include the current temperature as the trailing two-character number representing Degrees Centigrade with a resolution of one degree but it does not include the “degC” as shown by the *TEMP and *NOW commands. This is intentional as the choice of temperature units annotation is regarded as the remit of the particular application software accessing the string data. (e.g. as provided by the *TEMP and *NOW commands.)
