Reducing Basic Program Size
Re: Reducing Basic Program Size
Post by Richard Russell »
Rich Talbot-Watkins wrote:
Wed Feb 12, 2020 12:57 pm
Do you remember if the BBC BASIC specification required this to work, or whether it's just an undefined consequence of how BBC BASIC implements variable assignment (allocating a new variable and defaulting it to zero prior to evaluating the RHS)?
The 'specification' didn't go into that much detail, but it did imply the behaviour by calling for a good degree of compatibility with the Microsoft BASICs of the day. In those BASICs it was legitimate to write:
      A = A + 1
(where A wasn't previously defined) because all numeric variables initially 'exist', with a value of zero. There is nothing comparable to a 'No such variable' error; the very first line of a program could be:
      PRINT A
which would print zero, not raise an error as it would in BBC BASIC. This behaviour has survived to the present day in languages like Liberty BASIC in which all variables - even arrays with up to 10 elements - initially 'exist' but with values of zero or an empty string as appropriate.
In practice it's extremely useful to have a way of forcing a variable to exist if it doesn't, but not changing its value if it does (for example when releasing resources in a 'cleanup' routine). I tend to use the compound += operator, introduced in BBC BASIC V, for this:
      var% += 0
      IF var% THEN PROCrelease(var%)
Post by Rich Talbot-Watkins »
I guess I have the C++ orthodoxy of "declare all variables before using them" too ingrained!
LordVaderUK
Post by LordVaderUK »
One way programs can use space unnecessarily is having two copies of things in memory: one copy in a program statement defining it, and another copy in its intended location in memory.
As you mentioned, the classic example is DATA statements - the data exists twice, in the DATA statements themselves, and in the variable heap once they've been read. A lot of DATA use can be rewitten to avoid this duplication, for example the classic "day of week" function can be written:
DEF FNmon(mon%)=MID$("JanFebMarAprMayJunJulAugSepOctNovDec",mon%*3-2,3)
See http://beebwiki.mdfs.net/Data_without_DATA
Wow this is a GREAT tip. I just managed to get rid of a 6 element string array with this little tip :-) Struggling to ensure my code fits into a BBC B. Thanks!
Loving my BBC Master 128
joachim
Post by joachim »
jgharston wrote:
Sun Dec 15, 2019 10:03 pm
julie_m wrote:
Sun Dec 15, 2019 6:59 pm
Sphinx Adventure (IIRC) solves the problem in the opposite way: it stores the room descriptions in DATA statements but doesn't make an in-memory copy. How? Well, when you're in room L% and need a description, it does what amounts to:
RESTORE L%: READ LOC$: PROCprint(LOC$)
That's right, the data for location number L% is stored in line L% (or the next valid data line after it).
Post by cmorley »
I use DATA & RESTORE without copying to other memory in RTool for the menu.
REPEAT
PRINT"? ";:K$=GET$:IF K$>"`":K$=CHR$(ASCK$-32)
F$="unrecognised":A$=""
RESTORE
REPEAT:READ key$,func$,arg$,help$:IF key$=K$ THEN F$=func$:A$=arg$
UNTIL key$=""
PRINT K$;" ";
IF A$<>"" THEN INPUT LINE ""A$:A%=VAL(A$):IF A$=""THENF$="argument"
PRINT EVAL("FN"+F$)
UNTIL FALSE
DATA I,romlist,,List ROMs
DATA *,oscli,<cmd>,Issue user OS Command
DATA .,cat,,Catalogue filesystem (*.)
DATA D,drive,<drive>,Change drive
DATA L,load,<afsp>,Load ROM image from file
DATA S,save,<afsp>,Save ROM image to file
DATA R,read,<bank>,Read ROM image
DATA P,program,<bank>,Write ROM image
DATA V,verify,<bank>,Verify ROM image
DATA E,erase,<bank>,Erase complete 64K EEPROM
DATA K,lock,<bank>,Lock (write protect) SRAM
DATA U,unlock,<bank>,Unlock (write enable) SRAM
DATA Q,quit,,Quit
DATA B,reset,,Reboot computer
DATA ?,help,,Display this help
DATA ,,,
sa_scott
Post by sa_scott »
I wanted to pick up further on a point made with regards to storing DATA statements into a memory location.
My Androidz game has 20 levels of compressed level data. Each level occupies 65 bytes. How would I go about pushing this into a given location, .e.g. &A00, and keep it in memory once I load the main game file? Can I then refer to this memory location, for unpacking and displaying the data?
Currently, the data looks like this:
DATA VVVVV/...ISZfzMA...OA```O8/.IL8...L8/.ILA```OA...OSZfzM/...IVVVVV
I've looked at magazine listings over various magazines, but can't seem to find an example of one that has done this technique before. I would prefer to keep everything 'in listing' for this particular game, rather than have separate data files. Call me a traditionalist.
20 levels would equate to 1300 bytes (20 x 65 characters), I was planning on using &A00 onwards for the storage.
I'm still keen on using MODE2 for the game, but without removing the data from the listing, this can't happen!
Thanks in advance
Stephen Scott, Digital Media Professional
www.sassquad.net
Post by lurkio »
sa_scott wrote:
Wed Nov 25, 2020 7:21 pm
http://mdfs.net/Docs/Comp/BBC/AllMem
http://mdfs.net/Docs/Comp/BBC/Disk/DFSMem
sa_scott
Post by sa_scott »
Thanks Lurkio.
Looks like I can use &A00 (1300 or &514 bytes) takes me into &E08, which I think is ok.
This old game - Gold Mine - http://bbcmicro.co.uk//game.php?id=1590 - uses some data file loaded into &2200. The BASIC code then pokes at this memory location to grab the level layout. I can always try this as well. Notably, the game sets HIMEM to a location just below &2200 to prevent the data being polluted.
I was also very intrigued by this game - Rabbit Run - http://bbcmicro.co.uk//game.php?id=843 - that has very similar mechanics to mine, except the &FFEE screen poke routine is not only in machine code, but the enemies home in on your position also using machine code. The code can only be disassembled, and I can't make head nor tail of it, unfortunately. My homing code is all BASIC, and rather slow and flickery. I suspect it will be even slower if I make the jump to Mode 2.
www.sassquad.net
Post by lurkio »
sa_scott wrote:
Wed Nov 25, 2020 8:52 pm
Not if you're using disc rather than tape.
See the second link in my previous post.
See also: viewtopic.php?f=2&t=13345&p=174350&hili ... ge#p174350
sa_scott
Post by sa_scott »
Thanks, I'm getting confused. &E00 is where DFS starts.
My screen data has some repetition - the top and bottom lines of each level are always filled in, and are therefore not necessary. This will shave some data off. I'll keep stabbing away at this.
bbcmicro.co.uk is immensely useful for this type of thing - much more handy than rifling through old magazines!
www.sassquad.net
Post by lurkio »
sa_scott wrote:
Wed Nov 25, 2020 9:01 pm
Beware of &D00 when running from disc! See the "AllMem" link I posted above.
sa_scott
Post by sa_scott »
I'm currently setting PAGE to &1100 when running the main game file - the first file displays the instructions, and has page set at &1900. I'm assuming a BBC DFS system.
If I could, I would relocate page to &E00, but when the game is over, a third part is loaded containing your verdict, which needs your score tally from the game. Therefore, setting to &E00 would lose the ability to load that part.
This is where the Rabbit Run reference comes in, as it also gives you a verdict, but is all self contained.
www.sassquad.net
Post by lurkio »
sa_scott wrote:
Wed Nov 25, 2020 9:24 pm
There are ways around that. For example, in the main game (with PAGE at &E00) you could define function key 10 (the Break key) with *KEY10... to load the third part. And then CALL!-4 to trigger a Break and activate the function-key definition. PAGE should be reset on Break.
Or you might not need to define Break at all. It might be enough to define *KEY0PAGE=&1900|M*DISC|MCHAIN"VERDICT"|M and then trigger f0 with *FX138,0,128 as the last thing you do in the main game before END.
Return to “programming”
