Dave H
I opened it in irfanview. Very slowlyBeebMaster wrote: ↑Fri Aug 21, 2020 12:06 pmThis is very exciting, and all happened before I got the chance to say "it's been delivered today"!
Can anyone open the 120MB picture?
Some notes from Sean:BeebMaster wrote: ↑Fri Aug 21, 2020 12:10 pmThere's a new picture in that link now as well, the previous one everyone has been looking at so far is an 8271-6 variety, I also sent an 8271 which has now been photographed.
Oh, and there's a 8272 at www.seanriddle.com/8272metal.jpg if anyone's interested.One of the die shots is out there now and I’ll upload the other later today. The 2 dies look identical to me, but I haven’t compared them closely yet.
I’m not sure how I’ll remove the top metal layer; I normally put the die in a test tube with Whink and heat that in boiling water, but the die is stuck to the ceramic bottom and that’s too large to put in a test tube. I’ll figure something out.
I copied the pic of the 2nd die out to the same folder. I’ll do some more work this weekend.
Furthermore, these look like the connections from the bus to the big ROM looking thing in the bottom left. 8 bits seem to be tapped off the bus, and each bit makes four connections to the top of that structure, making it some sort of 8x4 thing:Diminished wrote: ↑Fri Aug 21, 2020 11:47 amThe bus in the top-left is interesting. I'm wondering if this is the "internal data bus" mentioned in the block diagram:
https://drive.google.com/file/d/19b-AsH ... sp=sharing
It continues across the width of the chip and no doubt connects up to various other things.
(Disclaimer: I have absolutely no idea what I am doing)
I was just thinking in terms of several people not all starting vectorising the same part of the chip in an incompatible format
