EcoPort Issue 1 - slots into the econet header on a master, and gives you a 6522 at &FEA0. On these boards, the 6522's ~IRQ line is connected directly to the ~NMI line, so they need modifying to use interrupts on the extra 6522 properly.
EcoPort Issue 2 - the big brother of Issue 1. Connect a flying lead to A4 and you get two 6522s, one at &FEA0 and one at &FEB0. These boards have a pin header that can either act as a place to attach a flying lead for the ~IRQ line, or a jumper to bridge the 6522 ~IRQs to the ~NMI line. Untested at present due to master dying (hence why most of the board is unpopulated).
Modem to EcoPort Bridge - made so I could experiment with the internal modem header, it adapts the modem header pinout to match the econet header pinout (requires a flying lead for A3). I have one of my ecoport boards configured to connect to it so I can test it all out.
EcoSound - a 6522 driving a YM2149 and using the econet socket as an audio out. I couldn't get the YM2149 working directly on the bus, so I have the 6522 on there acting as a go-between. The MC14066 is connected to the 6522's B port, and lets you enable/disable any of the four outputs through software (two pins on the econet port to provide stereo out, and the speaker out and aux out headers on the PCB). A speaker in header lets you feed the internal audio into the mix as well. The unfitted Port A and Port B headers on the PCB are the YM2149's IO ports, not the 6522's.
EcoNet Expansion Board - the last one I was working on before the master gave up and died. If it's working, this board has an econet module with built in econet clock, and also a 6522 sitting at &FEB0 (requires the A4 flying lead). It also decodes the unused address space in the &FEA0-&FEAF range, allowing for another daughter board to be fitted with something else on, sitting at &FEA4, &FEA8 or &FEAC.
These ones aren't my designs, but came with a bundle of stuff on ebay. From poking at the green one, that has socketed ICs, they seem to be 16K to 2x8K adaptor boards with a copy of MOS on. When the model B is up and running, I'm thinking of testing them in there to see if they still work. Also the ICs are north-facing but the sockets are facing south, and this irritates me so much. The green one says '203,011 S2 Iss 1', and the white one has some faint traces which I think used to say '203,011 S1'
