Identification of small Electron PCB
retroclinic
Post by retroclinic »
Dave, can you confirm the picture of the 1770 DFS board please? I can't quite see how that could be a 1770 Disc interface? I would be interested in taking any 1770 DFS PCBs for the Model B that were available.
Thx, Mark.
Re: FS: Slogger PCBs: Pegasus, Click, Stop Press, DFS
Post by danielj »
Arcadian wrote:All four PCB requests replied to via PM.
Mark - I'm by no means 100% on the boards marked '1770' so I'll take a pic and post it to a new thread for comments/observation.
Just looking at that board, it looks like it's designed to shove some edge connector signals through a buffer IC. I don't have the elk edge connector diagram to hand at the moment... Possibly something else to do with the Plus 2? Does anyone have a "last edition" slogger catalogue scanned somewhere?
aerworuld
Post by aerworuld »
danielj wrote:Just looking at that board, it looks like it's designed to shove some edge connector signals through a buffer IC. I don't have the elk edge connector diagram to hand at the moment... Possibly something else to do with the Plus 2? Does anyone have a "last edition" slogger catalogue scanned somewhere?
Might that account for the last IC sockets (U3 and U4) as yet unknown on the Plus 2?
Stuart :)
Post by danielj »
Stuart :)
Don't think so. It's a bit odd, it has 14 direct through signals (address lines?), 4 that go through the buffer and then GND & +ve and two more. 22-way is half a cartridge slot. You'd need two of them to buffer the data lines on a cartridge slot, but if that's what it's for it's a very messy way of doing it - the data lines aren't neatly lined up on each half either. Strange.
Prime
Post by Prime »
danielj wrote: Just looking at that board, it looks like it's designed to shove some edge connector signals through a buffer IC. I don't have the elk edge connector diagram to hand at the moment... Possibly something else to do with the Plus 2? Does anyone have a "last edition" slogger catalogue scanned somewhere?
I think it's probably an Electron keyboard buffer, that has 22 lines, of which 4 are connected to the data bus, plus I have seen pictures of electrons with a buffer in, ISTR Arcadian's Merlin Electron had a buffer.
Having a look at the Electron schematic on mdfs.net pins 5-8 of the keyboard connector are the data lines which seem to go to the chip, pin 4 which is +5V also seems to go to one of the end pins of the chip, which would make sense.
So at a guess buffering the databus perhaps ?
Phill.
Post by MartinB »
Daniel wrote:...shove some edge connector signals through a buffer IC.
The signal tracking and power connections are compatible with an LS244 buffer if fitted on the plain side of the PCB with Pin 1 facing forwards on the photo.
Site Admin
Re: Identification of small Electron PCB
Post by Arcadian »
Have split the topic from the original thread in the For Sale forum.
This is the board that we're trying to identify (I'll get a better photo soon):
flynnjs
Post by flynnjs »
Confirm what Martin said. '244 buffer works fits.
Buffers just 4 lines and the /OE line is tied low
meaning they're always driving.
Someone either needed to clean up some signals
(the 244 is Schmitt) or needed more output
current.
This looks more of a "bodge/fix board" than something
that would be used in production.
Post by BeebMaster »
Looks like a nit comb to me, are you sure it's a PCB?
Post by danielj »
Here you go, Phill's right. It's a keyboard buffer for the RX:
Popular 'PC' style design is predominant, with the original Electron keyboard and case which will retain both the speaker and the Master RAM Board switch, remote from the main RX unit on a generous length of ready made and buffered keyboard cable.
Slo
Post by Slo »
BeebMaster wrote:Looks like a nit comb to me, are you sure it's a PCB?
:lol: [-X
