Assembly Language Programming for the BBC Micro [Remastered PDF]
dv8
Post by dv8 » Wed Sep 13, 2017 11:02 am
Here is a scanned, OCRed and fully re-typeset copy of Assembly Language Programming for the BBC Microcomputer (2nd ed.) by Ian Birnbaum.
Also included are SSD images containing all the listings in the book, answers to the exercises, and bonus utility programs that were originally supplied on an accompanying cassette.
Assembly_Language_Programming.zip
(1.93 MiB) Downloaded 1271 times
Other remastered books you may be interested in:
BBC Micro User Guide (Model B and B+ editions)
Advanced User Guide
New Advanced User Guide
sirmorris
Re: Book: Assembly Language Programming for the BBC Micro
Post by sirmorris » Wed Sep 13, 2017 12:38 pm
Ooooh thanks!
Post by DutchAcorn » Wed Sep 13, 2017 4:05 pm
Wow, this is really quality work! Well done and thanks for sharing! =D>
Post by Lardo Boffin » Wed Sep 13, 2017 4:24 pm
Just wondering what you use to get these results? I have a load of Timex Sinclair 1500 Technical Literacy Series manuals to scan and currently can only produce a jpg or similar!
Many thanks for any info
Lardo
Adventure Language on GitHub
Atom, issue 5
Elk
dv8
Post by dv8 » Thu Sep 14, 2017 12:56 am
Lardo Boffin wrote:Just wondering what you use to get these results?
It's a variety of (mostly commercial) software, plus a fair amount of effort :-)
Effectively, the book has been recreated in a DTP application.
Regarding your scanning project, to turn the images into text you will need some form of OCR software. Was any provided with your scanner? Many of them do come bundled these days. If not, maybe other folks could offer some software suggestions. The one I have is probably overkill just for a single project.
Anyway, this is the process I used to put the book together... (you may regret asking after seeing all this!)
For scanning I use IrfanView with it's handy 'batch acquire' feature.
Colour photos are captured at 300dpi, 24-bit.
Black+white photos are at 300dpi, 8-bit greyscale.
Text and line-art are at 600dpi, 1-bit monochrome.
I always save the scans in PNG format to preserve the image quality during editing.
Photo editing and clean-up is done in PaintShopPro, with a final conversion to JPEG if appropriate.
For OCR I use Nuance OmniPage. It wasn't cheap, but it's had loads of use over the years so the investment was worth it.
I especially like its proofreading features.
The results of the OCR are saved as plain, unformatted text which is then imported into Serif PagePlus for layout and styling.
I usually redraw diagrams and illustrations as vector art within PagePlus. It's often quicker to do this than to clean up the original bitmap scans. The end result looks better too. Only the photos are kept as bitmaps.
Finally, after adding any active components like bookmarks and hyperlinks, the PDF is created from PagePlus.
So there you have it, more work than any sensible person would normally attempt for the purposes of preserving a retro book!
Post by Lardo Boffin » Thu Sep 14, 2017 8:40 am
Wow! I kind of suspected a lot of work had gone into this having looked at the PDF and compared it to my original book.
Well worth the effort I would say - it's a good book. =D>
Atom, issue 5
Elk
tautology
Post by tautology » Thu Sep 14, 2017 3:23 pm
Nice, I have the original too; this means I can archive it away from that evil sunlight!
Post by tricky » Thu Sep 14, 2017 5:52 pm
Nice job with some old school tools (I use psp for all my image editing, have done since its release!)
Post by RobC » Fri Sep 15, 2017 12:22 pm
Excellent job - I've had this book since I was a kid and it's a great introduction to 6502 coding on the Beeb.
It seems to have been very popular too as I've picked up numerous copies with other Beeb stuff over the years.
dv8
Post by dv8 » Fri Sep 15, 2017 3:54 pm
Thanks all for the kind words. It's good to know the effort is appreciated :-)
tricky wrote:Nice job with some old school tools (I use psp for all my image editing, have done since its release!)
PSP has been my go to image editor for ages too. Sometimes these older lightweight tools can be more productive than their modern bloated counterparts.
RobC wrote:It seems to have been very popular too as I've picked up numerous copies with other Beeb stuff over the years.
It does turn up a lot on ebay, but most of the time it tends to be the first edition (with the green cover). This later version seems to be much less common for some reason.
andy rea
Post by andy rea » Fri Sep 15, 2017 9:22 pm
Sweet i did a fair bit of 6502 way back on the vic and pet but hardly ever touched it on the beeb, this is fantastic and just what i need to refresh my memory and with my target system as well...
Many thanks
Andy
pixelblip
Post by pixelblip » Tue Sep 26, 2017 5:16 pm
Thank you dv8. You have kept 6502 alive for people to enjoy for many more years to come .........that should be worth your effort
ludwig_van_potato
Post by ludwig_van_potato » Fri Jan 18, 2019 8:21 pm
Nice...I'm working slowly through it. We'll written
SimonSideburns
Post by SimonSideburns » Sun Jan 20, 2019 6:12 pm
Paint Shop Pro 5 is my go to image editor of choice too.
Loads much faster than more modern stuff that I'll use only a small portion of.
The only issue with it for me is it is firmly routed in the Windows 95/98 way of doing things, for example it is not possible to resize file dialogs.
Stwert
Re: Assembly Language Programming for the BBC Micro [Remastered PDF]
Post by Stwert » Sun Aug 23, 2020 10:36 am
Thank you for putting so much time and effort into doing this. I’m sure it will help many people, including my own probably fruitless efforts to learn it.
I'll be highly medicated and my humour can be twisted, so when I offend you, its not intentional, honest :lol:
TobyLobster
Post by TobyLobster » Sun Aug 23, 2020 12:27 pm
Top quality work, nicely done.
