Modern Printer for Econet (BBC / RiscOS)
Post by 8271 »
Hopefully this is a simple question with a simple answer.
I am looking for a relatively modern printer that I can connect to my A7000 File server that is also running spooler for printing from both the BBC and RiscOS clients.
I was hoping to find a cheap laser printer that could potentially work with the laserjet drivers that come with the !Printers app that has a parallel port (unless riscos have a TCPIP Port print functionality?
I have my old LC10 that I used on my model B back in 1990 but the ribbon is probably dried up which I may be able to get running as a backup if nothing else comes up.
2 x BBC-B, 4 x Master128, Master Viglen, Master Domesday, A310, A4, A5000, RiscPC700 Level 4 Server, RPC_SA233 & RPC_SA200, RiscOS_Pi, Econet & Ethernet
paintings
Re: Modern Printer for Econet (BBC / RiscOS)
Post by paintings »
http://www.cjemicros.co.uk/ is another possibility: they sell printers with parallel ports that should work with an A7000.
dangardner
Post by dangardner »
https://www.retroprinter.com/ is another possible option, for connecting to more modern printers.
Marvin
Post by Marvin »
I have an HP 2200N LaserJet printer that's networked via cat5 that Risc OS is happy to print to. It uses JetDirect protocol which Risc OS printer drivers support. It's a bit long in the tooth but it's totally bombproof and you can pick them up for 50quid or so on ebay.
For other suggestions have a look here... https://www.riscosopen.org/forum/forums/5/topics/14646
Post by jgharston »
My HP LaserJet 5 and HP LaserJet 5000 work perfectly fine for me, Beeb, A5000, M128 and MDFS.
