HCR ROM/RAM Box
flash1965
HCR ROM/RAM Box
Post by flash1965 » Thu Oct 25, 2012 5:38 am
Hi
In a recent bulk BBC bits purchase I got an HCR ROM/RAM Box.
Trying to find some fitting instructions.
I found this
http://acorn.chriswhy.co.uk/docs/Mags/A ... ection.pdf
But not the fitting instructions. Does anyone have one of these or know where I can get the information.
Gordon
A pessimist sees the difficulty in every opportunity; an optimist sees the
opportunity in every difficulty.
Re: HCR ROM/RAM Box
Post by RobC » Sun Oct 28, 2012 8:16 pm
I've just done a quick trawl of my Micro User DVDs and it was reviewed in the March 1986 edition.
The review has basic fitting instructions - it says that the circuit board plugs into the right hand rom socket and the 40-pin socket plugs into the 6502 socket. I'd assume that the notches in the sockets should point North (just like the originals).
You then the replace the 6502 and any rom that was originally in the right most socket. It says the "other two twin sockets are attached to the two links at S21" - the polarity will be important so look to see if they are marked East and West.
Hope this helps - if you haven't got them already I can't recommend the Micro User/Acorn User DVDs highly enough!
All the best,
Rob
flash1965
Re: HCR ROM/RAM Box
Post by flash1965 » Mon Oct 29, 2012 8:50 pm
Hi
Thanks Ill take a look in that issue. Where did you get the DVD's with the magazines on ?
Gordon
Re: HCR ROM/RAM Box
Post by RobC » Mon Oct 29, 2012 8:58 pm
Hi Gordon,
Sorry - should have said that they come from here:
http://www.acornelectron.co.uk/p-dvd.php
Rob
Re: HCR ROM/RAM Box
Post by tricky » Sun Oct 07, 2018 9:53 am
I've joined the club, but with the Master version.
Fitting seems simple as it looks like it just plugs into both the cartridge slots with a single adaptor.
The piece of plastic with the terminals seems to only be there to stop the box getting scratched, but maybe it was originally used for something else!
Seems to be a version 4.
Kermit 1.30I, WordWise and BCPL fitted.
With version 1 Master connector.
The second connector only picks up one signal, the enable for the second bank I guess.
