BBC BASIC for SDL 2.0 version 1.26a released
Richard Russell
Re: BBC BASIC for SDL 2.0 version 1.24a released
Post by Richard Russell »
Comment deleted.
Last edited by Richard Russell on Sun Sep 26, 2021 10:28 pm, edited 1 time in total.
nicolagiacobbe
Post by nicolagiacobbe »
Well. iOS is not my preferite platform but would be interesting to hear (in plain terms) why it won't work and what did apple do to render a difficult situation even worse.
baz4096
Post by baz4096 »
I've had issues with SDL on iOS before. Commonly used functions, in my case for keyboard entry in a game, were suddenly classified as "potential keyloggers", and threw up FUD warnings to our users. Updates weren't accepted until we refactored and used different input functions. IIRC.
Richard Russell
I've released version 1.25a of BBC BASIC for SDL 2.0 - the cross-platform programming language for Windows, MacOS, Linux, Raspberry Pi OS, Android, iOS and in-browser. The changes in this version are as follows:
  1. BASIC Interpreter / Run Time Engine
    PAGE may now be lowered without generating an error. This is dangerous in general, but in limited memory environments (e.g. the Raspberry Pi Pico) it can be useful, as it was on the original BBC Micro.
    Implemented a new SUM operator which performs modulo-2^64 addition, i.e. overflows are ignored. Using this operator modulo-2^64 subtraction and multiplication functions can be written:
          DEF FNsub64(a%%,b%%)=a%%SUMNOTb%%SUM1
          DEF FNmul64(a%%,b%%)LOCALA%,B%:A%=a%%AND&7FFFFFFF:B%=b%%AND&7FFFFFFF
          =A%*B%SUM((a%%>>31)*B%<<<31)SUM(A%*(b%%>>31)<<<31)SUM((a%%>>31AND3)*(b%%>>31AND3)<<<62)
  2. IDEs and Utilities
    No changes (other than the version number of SDLIDE.bbc being updated).
  3. Libraries
    stringlib.bbc modified so that FN_binary() and FN_tobase() accept 64-bit integers.
  4. Example Programs
    There are no changes to the example programs in this release.
This version may be downloaded, for all the supported platforms, from the usual location. The GitHub repository has been updated (used to build the MacOS, Raspberry Pi, Android, iOS, 64-bit Linux and in-browser editions, currently).
Last edited by Richard Russell on Fri Oct 08, 2021 11:17 pm, edited 2 times in total.
Re: BBC BASIC for SDL 2.0 version 1.25a released
Post by BigEd »
Hurrah!
Richard Russell
BigEd wrote:
Fri Oct 08, 2021 6:02 pm
Hurrah!
I've managed to simplify the modulo-264 multiplication routine a little:
      DEF FNmul64(a%%,b%%)LOCALA%,B%:A%=a%%AND&7FFFFFFF:B%=b%%AND&7FFFFFFF:a%%=a%%>>31:b%%=b%%>>31
      =A%*B%SUM(a%%*B%<<<31)SUM(A%*b%%<<<31)SUM((a%%AND3)*(b%%AND3)<<<62)
Can anybody do any better?
Richard Russell
Richard Russell wrote:
Fri Oct 08, 2021 11:28 pm
This is the program I used to verify my version, by comparing the result from FNmul64() with the equivalent x86-64 instruction:
      DIM ]^P% 100,]^L% -1
      [OPT 11
      .mul64
      mov rax,[REL ^b%%]
      mul qword [REL ^c%%]
      mov [REL ^a%%],rax
      ret
      *hex 64
      REPEAT
        b%% = RND EOR RND <<< 32
        c%% = RND EOR RND <<< 32
        CALL mul64
        IF a%% <> FNmul64(b%%,c%%) PRINT "Failed: should be &";~a%% " but was &";~FNmul64(b%%,c%%)
        WAIT 0
      UNTIL FALSE
      END
The *hex64 is present only so the 64-bit values can be printed in the event of a failure; the function works in *hex32 mode as well.
Richard Russell
Re: BBC BASIC for SDL 2.0 version 1.26a released
I've released version 1.26a of BBC BASIC for SDL 2.0 - the cross-platform programming language for Windows, MacOS, Linux, Raspberry Pi OS, Android, iOS and in-browser. The changes in this version are as follows:
    Changed the behaviour of VDU 127 (DEL) in VDU 5 mode to correspond to that of Acorn systems, i.e. the background GCOL mode is ignored.
    Fixed a bug causing VDU 127 not to work correctly in VDU 5 mode if the text direction has been changed.
    Fixed a bug (in ARM and 64-bit editions only) whereby characters plotted in VDU 5 mode could not be read back using GET(x,y).
    Fixed a minor bug in SDLIDE.bbc which could cause incorrect indentation of lines added at the end of a program.
    Modified compiler.bbc so that message boxes still work when path names are very long.
    Modified compiler.bbc (on Windows only) to be tolerant of spaces in the path to BBCSDL.
  3. Libraries
    Added gfxlib.bbc which partially emulates David Williams's GFXLIB2 library for BB4W; see gfxlib_docs.pdf for a detailed description.
    Added audiolib to support playing music (including MP3) and sound effects.
    Modified dlglib so that it works correctly if @ox% or @oy% is non-zero, or the graphics ORIGIN has been moved.
  4. Example Programs
    Added cowboy.bbc in examples/games; this is David Williams's GFXLIB2 demo for BB4W, converted to use the new gfxlib library.
    Added metronome.bbc in examples/sounds (this is also compatible with BBC BASIC for Windows).
    Modified lemmings.bbc and tower.bbc to use the new audiolib library.
Richard Russell
Fri Nov 19, 2021 1:50 pm
Here's a screen grab. I considered posting a video, but it could have been one of the most boring and irritating videos ever! You can however run it yourself (without needing to install anything) here.
