ingmar
Post by ingmar »
G'day from Australia.
I've just built a few of the latest version (6/8 bit) boards for myself and a couple of Canberra retro mates and the results out of the box on my BBC model B were outstanding. Thanks for all the effort that has gone into this project.
I've waded through the last 33 pages of posts but I've somehow missed the one snippet that may tell me how to connect a RGBI source (TTL level) to the board. Is it a case of specifying the RGBI colour palette in the config file and connecting the I(ntensity) line to one of the rgb x1 or x2 lines?
Ingmar
Post by hoglet »
Hello Ingmar,
ingmar wrote:
Mon Apr 06, 2020 9:12 am
You are most welcome - thanks for the positive feedback.
In terms of connections for non BBC machines, you are right this isn't well documented yet.
The I(ntensity) signal needs to be connected to the of pin P2 which is labelled with a lower case g, and the RGB signals should connect to pins labelled R, G and B respectively. The additional signals x1 and x2 are not used in RGBI mode.
You then need to select the RGBI palette. I would suggest doing this in the UI, then saving the configuration.
Depending on the source, you may need to fiddle with other setting before you get a stable picture.
What actually is the source? There may be a suitable profile already.
ingmar
Post by ingmar »
Hey Dave, the source (first off) will be a an Australian Microbee. This, if you are not familiar with them, is a Z80 based and Australian made system which was sold in large numbers to Australian and Swedish schools. The "premium" iteration runs at 3.375MHz, has a pixel clock of 13.5MHz and the video chip is a 6545. Interface was designed to essentially be CGA compatible. Microbee systems used to sell the Kaga RGB monitors. Timing is PAL compatible as it by default also has a monochrome composite video out as well.
I'm happy to wade through the other docs, coincidentally my current work-from-home task for work is to re-learn VHDL :-)
Ingmar
Post by hoglet »
ingmar wrote:
Mon Apr 06, 2020 11:29 am
I don't think there's a existing profile that's a good match to that.
Ian did some work on a profile creation guide:
https://github.com/hoglet67/RGBtoHDMI/w ... ew-Profile
I would suggest starting with that.
ingmar
Post by ingmar »
hoglet wrote:
Mon Apr 06, 2020 11:35 am
Will do, thanks again.
Is it worth running off a couple of the latest analogue boards or are they likely to change a lot?
IanB
Post by IanB »
ingmar wrote:
Mon Apr 06, 2020 12:13 pm
The issue 3 analog board is pretty stable now and not likely to change much if at all. Using the 6 way IDC header on the end of the PCB works really well.
In addition to the 3 bit TTL buffer board which has the same 6 way IDC as the analog board I've designed 6 bit, 8 bit and PC buffer boards which also have end mounted IDC connectors (9 way D for the PC board) although these new boards are untested so far.
I've also added a full size case drilling template layout to the main 6 bit V3 folder
BTW there is now an RC9 release with the latest fixes and screengrab updates.
The first 9 pins of the 10 way IDC header (i.e. excluding the +5v pin and the X1 / X2 8 bit extensions) are designed to connect via a ribbon cable directly to a 9 way "D" type IDC connector which is the CGA/EGA PC standard so the wiring is the same as the CGA standard and as mentioned by hoglet, intensity is the 'g' signal.
If you get a working profile, please post it and I'll add it to the default set
Post by BeebMaster »
I added the 4 wires to allow firmware updating, and I'm now running v66. I didn't have to do anything else except choose it through the Info menu.
I've narrowed down the rogue 8GB Kingston card boot problem.
With scaling set to Integer it boots fine.
With scaling set to Fill or Full 4:3, it needs a reset before anything happens.
This also explains why the kernel update initially worked then "suddenly" stopped working - this coincided with a change from the HD TV which looks better in Integer scaling, to the Dell 4:3 monitor which looks better with 4:3.
If it helps this is the debug output with Fill 4:3 scaling (no picture):
sudo cat /dev/serial0 | ts "%a,%d %b %Y.%.T"
TGB to HDMI booted:42:04.104494 ***********RET***********
Wed,08 Apr 2020.14:42:04.107962 8 bit board NOT detected
Wed,08 Apr 2020.14:42:04.110934 Using PLLA as the sampling clock
Wed,08 Apr 2020.14:42:04.114005 PLLA: 2400.000000 ANA1 = 00144000
Wed,08 Apr 2020.14:42:04.121153 PLLA: PDIV=1 NDIV=62 CTRL=0002103e FRAC=524288 DSI0=256 CORE=2 PER=256 CCP2=256
Wed,08 Apr 2020.14:42:04.124197 PLLB: 2000.000024 ANA1 = 00144000
Wed,08 Apr 2020.14:42:04.131017 PLLB: PDIV=1 NDIV=52 CTRL=00021034 FRAC=87382 ARM=2 SP0=256 SP1=256 SP2=256
Wed,08 Apr 2020.14:42:04.134175 PLLC: 2400.000000, ANA1 = 00144000
Wed,08 Apr 2020.14:42:04.141398 PLLC: PDIV=1 NDIV=62 CTRL=0002103e FRAC=524288 CORE2=256 CORE1=256 PER=2 CORE0=2
Wed,08 Apr 2020.14:42:04.144425 PLLD: 2000.000024 ANA1 = 00144000
Wed,08 Apr 2020.14:42:04.151326 PLLD: PDIV=1 NDIV=52 CTRL=00021034 FRAC=87382 DSI0=256 CORE=4 PER=4 DSI1=256
Wed,08 Apr 2020.14:42:04.154272 PLLH: 864.000000 ANA1 = 00144000
Wed,08 Apr 2020.14:42:04.161097 PLLH: PDIV=1 NDIV=45 CTRL=0002102d FRAC=0 AUX=4 RCAL=256 PIX=256 STS=527597
Wed,08 Apr 2020.14:42:04.164126 PLLA: 2400.000000 ANA1 = 00144000
Wed,08 Apr 2020.14:42:04.171295 PLLA: PDIV=1 NDIV=62 CTRL=0002103e FRAC=524288 DSI0=256 CORE=256 PER=4 CCP2=256
Wed,08 Apr 2020.14:42:04.174212 CPU speed detected as: 1000 Mhz
Wed,08 Apr 2020.14:42:04.184637 Keycount = 0
Wed,08 Apr 2020.14:42:04.184818 CPLD  Design: 3BIT_RGB
Wed,08 Apr 2020.14:42:04.184935 CPLD Version: 6.6
Wed,08 Apr 2020.14:42:04.193031 EMMC: BCM2708 controller power-cycled
Wed,08 Apr 2020.14:42:04.812384 Loading file /Palettes/Atom_MKII.bin
Wed,08 Apr 2020.14:42:04.819114 Loading file /Palettes/Atom_MKII_Full.bin
Wed,08 Apr 2020.14:42:04.826040 Loading file /Palettes/Atom_MKII_Plus.bin
Wed,08 Apr 2020.14:42:04.833055 Loading file /Palettes/Colour_Genie_N25.bin
Wed,08 Apr 2020.14:42:04.840602 Loading file /Palettes/Colour_Genie_S24.bin
Wed,08 Apr 2020.14:42:04.848181 Loading file /Palettes/Colour_Genie_S25.bin
Wed,08 Apr 2020.14:42:04.855270 Loading file /Palettes/Dragon-CoCo.bin
Wed,08 Apr 2020.14:42:04.861769 Loading file /Palettes/Dragon-CoCo_Emu.bin
Wed,08 Apr 2020.14:42:04.868227 Loading file /Palettes/Dragon-CoCo_Full.bin
Wed,08 Apr 2020.14:42:04.874258 Loading file /Palettes/MDA-Hercules.bin
Wed,08 Apr 2020.14:42:04.880575 Loading file /Palettes/Mono_(2_level).bin
Wed,08 Apr 2020.14:42:04.887428 Loading file /Palettes/Mono_(3_level).bin
Wed,08 Apr 2020.14:42:04.894412 Loading file /Palettes/Mono_(4_level).bin
Wed,08 Apr 2020.14:42:04.901367 Loading file /Palettes/Mono_(6_level).bin
Wed,08 Apr 2020.14:42:04.907634 Loading file /Palettes/RGB.bin
Wed,08 Apr 2020.14:42:04.912566 Loading file /Palettes/RGBI.bin
Wed,08 Apr 2020.14:42:04.917795 Loading file /Palettes/RGBI_(CGA).bin
Wed,08 Apr 2020.14:42:04.923381 Loading file /Palettes/RGBI_(Spectrum).bin
Wed,08 Apr 2020.14:42:04.929205 Loading file /Palettes/RGBrgb_(Amstrad).bin
Wed,08 Apr 2020.14:42:04.935079 Loading file /Palettes/RGBrgb_(Spectrum).bin
Wed,08 Apr 2020.14:42:04.940520 Loading file /Palettes/RrGgBb_(EGA).bin
Wed,08 Apr 2020.14:42:04.947120 Loading file /Palettes/Spectrum_48K_9Col.bin
Wed,08 Apr 2020.14:42:04.956563 FOUND RESOLUTION: 1024x600@50Hz
Wed,08 Apr 2020.14:42:04.959518 FOUND RESOLUTION: 1024x600@60Hz
Wed,08 Apr 2020.14:42:04.962422 FOUND RESOLUTION: 1024x768@50Hz
Wed,08 Apr 2020.14:42:04.965225 FOUND RESOLUTION: 1024x768@60Hz
Wed,08 Apr 2020.14:42:04.968202 FOUND RESOLUTION: 1280x1024@50Hz
Wed,08 Apr 2020.14:42:04.980318 FOUND RESOLUTION: 1280x1024@60Hz
Wed,08 Apr 2020.14:42:04.980577 FOUND RESOLUTION: 1280x720@50Hz
Wed,08 Apr 2020.14:42:04.980733 FOUND RESOLUTION: 1280x720@60Hz
Wed,08 Apr 2020.14:42:04.980866 FOUND RESOLUTION: 1280x800@50Hz
Wed,08 Apr 2020.14:42:04.982809 FOUND RESOLUTION: 1280x800@60Hz
Wed,08 Apr 2020.14:42:04.985678 FOUND RESOLUTION: 1368x768@50Hz
Wed,08 Apr 2020.14:42:04.988553 FOUND RESOLUTION: 1368x768@60Hz
Wed,08 Apr 2020.14:42:04.991563 FOUND RESOLUTION: 1600x1200@50Hz
Wed,08 Apr 2020.14:42:04.994538 FOUND RESOLUTION: 1600x1200@60Hz
Wed,08 Apr 2020.14:42:04.997523 FOUND RESOLUTION: 1920x1080@50Hz
Wed,08 Apr 2020.14:42:05.000532 FOUND RESOLUTION: 1920x1080@60Hz
Wed,08 Apr 2020.14:42:05.003499 FOUND RESOLUTION: 1920x1200@50Hz
Wed,08 Apr 2020.14:42:05.006507 FOUND RESOLUTION: 1920x1200@60Hz
Wed,08 Apr 2020.14:42:05.009281 FOUND RESOLUTION: 640x480@50Hz
Wed,08 Apr 2020.14:42:05.012076 FOUND RESOLUTION: 640x480@60Hz
Wed,08 Apr 2020.14:42:05.014893 FOUND RESOLUTION: 720x576@50Hz
Wed,08 Apr 2020.14:42:05.017714 FOUND RESOLUTION: 800x600@50Hz
Wed,08 Apr 2020.14:42:05.020511 FOUND RESOLUTION: 800x600@60Hz
Wed,08 Apr 2020.14:42:05.023333 FOUND RESOLUTION: Default@60Hz
Wed,08 Apr 2020.14:42:05.025986 Loading file /config.txt
Wed,08 Apr 2020.14:42:05.030382 Read resolution: 1280x800@60Hz
Wed,08 Apr 2020.14:42:05.033317 Match resolution: 9 1280x800@60Hz
Wed,08 Apr 2020.14:42:05.034855 Read scaling: 3
Wed,08 Apr 2020.14:42:05.044341 Loading file: /Profiles/3BIT_RGB/Default.txt
Wed,08 Apr 2020.14:42:05.068224 FOUND PROFILE: Atom
Wed,08 Apr 2020.14:42:05.070463 FOUND PROFILE: BBC_Micro
Wed,08 Apr 2020.14:42:05.073266 FOUND PROFILE: BBC_Micro_24MHz
Wed,08 Apr 2020.14:42:05.076062 FOUND PROFILE: Camputers_Lynx
Wed,08 Apr 2020.14:42:05.078857 FOUND SUB-FOLDER: Colour Test
Wed,08 Apr 2020.14:42:05.081405 FOUND PROFILE: Colour_Genie
Wed,08 Apr 2020.14:42:05.083936 FOUND PROFILE: Communicator
Wed,08 Apr 2020.14:42:05.088366 FOUND PROFILE: Communicator_Mode7
Wed,08 Apr 2020.14:42:05.088914 FOUND PROFILE: Custom
Wed,08 Apr 2020.14:42:05.091194 FOUND PROFILE: Electron
Wed,08 Apr 2020.14:42:05.092973 FOUND PROFILE: Oric
Wed,08 Apr 2020.14:42:05.094626 FOUND PROFILE: QL
Wed,08 Apr 2020.14:42:05.097002 FOUND PROFILE: Station129
Wed,08 Apr 2020.14:42:05.099198 FOUND PROFILE: Teletext
Wed,08 Apr 2020.14:42:05.101041 FOUND PROFILE: ZX80
Wed,08 Apr 2020.14:42:05.104614 Loading file /profile_3BIT_RGB.txt
Wed,08 Apr 2020.14:42:05.107697 Setting profile to 12
Wed,08 Apr 2020.14:42:05.114970 Loading file: /Saved_Profiles/3BIT_RGB/Station129.txt
Wed,08 Apr 2020.14:42:05.120494 Setting subprofile to 0
Wed,08 Apr 2020.14:42:05.122409 Profile = Station129
Wed,08 Apr 2020.14:42:05.126825 Analyze Csync: polarity unchanged (non-inverted)
Wed,08 Apr 2020.14:42:05.203746 Detected polarity state at startup = Comp (Separate H & V CPLD)
Wed,08 Apr 2020.14:42:05.224299 Keycount = 0
Wed,08 Apr 2020.14:42:05.228914 -----------------------LOOP------------------------
Wed,08 Apr 2020.14:42:05.233338 Analyze Csync: polarity unchanged (non-inverted)
Wed,08 Apr 2020.14:42:05.238352 Detected polarity state = 4, Comp (Separate H & V CPLD)
Wed,08 Apr 2020.14:42:05.246310         clkinfo.clock = 12000000 Hz
Wed,08 Apr 2020.14:42:05.248869      clkinfo.line_len = 768
Wed,08 Apr 2020.14:42:05.251940     clkinfo.clock_ppm = 5000 ppm
Wed,08 Apr 2020.14:42:05.273964     Nominal 100 lines = 6400000 ns
Wed,08 Apr 2020.14:42:05.277111      Actual 100 lines = 6405293 ns
Wed,08 Apr 2020.14:42:05.279979           Clock error = 827 PPM
Wed,08 Apr 2020.14:42:05.283313  Error adjusted clock = 11990083 Hz
Wed,08 Apr 2020.14:42:05.288668  Target PLL frequency = 2302096080 Hz, prediv = 1, PER = 4
Wed,08 Apr 2020.14:42:05.291940  Actual PLL frequency = 2302096080 Hz
Wed,08 Apr 2020.14:42:05.294289         GPCLK Divisor = 6
Wed,08 Apr 2020.14:42:05.366663       Lines per frame = 625, (625.003)
Wed,08 Apr 2020.14:42:05.372617 Actual frame time = 40032990 ns (interlaced), line time = 64052 ns
Wed,08 Apr 2020.14:42:05.378281 Window: H = 63732 to 64372, V = 19916413 to 20116577, S = Comp
Wed,08 Apr 2020.14:42:05.405456 Width or Height differ from last FB: Setting dummy 64x64 framebuffer
Wed,08 Apr 2020.14:42:05.407973 Overscan L=0, R=0, T=0, B=0
Wed,08 Apr 2020.14:42:05.435663 Initialised Framebuffer
Wed,08 Apr 2020.14:42:05.437121 Size: 1296x288
Wed,08 Apr 2020.14:42:05.438699 Pitch: 656 bytes
Wed,08 Apr 2020.14:42:05.441465 Framebuffer address: DE000000
Wed,08 Apr 2020.14:42:05.474000 RAM benchmark: Main memory = 801230 ns, Screen memory = 26348573 ns
and Integer (boots normally):
RGB to HDMI booted:46:27.787995 ***************REET***************
Wed,08 Apr 2020.14:46:27.791470 8 bit board NOT detected
Wed,08 Apr 2020.14:46:27.794486 Using PLLA as the sampling clock
Wed,08 Apr 2020.14:46:27.797562 PLLA: 2400.000000 ANA1 = 00144000
Wed,08 Apr 2020.14:46:27.804683 PLLA: PDIV=1 NDIV=62 CTRL=0002103e FRAC=524288 DSI0=256 CORE=2 PER=256 CCP2=256
Wed,08 Apr 2020.14:46:27.807734 PLLB: 2000.000024 ANA1 = 00144000
Wed,08 Apr 2020.14:46:27.814503 PLLB: PDIV=1 NDIV=52 CTRL=00021034 FRAC=87382 ARM=2 SP0=256 SP1=256 SP2=256
Wed,08 Apr 2020.14:46:27.817646 PLLC: 2400.000000, ANA1 = 00144000
Wed,08 Apr 2020.14:46:27.824802 PLLC: PDIV=1 NDIV=62 CTRL=0002103e FRAC=524288 CORE2=256 CORE1=256 PER=2 CORE0=2
Wed,08 Apr 2020.14:46:27.825030
Wed,08 Apr 2020.14:46:27.827873 PLLD: 2000.000024 ANA1 = 00144000
Wed,08 Apr 2020.14:46:27.828090
Wed,08 Apr 2020.14:46:27.834735 PLLD: PDIV=1 NDIV=52 CTRL=00021034 FRAC=87382 DSI0=256 CORE=4 PER=4 DSI1=256
Wed,08 Apr 2020.14:46:27.834948
Wed,08 Apr 2020.14:46:27.837703 PLLH: 864.000000 ANA1 = 00144000
Wed,08 Apr 2020.14:46:27.837903
Wed,08 Apr 2020.14:46:27.844478 TRL=0002102d FRAC=0 AUX=4 RCAL=256 PIX=256 STS=527437
Wed,08 Apr 2020.14:46:27.844703
Wed,08 Apr 2020.14:46:27.847518 PLLA: 2400.000000 ANA1 = 00144000
Wed,08 Apr 2020.14:46:27.847699
Wed,08 Apr 2020.14:46:27.854729 PLLA: PDIV=1 NDIV=62 CTRL=0002103e FRAC=524288 DSI0=256 CORE=256 PER=4 CCP2=256
Wed,08 Apr 2020.14:46:27.855043
Wed,08 Apr 2020.14:46:27.857585 CPU speed detected as: 1000 Mhz
Wed,08 Apr 2020.14:46:27.858036
Wed,08 Apr 2020.14:46:27.858854 Keycount = 0
Wed,08 Apr 2020.14:46:27.859419
Wed,08 Apr 2020.14:46:27.860936 CPLD  Design: 3BIT_RGB
Wed,08 Apr 2020.14:46:27.861287
Wed,08 Apr 2020.14:46:27.862656 CPLD Version: 6.6
Wed,08 Apr 2020.14:46:27.863133
Wed,08 Apr 2020.14:46:27.876474 EMMC: BCM2708 controller power-cycled
Wed,08 Apr 2020.14:46:27.876682
Wed,08 Apr 2020.14:46:28.495794 Loading file /Palettes/Atom_MKII.bin
Wed,08 Apr 2020.14:46:28.502532 Loading file /Palettes/Atom_MKII_Full.bin
Wed,08 Apr 2020.14:46:28.502658
Wed,08 Apr 2020.14:46:28.509421 Loading file /Palettes/Atom_MKII_Plus.bin
Wed,08 Apr 2020.14:46:28.509555
Wed,08 Apr 2020.14:46:28.516458 Loading file /Palettes/Colour_Genie_N25.bin
Wed,08 Apr 2020.14:46:28.516582
Wed,08 Apr 2020.14:46:28.525072 Loading file /Palettes/Colour_Genie_S24.bin
Wed,08 Apr 2020.14:46:28.525240
Wed,08 Apr 2020.14:46:28.531574 Loading file /Palettes/Colour_Genie_S25.bin
Wed,08 Apr 2020.14:46:28.531756
Wed,08 Apr 2020.14:46:28.538671 Loading file /Palettes/Dragon-CoCo.bin
Wed,08 Apr 2020.14:46:28.538843
Wed,08 Apr 2020.14:46:28.545152 Loading file /Palettes/Dragon-CoCo_Emu.bin
Wed,08 Apr 2020.14:46:28.545456
Wed,08 Apr 2020.14:46:28.551596 Loading file /Palettes/Dragon-CoCo_Full.bin
Wed,08 Apr 2020.14:46:28.552055
Wed,08 Apr 2020.14:46:28.557663 Loading file /Palettes/MDA-Hercules.bin
Wed,08 Apr 2020.14:46:28.557835
Wed,08 Apr 2020.14:46:28.563967 Loading file /Palettes/Mono_(2_level).bin
Wed,08 Apr 2020.14:46:28.564193
Wed,08 Apr 2020.14:46:28.570849 Loading file /Palettes/Mono_(3_level).bin
Wed,08 Apr 2020.14:46:28.571052
Wed,08 Apr 2020.14:46:28.577799 Loading file /Palettes/Mono_(4_level).bin
Wed,08 Apr 2020.14:46:28.578068
Wed,08 Apr 2020.14:46:28.584595 Loading file /Palettes/Mono_(6_level).bin
Wed,08 Apr 2020.14:46:28.584776
Wed,08 Apr 2020.14:46:28.590994 Loading file /Palettes/RGB.bin
Wed,08 Apr 2020.14:46:28.591152
Wed,08 Apr 2020.14:46:28.595924 Loading file /Palettes/RGBI.bin
Wed,08 Apr 2020.14:46:28.596126
Wed,08 Apr 2020.14:46:28.601185 Loading file /Palettes/RGBI_(CGA).bin
Wed,08 Apr 2020.14:46:28.601389
Wed,08 Apr 2020.14:46:28.606806 Loading file /Palettes/RGBI_(Spectrum).bin
Wed,08 Apr 2020.14:46:28.607053
Wed,08 Apr 2020.14:46:28.612631 Loading file /Palettes/RGBrgb_(Amstrad).bin
Wed,08 Apr 2020.14:46:28.612926
Wed,08 Apr 2020.14:46:28.618529 Loading file /Palettes/RGBrgb_(Spectrum).bin
Wed,08 Apr 2020.14:46:28.618846
Wed,08 Apr 2020.14:46:28.624043 Loading file /Palettes/RrGgBb_(EGA).bin
Wed,08 Apr 2020.14:46:28.624479
Wed,08 Apr 2020.14:46:28.630528 Loading file /Palettes/Spectrum_48K_9Col.bin
Wed,08 Apr 2020.14:46:28.630840
Wed,08 Apr 2020.14:46:28.639927 FOUND RESOLUTION: 1024x600@50Hz
Wed,08 Apr 2020.14:46:28.640295
Wed,08 Apr 2020.14:46:28.642804 FOUND RESOLUTION: 1024x600@60Hz
Wed,08 Apr 2020.14:46:28.643044
Wed,08 Apr 2020.14:46:28.645721 FOUND RESOLUTION: 1024x768@50Hz
Wed,08 Apr 2020.14:46:28.646002
Wed,08 Apr 2020.14:46:28.648591 FOUND RESOLUTION: 1024x768@60Hz
Wed,08 Apr 2020.14:46:28.648802
Wed,08 Apr 2020.14:46:28.651598 FOUND RESOLUTION: 1280x1024@50Hz
Wed,08 Apr 2020.14:46:28.651792
Wed,08 Apr 2020.14:46:28.654602 FOUND RESOLUTION: 1280x1024@60Hz
Wed,08 Apr 2020.14:46:28.654898
Wed,08 Apr 2020.14:46:28.657502 FOUND RESOLUTION: 1280x720@50Hz
Wed,08 Apr 2020.14:46:28.657761
Wed,08 Apr 2020.14:46:28.660404 FOUND RESOLUTION: 1280x720@60Hz
Wed,08 Apr 2020.14:46:28.660667
Wed,08 Apr 2020.14:46:28.663315 FOUND RESOLUTION: 1280x800@50Hz
Wed,08 Apr 2020.14:46:28.663679
Wed,08 Apr 2020.14:46:28.666223 FOUND RESOLUTION: 1280x800@60Hz
Wed,08 Apr 2020.14:46:28.666573
Wed,08 Apr 2020.14:46:28.669155 FOUND RESOLUTION: 1368x768@50Hz
Wed,08 Apr 2020.14:46:28.669437
Wed,08 Apr 2020.14:46:28.672131 FOUND RESOLUTION: 1368x768@60Hz
Wed,08 Apr 2020.14:46:28.672683
Wed,08 Apr 2020.14:46:28.675073 FOUND RESOLUTION: 1600x1200@50Hz
Wed,08 Apr 2020.14:46:28.675427
Wed,08 Apr 2020.14:46:28.677979 FOUND RESOLUTION: 1600x1200@60Hz
Wed,08 Apr 2020.14:46:28.678242
Wed,08 Apr 2020.14:46:28.680966 FOUND RESOLUTION: 1920x1080@50Hz
Wed,08 Apr 2020.14:46:28.681181
Wed,08 Apr 2020.14:46:28.683922 FOUND RESOLUTION: 1920x1080@60Hz
Wed,08 Apr 2020.14:46:28.684127
Wed,08 Apr 2020.14:46:28.686907 FOUND RESOLUTION: 1920x1200@50Hz
Wed,08 Apr 2020.14:46:28.687085
Wed,08 Apr 2020.14:46:28.689897 FOUND RESOLUTION: 1920x1200@60Hz
Wed,08 Apr 2020.14:46:28.690090
Wed,08 Apr 2020.14:46:28.692725 FOUND RESOLUTION: 640x480@50Hz
Wed,08 Apr 2020.14:46:28.692916
Wed,08 Apr 2020.14:46:28.695565 FOUND RESOLUTION: 640x480@60Hz
Wed,08 Apr 2020.14:46:28.695828
Wed,08 Apr 2020.14:46:28.698374 FOUND RESOLUTION: 720x576@50Hz
Wed,08 Apr 2020.14:46:28.698634
Wed,08 Apr 2020.14:46:28.701208 FOUND RESOLUTION: 800x600@50Hz
Wed,08 Apr 2020.14:46:28.701469
Wed,08 Apr 2020.14:46:28.703959 FOUND RESOLUTION: 800x600@60Hz
Wed,08 Apr 2020.14:46:28.704147
Wed,08 Apr 2020.14:46:28.706771 FOUND RESOLUTION: Default@60Hz
Wed,08 Apr 2020.14:46:28.706960
Wed,08 Apr 2020.14:46:28.709394 Loading file /config.txt
Wed,08 Apr 2020.14:46:28.709600
Wed,08 Apr 2020.14:46:28.713678 Read resolution: 1280x800@60Hz
Wed,08 Apr 2020.14:46:28.713981
Wed,08 Apr 2020.14:46:28.716850 Match resolution: 9 1280x800@60Hz
Wed,08 Apr 2020.14:46:28.717481
Wed,08 Apr 2020.14:46:28.718186 Read scaling: 1
Wed,08 Apr 2020.14:46:28.718348
Wed,08 Apr 2020.14:46:28.727759 Loading file: /Profiles/3BIT_RGB/Default.txt
Wed,08 Apr 2020.14:46:28.727951
Wed,08 Apr 2020.14:46:28.751616 FOUND PROFILE: Atom
Wed,08 Apr 2020.14:46:28.751785
Wed,08 Apr 2020.14:46:28.753876 FOUND PROFILE: BBC_Micro
Wed,08 Apr 2020.14:46:28.753988
Wed,08 Apr 2020.14:46:28.756683 FOUND PROFILE: BBC_Micro_24MHz
Wed,08 Apr 2020.14:46:28.756790
Wed,08 Apr 2020.14:46:28.759505 FOUND PROFILE: Camputers_Lynx
Wed,08 Apr 2020.14:46:28.759754
Wed,08 Apr 2020.14:46:28.762310 FOUND SUB-FOLDER: Colour Test
Wed,08 Apr 2020.14:46:28.762748
Wed,08 Apr 2020.14:46:28.764853 FOUND PROFILE: Colour_Genie
Wed,08 Apr 2020.14:46:28.765293
Wed,08 Apr 2020.14:46:28.767247 FOUND PROFILE: Communicator
Wed,08 Apr 2020.14:46:28.767400
Wed,08 Apr 2020.14:46:28.770304 FOUND PROFILE: Communicator_Mode7
Wed,08 Apr 2020.14:46:28.770403
Wed,08 Apr 2020.14:46:28.772347 FOUND PROFILE: Custom
Wed,08 Apr 2020.14:46:28.772491
Wed,08 Apr 2020.14:46:28.774543 FOUND PROFILE: Electron
Wed,08 Apr 2020.14:46:28.774679
Wed,08 Apr 2020.14:46:28.776372 FOUND PROFILE: Oric
Wed,08 Apr 2020.14:46:28.776473
Wed,08 Apr 2020.14:46:28.778063 FOUND PROFILE: QL
Wed,08 Apr 2020.14:46:28.778229
Wed,08 Apr 2020.14:46:28.780431 FOUND PROFILE: Station129
Wed,08 Apr 2020.14:46:28.780574
Wed,08 Apr 2020.14:46:28.782612 FOUND PROFILE: Teletext
Wed,08 Apr 2020.14:46:28.782715
Wed,08 Apr 2020.14:46:28.784448 FOUND PROFILE: ZX80
Wed,08 Apr 2020.14:46:28.784549
Wed,08 Apr 2020.14:46:28.787903 Loading file /profile_3BIT_RGB.txt
Wed,08 Apr 2020.14:46:28.788016
Wed,08 Apr 2020.14:46:28.791044 Setting profile to 12
Wed,08 Apr 2020.14:46:28.791256
Wed,08 Apr 2020.14:46:28.798425 Loading file: /Saved_Profiles/3BIT_RGB/Station129.txt
Wed,08 Apr 2020.14:46:28.798576
Wed,08 Apr 2020.14:46:28.803898 Setting subprofile to 0
Wed,08 Apr 2020.14:46:28.804028
Wed,08 Apr 2020.14:46:28.805848 Profile = Station129
Wed,08 Apr 2020.14:46:28.806009
Wed,08 Apr 2020.14:46:28.810245 Analyze Csync: polarity unchanged (non-inverted)
Wed,08 Apr 2020.14:46:28.810417
Wed,08 Apr 2020.14:46:28.887156 Detected polarity state at startup = Comp (Separate H & V CPLD)
Wed,08 Apr 2020.14:46:28.887280
Wed,08 Apr 2020.14:46:28.890068 Keycount = 0
Wed,08 Apr 2020.14:46:28.890310
Wed,08 Apr 2020.14:46:28.894764 -----------------------LOOP------------------------
Wed,08 Apr 2020.14:46:28.894921
Wed,08 Apr 2020.14:46:28.900510 Analyze Csync: polarity unchanged (non-inverted)
Wed,08 Apr 2020.14:46:28.900662
Wed,08 Apr 2020.14:46:28.904153 Detected polarity state = 4, Comp (Separate H & V CPLD)
Wed,08 Apr 2020.14:46:28.904305
Wed,08 Apr 2020.14:46:28.912110         clkinfo.clock = 12000000 Hz
Wed,08 Apr 2020.14:46:28.912244
Wed,08 Apr 2020.14:46:28.914654      clkinfo.line_len = 768
Wed,08 Apr 2020.14:46:28.914817
Wed,08 Apr 2020.14:46:28.917620     clkinfo.clock_ppm = 5000 ppm
Wed,08 Apr 2020.14:46:28.917749
Wed,08 Apr 2020.14:46:28.939798     Nominal 100 lines = 6400000 ns
Wed,08 Apr 2020.14:46:28.939960
Wed,08 Apr 2020.14:46:28.942922      Actual 100 lines = 6405229 ns
Wed,08 Apr 2020.14:46:28.943080
Wed,08 Apr 2020.14:46:28.945808           Clock error = 817 PPM
Wed,08 Apr 2020.14:46:28.945957
Wed,08 Apr 2020.14:46:28.949059  Error adjusted clock = 11990203 Hz
Wed,08 Apr 2020.14:46:28.949172
Wed,08 Apr 2020.14:46:28.954344  Target PLL frequency = 2302119096 Hz, prediv = 1, PER = 4
Wed,08 Apr 2020.14:46:28.954512
Wed,08 Apr 2020.14:46:28.957753  Actual PLL frequency = 2302119096 Hz
Wed,08 Apr 2020.14:46:28.957863
Wed,08 Apr 2020.14:46:28.960146         GPCLK Divisor = 6
Wed,08 Apr 2020.14:46:28.960262
Wed,08 Apr 2020.14:46:29.032475       Lines per frame = 625, (624.995)
Wed,08 Apr 2020.14:46:29.032630
Wed,08 Apr 2020.14:46:29.038424 Actual frame time = 40032750 ns (interlaced), line time = 64052 ns
Wed,08 Apr 2020.14:46:29.038508
Wed,08 Apr 2020.14:46:29.044057 Window: H = 63732 to 64372, V = 19916294 to 20116456, S = Comp
Wed,08 Apr 2020.14:46:29.044661
Wed,08 Apr 2020.14:46:29.071260 Width or Height differ from last FB: Setting dummy 64x64 framebuffer
Wed,08 Apr 2020.14:46:29.071409
Wed,08 Apr 2020.14:46:29.074464 Overscan L=360, R=361, T=120, B=121
Wed,08 Apr 2020.14:46:29.074595
Wed,08 Apr 2020.14:46:29.103124 Initialised Framebuffer
Wed,08 Apr 2020.14:46:29.103323
Wed,08 Apr 2020.14:46:29.104650 Size: 1920x8192
Wed,08 Apr 2020.14:46:29.104766
Wed,08 Apr 2020.14:46:29.111014 Invalid frame buffer dimensions - maybe HDMI not connected - rebooting
Wed,08 Apr 2020.14:46:29.111207
Wed,08 Apr 2020.14:46:31.186680 ***********************RESET***********************
Wed,08 Apr 2020.14:46:31.186932
Wed,08 Apr 2020.14:46:31.188392 RGB to HDMI booted
Wed,08 Apr 2020.14:46:31.188558
Wed,08 Apr 2020.14:46:31.191870 8 bit board NOT detected
Wed,08 Apr 2020.14:46:31.192036
Wed,08 Apr 2020.14:46:31.194892 Using PLLA as the sampling clock
Wed,08 Apr 2020.14:46:31.195082
Wed,08 Apr 2020.14:46:31.197950 PLLA: 2400.000000 ANA1 = 00144000
Wed,08 Apr 2020.14:46:31.198121
Wed,08 Apr 2020.14:46:31.205087 PLLA: PDIV=1 NDIV=62 CTRL=0002103e FRAC=524288 DSI0=256 CORE=2 PER=256 CCP2=256
Wed,08 Apr 2020.14:46:31.205272
Wed,08 Apr 2020.14:46:31.208128 PLLB: 2000.000024 ANA1 = 00144000
Wed,08 Apr 2020.14:46:31.208239
Wed,08 Apr 2020.14:46:31.214914 PLLB: PDIV=1 NDIV=52 CTRL=00021034 FRAC=87382 ARM=2 SP0=256 SP1=256 SP2=256
Wed,08 Apr 2020.14:46:31.215085
Wed,08 Apr 2020.14:46:31.218065 PLLC: 2400.000000, ANA1 = 00144000
Wed,08 Apr 2020.14:46:31.218205
Wed,08 Apr 2020.14:46:31.225350 PLLC: PDIV=1 NDIV=62 CTRL=0002103e FRAC=524288 CORE2=256 CORE1=256 PER=2 CORE0=2
Wed,08 Apr 2020.14:46:31.225595
Wed,08 Apr 2020.14:46:31.228359 PLLD: 2000.000024 ANA1 = 00144000
Wed,08 Apr 2020.14:46:31.228577
Wed,08 Apr 2020.14:46:31.235238 PLLD: PDIV=1 NDIV=52 CTRL=00021034 FRAC=87382 DSI0=256 CORE=4 PER=4 DSI1=256
Wed,08 Apr 2020.14:46:31.235488
Wed,08 Apr 2020.14:46:31.238220 PLLH: 834.999994 ANA1 = 00144000
Wed,08 Apr 2020.14:46:31.238466
Wed,08 Apr 2020.14:46:31.245443 PLLH: PDIV=1 NDIV=43 CTRL=0002102b FRAC=513365 AUX=256 RCAL=256 PIX=1 STS=528367
Wed,08 Apr 2020.14:46:31.245750
Wed,08 Apr 2020.14:46:31.248542 PLLA: 2400.000000 ANA1 = 00144000
Wed,08 Apr 2020.14:46:31.248877
Wed,08 Apr 2020.14:46:31.255716 PLLA: PDIV=1 NDIV=62 CTRL=0002103e FRAC=524288 DSI0=256 CORE=256 PER=4 CCP2=256
Wed,08 Apr 2020.14:46:31.256309
Wed,08 Apr 2020.14:46:31.258602 CPU speed detected as: 1000 Mhz
Wed,08 Apr 2020.14:46:31.259013
Wed,08 Apr 2020.14:46:31.259863 Keycount = 0
Wed,08 Apr 2020.14:46:31.260537
Wed,08 Apr 2020.14:46:31.261849 CPLD  Design: 3BIT_RGB
Wed,08 Apr 2020.14:46:31.262117
Wed,08 Apr 2020.14:46:31.263500 CPLD Version: 6.6
Wed,08 Apr 2020.14:46:31.263677
Wed,08 Apr 2020.14:46:31.277427 EMMC: BCM2708 controller power-cycled
Wed,08 Apr 2020.14:46:31.277715
Wed,08 Apr 2020.14:46:31.896863 Loading file /Palettes/Atom_MKII.bin
Wed,08 Apr 2020.14:46:31.903610 Loading file /Palettes/Atom_MKII_Full.bin
Wed,08 Apr 2020.14:46:31.903925
Wed,08 Apr 2020.14:46:31.910410 Loading file /Palettes/Atom_MKII_Plus.bin
Wed,08 Apr 2020.14:46:31.910612
Wed,08 Apr 2020.14:46:31.917562 Loading file /Palettes/Colour_Genie_N25.bin
Wed,08 Apr 2020.14:46:31.917885
Wed,08 Apr 2020.14:46:31.925037 Loading file /Palettes/Colour_Genie_S24.bin
Wed,08 Apr 2020.14:46:31.932590 Loading file /Palettes/Colour_Genie_S25.bin
Wed,08 Apr 2020.14:46:31.932812
Wed,08 Apr 2020.14:46:31.939670 Loading file /Palettes/Dragon-CoCo.bin
Wed,08 Apr 2020.14:46:31.939856
Wed,08 Apr 2020.14:46:31.946142 Loading file /Palettes/Dragon-CoCo_Emu.bin
Wed,08 Apr 2020.14:46:31.946422
Wed,08 Apr 2020.14:46:31.952762 Loading file /Palettes/Dragon-CoCo_Full.bin
Wed,08 Apr 2020.14:46:31.953458
Wed,08 Apr 2020.14:46:31.958709 Loading file /Palettes/MDA-Hercules.bin
Wed,08 Apr 2020.14:46:31.959100
Wed,08 Apr 2020.14:46:31.967438 Loading file /Palettes/Mono_(2_level).bin
Wed,08 Apr 2020.14:46:31.967978
Wed,08 Apr 2020.14:46:31.972000 Loading file /Palettes/Mono_(3_level).bin
Wed,08 Apr 2020.14:46:31.972498
Wed,08 Apr 2020.14:46:31.978734 Loading file /Palettes/Mono_(4_level).bin
Wed,08 Apr 2020.14:46:31.978963
Wed,08 Apr 2020.14:46:31.985622 Loading file /Palettes/Mono_(6_level).bin
Wed,08 Apr 2020.14:46:31.985786
Wed,08 Apr 2020.14:46:31.992065 Loading file /Palettes/RGB.bin
Wed,08 Apr 2020.14:46:31.992565
Wed,08 Apr 2020.14:46:31.996970 Loading file /Palettes/RGBI.bin
Wed,08 Apr 2020.14:46:31.997359
Wed,08 Apr 2020.14:46:32.002344 Loading file /Palettes/RGBI_(CGA).bin
Wed,08 Apr 2020.14:46:32.002818
Wed,08 Apr 2020.14:46:32.007803 Loading file /Palettes/RGBI_(Spectrum).bin
Wed,08 Apr 2020.14:46:32.008070
Wed,08 Apr 2020.14:46:32.013692 Loading file /Palettes/RGBrgb_(Amstrad).bin
Wed,08 Apr 2020.14:46:32.014099
Wed,08 Apr 2020.14:46:32.019500 Loading file /Palettes/RGBrgb_(Spectrum).bin
Wed,08 Apr 2020.14:46:32.019783
Wed,08 Apr 2020.14:46:32.024947 Loading file /Palettes/RrGgBb_(EGA).bin
Wed,08 Apr 2020.14:46:32.025227
Wed,08 Apr 2020.14:46:32.031537 Loading file /Palettes/Spectrum_48K_9Col.bin
Wed,08 Apr 2020.14:46:32.031906
Wed,08 Apr 2020.14:46:32.041103 FOUND RESOLUTION: 1024x600@50Hz
Wed,08 Apr 2020.14:46:32.041641
Wed,08 Apr 2020.14:46:32.043942 FOUND RESOLUTION: 1024x600@60Hz
Wed,08 Apr 2020.14:46:32.044473
Wed,08 Apr 2020.14:46:32.046709 FOUND RESOLUTION: 1024x768@50Hz
Wed,08 Apr 2020.14:46:32.047010
Wed,08 Apr 2020.14:46:32.049638 FOUND RESOLUTION: 1024x768@60Hz
Wed,08 Apr 2020.14:46:32.050021
Wed,08 Apr 2020.14:46:32.052627 FOUND RESOLUTION: 1280x1024@50Hz
Wed,08 Apr 2020.14:46:32.052993
Wed,08 Apr 2020.14:46:32.055592 FOUND RESOLUTION: 1280x1024@60Hz
Wed,08 Apr 2020.14:46:32.055941
Wed,08 Apr 2020.14:46:32.058504 FOUND RESOLUTION: 1280x720@50Hz
Wed,08 Apr 2020.14:46:32.058818
Wed,08 Apr 2020.14:46:32.061379 FOUND RESOLUTION: 1280x720@60Hz
Wed,08 Apr 2020.14:46:32.061639
Wed,08 Apr 2020.14:46:32.064275 FOUND RESOLUTION: 1280x800@50Hz
Wed,08 Apr 2020.14:46:32.064516
Wed,08 Apr 2020.14:46:32.067173 FOUND RESOLUTION: 1280x800@60Hz
Wed,08 Apr 2020.14:46:32.067417
Wed,08 Apr 2020.14:46:32.070092 FOUND RESOLUTION: 1368x768@50Hz
Wed,08 Apr 2020.14:46:32.070448
Wed,08 Apr 2020.14:46:32.073019 FOUND RESOLUTION: 1368x768@60Hz
Wed,08 Apr 2020.14:46:32.073425
Wed,08 Apr 2020.14:46:32.076009 FOUND RESOLUTION: 1600x1200@50Hz
Wed,08 Apr 2020.14:46:32.076339
Wed,08 Apr 2020.14:46:32.078979 FOUND RESOLUTION: 1600x1200@60Hz
Wed,08 Apr 2020.14:46:32.079255
Wed,08 Apr 2020.14:46:32.082116 FOUND RESOLUTION: 1920x1080@50Hz
Wed,08 Apr 2020.14:46:32.082534
Wed,08 Apr 2020.14:46:32.085088 FOUND RESOLUTION: 1920x1080@60Hz
Wed,08 Apr 2020.14:46:32.085590
Wed,08 Apr 2020.14:46:32.087915 FOUND RESOLUTION: 1920x1200@50Hz
Wed,08 Apr 2020.14:46:32.088122
Wed,08 Apr 2020.14:46:32.090899 FOUND RESOLUTION: 1920x1200@60Hz
Wed,08 Apr 2020.14:46:32.091089
Wed,08 Apr 2020.14:46:32.093724 FOUND RESOLUTION: 640x480@50Hz
Wed,08 Apr 2020.14:46:32.093936
Wed,08 Apr 2020.14:46:32.096530 FOUND RESOLUTION: 640x480@60Hz
Wed,08 Apr 2020.14:46:32.096728
Wed,08 Apr 2020.14:46:32.099327 FOUND RESOLUTION: 720x576@50Hz
Wed,08 Apr 2020.14:46:32.099513
Wed,08 Apr 2020.14:46:32.102159 FOUND RESOLUTION: 800x600@50Hz
Wed,08 Apr 2020.14:46:32.102357
Wed,08 Apr 2020.14:46:32.104957 FOUND RESOLUTION: 800x600@60Hz
Wed,08 Apr 2020.14:46:32.105123
Wed,08 Apr 2020.14:46:32.107793 FOUND RESOLUTION: Default@60Hz
Wed,08 Apr 2020.14:46:32.107985
Wed,08 Apr 2020.14:46:32.110354 Loading file /config.txt
Wed,08 Apr 2020.14:46:32.110715
Wed,08 Apr 2020.14:46:32.114792 Read resolution: 1280x800@60Hz
Wed,08 Apr 2020.14:46:32.115365
Wed,08 Apr 2020.14:46:32.117817 Match resolution: 9 1280x800@60Hz
Wed,08 Apr 2020.14:46:32.118324
Wed,08 Apr 2020.14:46:32.119268 Read scaling: 1
Wed,08 Apr 2020.14:46:32.119798
Wed,08 Apr 2020.14:46:32.128760 Loading file: /Profiles/3BIT_RGB/Default.txt
Wed,08 Apr 2020.14:46:32.128921
Wed,08 Apr 2020.14:46:32.152775 FOUND PROFILE: Atom
Wed,08 Apr 2020.14:46:32.153213
Wed,08 Apr 2020.14:46:32.154987 FOUND PROFILE: BBC_Micro
Wed,08 Apr 2020.14:46:32.155411
Wed,08 Apr 2020.14:46:32.157715 FOUND PROFILE: BBC_Micro_24MHz
Wed,08 Apr 2020.14:46:32.157839
Wed,08 Apr 2020.14:46:32.160444 FOUND PROFILE: Camputers_Lynx
Wed,08 Apr 2020.14:46:32.160613
Wed,08 Apr 2020.14:46:32.163167 FOUND SUB-FOLDER: Colour Test
Wed,08 Apr 2020.14:46:32.163327
Wed,08 Apr 2020.14:46:32.165691 FOUND PROFILE: Colour_Genie
Wed,08 Apr 2020.14:46:32.165802
Wed,08 Apr 2020.14:46:32.168239 FOUND PROFILE: Communicator
Wed,08 Apr 2020.14:46:32.168349
Wed,08 Apr 2020.14:46:32.171323 FOUND PROFILE: Communicator_Mode7
Wed,08 Apr 2020.14:46:32.171462
Wed,08 Apr 2020.14:46:32.173467 FOUND PROFILE: Custom
Wed,08 Apr 2020.14:46:32.173702
Wed,08 Apr 2020.14:46:32.175617 FOUND PROFILE: Electron
Wed,08 Apr 2020.14:46:32.175990
Wed,08 Apr 2020.14:46:32.177539 FOUND PROFILE: Oric
Wed,08 Apr 2020.14:46:32.178016
Wed,08 Apr 2020.14:46:32.179222 FOUND PROFILE: QL
Wed,08 Apr 2020.14:46:32.179687
Wed,08 Apr 2020.14:46:32.181442 FOUND PROFILE: Station129
Wed,08 Apr 2020.14:46:32.181583
Wed,08 Apr 2020.14:46:32.183640 FOUND PROFILE: Teletext
Wed,08 Apr 2020.14:46:32.183866
Wed,08 Apr 2020.14:46:32.185476 FOUND PROFILE: ZX80
Wed,08 Apr 2020.14:46:32.185617
Wed,08 Apr 2020.14:46:32.188916 Loading file /profile_3BIT_RGB.txt
Wed,08 Apr 2020.14:46:32.189036
Wed,08 Apr 2020.14:46:32.191984 Setting profile to 12
Wed,08 Apr 2020.14:46:32.192122
Wed,08 Apr 2020.14:46:32.199481 Loading file: /Saved_Profiles/3BIT_RGB/Station129.txt
Wed,08 Apr 2020.14:46:32.199769
Wed,08 Apr 2020.14:46:32.205096 Setting subprofile to 0
Wed,08 Apr 2020.14:46:32.205530
Wed,08 Apr 2020.14:46:32.206834 Profile = Station129
Wed,08 Apr 2020.14:46:32.206936
Wed,08 Apr 2020.14:46:32.211258 Analyze Csync: polarity unchanged (non-inverted)
Wed,08 Apr 2020.14:46:32.211445
Wed,08 Apr 2020.14:46:32.288172 Detected polarity state at startup = Comp (Separate H & V CPLD)
Wed,08 Apr 2020.14:46:32.288307
Wed,08 Apr 2020.14:46:32.292850 Keycount = 0
Wed,08 Apr 2020.14:46:32.292948
Wed,08 Apr 2020.14:46:32.297527 -----------------------LOOP------------------------
Wed,08 Apr 2020.14:46:32.297652
Wed,08 Apr 2020.14:46:32.301932 Analyze Csync: polarity unchanged (non-inverted)
Wed,08 Apr 2020.14:46:32.302145
Wed,08 Apr 2020.14:46:32.306911 Detected polarity state = 4, Comp (Separate H & V CPLD)
Wed,08 Apr 2020.14:46:32.307001
Wed,08 Apr 2020.14:46:32.314878         clkinfo.clock = 12000000 Hz
Wed,08 Apr 2020.14:46:32.315009
Wed,08 Apr 2020.14:46:32.317414      clkinfo.line_len = 768
Wed,08 Apr 2020.14:46:32.317518
Wed,08 Apr 2020.14:46:32.320408     clkinfo.clock_ppm = 5000 ppm
Wed,08 Apr 2020.14:46:32.320523
Wed,08 Apr 2020.14:46:32.342683     Nominal 100 lines = 6400000 ns
Wed,08 Apr 2020.14:46:32.342816
Wed,08 Apr 2020.14:46:32.345703      Actual 100 lines = 6405199 ns
Wed,08 Apr 2020.14:46:32.345834
Wed,08 Apr 2020.14:46:32.348594           Clock error = 812 PPM
Wed,08 Apr 2020.14:46:32.348761
Wed,08 Apr 2020.14:46:32.351831  Error adjusted clock = 11990259 Hz
Wed,08 Apr 2020.14:46:32.351997
Wed,08 Apr 2020.14:46:32.357111  Target PLL frequency = 2302129872 Hz, prediv = 1, PER = 4
Wed,08 Apr 2020.14:46:32.357260
Wed,08 Apr 2020.14:46:32.360540  Actual PLL frequency = 2302129872 Hz
Wed,08 Apr 2020.14:46:32.360689
Wed,08 Apr 2020.14:46:32.362918         GPCLK Divisor = 6
Wed,08 Apr 2020.14:46:32.363102
Wed,08 Apr 2020.14:46:32.434905       Lines per frame = 625, (625)
Wed,08 Apr 2020.14:46:32.435037
Wed,08 Apr 2020.14:46:32.440855 Actual frame time = 40032683 ns (interlaced), line time = 64052 ns
Wed,08 Apr 2020.14:46:32.440950
Wed,08 Apr 2020.14:46:32.446498 Window: H = 63732 to 64372, V = 19916260 to 20116422, S = Comp
Wed,08 Apr 2020.14:46:32.446648
Wed,08 Apr 2020.14:46:32.473693 Width or Height differ from last FB: Setting dummy 64x64 framebuffer
Wed,08 Apr 2020.14:46:32.473923
Wed,08 Apr 2020.14:46:32.476185 Overscan L=0, R=0, T=1, B=2
Wed,08 Apr 2020.14:46:32.476319
Wed,08 Apr 2020.14:46:32.503861 Initialised Framebuffer
Wed,08 Apr 2020.14:46:32.504080
Wed,08 Apr 2020.14:46:32.505209 Size: 640x532
Wed,08 Apr 2020.14:46:32.505315
Wed,08 Apr 2020.14:46:32.506790 Pitch: 320 bytes
Wed,08 Apr 2020.14:46:32.506912
Wed,08 Apr 2020.14:46:32.509520 Framebuffer address: DE000000
Wed,08 Apr 2020.14:46:32.509657
Wed,08 Apr 2020.14:46:32.542162 RAM benchmark: Main memory = 801090 ns, Screen memory = 26386771 ns
Wed,08 Apr 2020.14:46:32.542387
IanB
Post by IanB »
BeebMaster wrote:
Wed Apr 08, 2020 2:47 pm
Again that doesn't look the right size for the resolution and profile.
Can you first update to the RC9 release as that contains an extra delay on startup which might help.
Then overwrite the kernel.img with this version which now checks that the supplied resolution matches the requested resolution.
Note also with RC9 there are BBC micro and Master 128 profiles so you can switch between them without having to recalibrate every time.
kernelrpi.zip
(117.84 KiB) Downloaded 39 times
Sadly that hasn't helped after both updates. I think we'll just have to put it down to a rogue card.
sudo cat /dev/ttyS0 | ts "%a,%d %b %Y.%.T"
Wed,08 Apr 2020.20:15:49.685968 *******RE********
Wed,08 Apr 2020.20:15:49.686701 RGB to HDMI booted
Wed,08 Apr 2020.20:15:49.686885
Wed,08 Apr 2020.20:15:49.690120 8 bit board NOT detected
Wed,08 Apr 2020.20:15:49.690317
Wed,08 Apr 2020.20:15:49.693094 Using PLLA as the sampling clock
Wed,08 Apr 2020.20:15:49.693300
Wed,08 Apr 2020.20:15:49.696167 PLLA: 2400.000000 ANA1 = 00144000
Wed,08 Apr 2020.20:15:49.696363
Wed,08 Apr 2020.20:15:49.704808 PLLA: PDIV=1 NDIV=62 CTRL=0002103e FRAC=524288 DSI0=256 CORE=2 PER=256 CCP2=256
Wed,08 Apr 2020.20:15:49.705082
Wed,08 Apr 2020.20:15:49.706410 PLLB: 2000.000024 ANA1 = 00144000
Wed,08 Apr 2020.20:15:49.706704
Wed,08 Apr 2020.20:15:49.713200 PLLB: PDIV=1 NDIV=52 CTRL=00021034 FRAC=87382 ARM=2 SP0=256 SP1=256 SP2=256
Wed,08 Apr 2020.20:15:49.713568
Wed,08 Apr 2020.20:15:49.716343 PLLC: 2400.000000, ANA1 = 00144000
Wed,08 Apr 2020.20:15:49.716646
Wed,08 Apr 2020.20:15:49.723562 1=256 PER=2 CORE0=2
Wed,08 Apr 2020.20:15:49.723888
Wed,08 Apr 2020.20:15:49.738943 PLLD: 2000.000024 ANA1 = 00144000
Wed,08 Apr 2020.20:15:49.739221
Wed,08 Apr 2020.20:15:49.739435 PLLD: PDIV=1 NDIV=52 CTRL=00021034 FRAC=87382 DSI0=256 CORE=4 PER=4 DSI1=256
Wed,08 Apr 2020.20:15:49.739600
Wed,08 Apr 2020.20:15:49.739748 PLLH: 864.000000 ANA1 = 00144000
Wed,08 Apr 2020.20:15:49.739907
Wed,08 Apr 2020.20:15:49.743267 PLLH: PDIV=1 NDIV=45 CTRL=0002102d FRAC=0 AUX=4 RCAL=256 PIX=256 STS=527597
Wed,08 Apr 2020.20:15:49.743714
Wed,08 Apr 2020.20:15:49.746294 PLLA: 2400.000000 ANA1 = 00144000
Wed,08 Apr 2020.20:15:49.746549
Wed,08 Apr 2020.20:15:49.753500 PLLA: PDIV=1 NDIV=62 CTRL=0002103e FRAC=524288 DSI0=256 CORE=256 PER=4 CCP2=256
Wed,08 Apr 2020.20:15:49.753787
Wed,08 Apr 2020.20:15:49.756340 CPU speed detected as: 1000 Mhz
Wed,08 Apr 2020.20:15:49.756631
Wed,08 Apr 2020.20:15:49.757544 Keycount = 0
Wed,08 Apr 2020.20:15:49.757824
Wed,08 Apr 2020.20:15:49.759733 CPLD  Design: 3BIT_RGB
Wed,08 Apr 2020.20:15:49.760087
Wed,08 Apr 2020.20:15:49.761361 CPLD Version: 6.6
Wed,08 Apr 2020.20:15:49.761667
Wed,08 Apr 2020.20:15:50.275172 EMMC: BCM2708 controller power-cycled
Wed,08 Apr 2020.20:15:50.951611 Loading file /Palettes/Atom_MKII.bin
Wed,08 Apr 2020.20:15:50.951874
Wed,08 Apr 2020.20:15:50.958976 Loading file /Palettes/Atom_MKII_Full.bin
Wed,08 Apr 2020.20:15:50.959156
Wed,08 Apr 2020.20:15:50.966406 Loading file /Palettes/Atom_MKII_Plus.bin
Wed,08 Apr 2020.20:15:50.966633
Wed,08 Apr 2020.20:15:50.973979 Loading file /Palettes/Colour_Genie_N25.bin
Wed,08 Apr 2020.20:15:50.974212
Wed,08 Apr 2020.20:15:50.981880 Loading file /Palettes/Colour_Genie_S24.bin
Wed,08 Apr 2020.20:15:50.982088
Wed,08 Apr 2020.20:15:50.989774 Loading file /Palettes/Colour_Genie_S25.bin
Wed,08 Apr 2020.20:15:50.990033
Wed,08 Apr 2020.20:15:50.997188 Loading file /Palettes/Dragon-CoCo.bin
Wed,08 Apr 2020.20:15:50.997382
Wed,08 Apr 2020.20:15:51.004379 Loading file /Palettes/Dragon-CoCo_Emu.bin
Wed,08 Apr 2020.20:15:51.004580
Wed,08 Apr 2020.20:15:51.011650 Loading file /Palettes/Dragon-CoCo_Full.bin
Wed,08 Apr 2020.20:15:51.011857
Wed,08 Apr 2020.20:15:51.018612 Loading file /Palettes/MDA-Hercules.bin
Wed,08 Apr 2020.20:15:51.018949
Wed,08 Apr 2020.20:15:51.025794 Loading file /Palettes/Mono_(2_level).bin
Wed,08 Apr 2020.20:15:51.026262
Wed,08 Apr 2020.20:15:51.033087 Loading file /Palettes/Mono_(3_level).bin
Wed,08 Apr 2020.20:15:51.033322
Wed,08 Apr 2020.20:15:51.040471 Loading file /Palettes/Mono_(4_level).bin
Wed,08 Apr 2020.20:15:51.040663
Wed,08 Apr 2020.20:15:51.047884 Loading file /Palettes/Mono_(6_level).bin
Wed,08 Apr 2020.20:15:51.048090
Wed,08 Apr 2020.20:15:51.054653 Loading file /Palettes/RGB.bin
Wed,08 Apr 2020.20:15:51.054889
Wed,08 Apr 2020.20:15:51.060608 Loading file /Palettes/RGBI.bin
Wed,08 Apr 2020.20:15:51.060846
Wed,08 Apr 2020.20:15:51.066979 Loading file /Palettes/RGBI_(CGA).bin
Wed,08 Apr 2020.20:15:51.067184
Wed,08 Apr 2020.20:15:51.073836 Loading file /Palettes/RGBI_(Spectrum).bin
Wed,08 Apr 2020.20:15:51.074059
Wed,08 Apr 2020.20:15:51.080782 Loading file /Palettes/RGBrgb_(Amstrad).bin
Wed,08 Apr 2020.20:15:51.080976
Wed,08 Apr 2020.20:15:51.087870 Loading file /Palettes/RGBrgb_(Spectrum).bin
Wed,08 Apr 2020.20:15:51.088090
Wed,08 Apr 2020.20:15:51.094400 Loading file /Palettes/RrGgBb_(EGA).bin
Wed,08 Apr 2020.20:15:51.094552
Wed,08 Apr 2020.20:15:51.101896 Loading file /Palettes/Spectrum_48K_9Col.bin
Wed,08 Apr 2020.20:15:51.102345
Wed,08 Apr 2020.20:15:51.114278 FOUND RESOLUTION: 1024x600@50Hz
Wed,08 Apr 2020.20:15:51.114451
Wed,08 Apr 2020.20:15:51.117175 FOUND RESOLUTION: 1024x600@60Hz
Wed,08 Apr 2020.20:15:51.117334
Wed,08 Apr 2020.20:15:51.120128 FOUND RESOLUTION: 1024x768@50Hz
Wed,08 Apr 2020.20:15:51.120410
Wed,08 Apr 2020.20:15:51.123016 FOUND RESOLUTION: 1024x768@60Hz
Wed,08 Apr 2020.20:15:51.123319
Wed,08 Apr 2020.20:15:51.126101 FOUND RESOLUTION: 1280x1024@50Hz
Wed,08 Apr 2020.20:15:51.126510
Wed,08 Apr 2020.20:15:51.128946 FOUND RESOLUTION: 1280x1024@60Hz
Wed,08 Apr 2020.20:15:51.129105
Wed,08 Apr 2020.20:15:51.131830 FOUND RESOLUTION: 1280x720@50Hz
Wed,08 Apr 2020.20:15:51.131959
Wed,08 Apr 2020.20:15:51.134725 FOUND RESOLUTION: 1280x720@60Hz
Wed,08 Apr 2020.20:15:51.134840
Wed,08 Apr 2020.20:15:51.137651 FOUND RESOLUTION: 1280x800@50Hz
Wed,08 Apr 2020.20:15:51.137882
Wed,08 Apr 2020.20:15:51.140553 FOUND RESOLUTION: 1280x800@60Hz
Wed,08 Apr 2020.20:15:51.140712
Wed,08 Apr 2020.20:15:51.143445 FOUND RESOLUTION: 1368x768@50Hz
Wed,08 Apr 2020.20:15:51.143601
Wed,08 Apr 2020.20:15:51.146440 FOUND RESOLUTION: 1368x768@60Hz
Wed,08 Apr 2020.20:15:51.146704
Wed,08 Apr 2020.20:15:51.149502 FOUND RESOLUTION: 1600x1200@50Hz
Wed,08 Apr 2020.20:15:51.150013
Wed,08 Apr 2020.20:15:51.152492 FOUND RESOLUTION: 1600x1200@60Hz
Wed,08 Apr 2020.20:15:51.152881
Wed,08 Apr 2020.20:15:51.155308 FOUND RESOLUTION: 1920x1080@50Hz
Wed,08 Apr 2020.20:15:51.155465
Wed,08 Apr 2020.20:15:51.158286 FOUND RESOLUTION: 1920x1080@60Hz
Wed,08 Apr 2020.20:15:51.158412
Wed,08 Apr 2020.20:15:51.161274 FOUND RESOLUTION: 1920x1200@50Hz
Wed,08 Apr 2020.20:15:51.161403
Wed,08 Apr 2020.20:15:51.164260 FOUND RESOLUTION: 1920x1200@60Hz
Wed,08 Apr 2020.20:15:51.164397
Wed,08 Apr 2020.20:15:51.167058 FOUND RESOLUTION: 640x480@50Hz
Wed,08 Apr 2020.20:15:51.167148
Wed,08 Apr 2020.20:15:51.170028 FOUND RESOLUTION: 640x480@60Hz
Wed,08 Apr 2020.20:15:51.170335
Wed,08 Apr 2020.20:15:51.172812 FOUND RESOLUTION: 720x576@50Hz
Wed,08 Apr 2020.20:15:51.173316
Wed,08 Apr 2020.20:15:51.175658 FOUND RESOLUTION: 800x480@50Hz
Wed,08 Apr 2020.20:15:51.176134
Wed,08 Apr 2020.20:15:51.178316 FOUND RESOLUTION: 800x480@60Hz
Wed,08 Apr 2020.20:15:51.178434
Wed,08 Apr 2020.20:15:51.181127 FOUND RESOLUTION: 800x600@50Hz
Wed,08 Apr 2020.20:15:51.181231
Wed,08 Apr 2020.20:15:51.183953 FOUND RESOLUTION: 800x600@60Hz
Wed,08 Apr 2020.20:15:51.184094
Wed,08 Apr 2020.20:15:51.186778 FOUND RESOLUTION: Default@60Hz
Wed,08 Apr 2020.20:15:51.186905
Wed,08 Apr 2020.20:15:51.189325 Loading file /config.txt
Wed,08 Apr 2020.20:15:51.189456
Wed,08 Apr 2020.20:15:51.194197 Read resolution: 1280x800@60Hz
Wed,08 Apr 2020.20:15:51.194358
Wed,08 Apr 2020.20:15:51.197256 Match resolution: 9 1280x800@60Hz
Wed,08 Apr 2020.20:15:51.197355
Wed,08 Apr 2020.20:15:51.198929 Read scaling: 5
Wed,08 Apr 2020.20:15:51.199206
Wed,08 Apr 2020.20:15:51.211766 Loading file: /Profiles/3BIT_RGB/Default.txt
Wed,08 Apr 2020.20:15:51.211889
Wed,08 Apr 2020.20:15:51.261148 FOUND PROFILE: Atom
Wed,08 Apr 2020.20:15:51.261277
Wed,08 Apr 2020.20:15:51.263409 FOUND PROFILE: BBC_Micro
Wed,08 Apr 2020.20:15:51.263504
Wed,08 Apr 2020.20:15:51.266131 FOUND PROFILE: Camputers_Lynx
Wed,08 Apr 2020.20:15:51.266223
Wed,08 Apr 2020.20:15:51.268860 FOUND SUB-FOLDER: Colour Test
Wed,08 Apr 2020.20:15:51.268974
Wed,08 Apr 2020.20:15:51.271403 FOUND PROFILE: Colour_Genie
Wed,08 Apr 2020.20:15:51.271490
Wed,08 Apr 2020.20:15:51.273977 FOUND PROFILE: Communicator
Wed,08 Apr 2020.20:15:51.274104
Wed,08 Apr 2020.20:15:51.277029 FOUND PROFILE: Communicator_Mode7
Wed,08 Apr 2020.20:15:51.277122
Wed,08 Apr 2020.20:15:51.279051 FOUND PROFILE: Custom
Wed,08 Apr 2020.20:15:51.279187
Wed,08 Apr 2020.20:15:51.281247 FOUND PROFILE: Electron
Wed,08 Apr 2020.20:15:51.281338
Wed,08 Apr 2020.20:15:51.283619 FOUND PROFILE: Master_128
Wed,08 Apr 2020.20:15:51.283707
Wed,08 Apr 2020.20:15:51.286520 FOUND PROFILE: Master_128_24MHz
Wed,08 Apr 2020.20:15:51.286612
Wed,08 Apr 2020.20:15:51.288385 FOUND PROFILE: Oric
Wed,08 Apr 2020.20:15:51.288493
Wed,08 Apr 2020.20:15:51.290039 FOUND PROFILE: QL
Wed,08 Apr 2020.20:15:51.290192
Wed,08 Apr 2020.20:15:51.292435 FOUND PROFILE: Station129
Wed,08 Apr 2020.20:15:51.292579
Wed,08 Apr 2020.20:15:51.294628 FOUND PROFILE: Teletext
Wed,08 Apr 2020.20:15:51.294746
Wed,08 Apr 2020.20:15:51.296472 FOUND PROFILE: ZX80
Wed,08 Apr 2020.20:15:51.296575
Wed,08 Apr 2020.20:15:51.299930 Loading file /profile_3BIT_RGB.txt
Wed,08 Apr 2020.20:15:51.300061
Wed,08 Apr 2020.20:15:51.304482 Setting profile to 13
Wed,08 Apr 2020.20:15:51.304614
Wed,08 Apr 2020.20:15:51.313622 Loading file: /Saved_Profiles/3BIT_RGB/Station129.txt
Wed,08 Apr 2020.20:15:51.314027
Wed,08 Apr 2020.20:15:51.318980 Setting subprofile to 0
Wed,08 Apr 2020.20:15:51.319093
Wed,08 Apr 2020.20:15:51.320926 Profile = Station129
Wed,08 Apr 2020.20:15:51.321052
Wed,08 Apr 2020.20:15:51.325331 Analyze Csync: polarity unchanged (non-inverted)
Wed,08 Apr 2020.20:15:51.325485
Wed,08 Apr 2020.20:15:51.402254 Detected polarity state at startup = Comp (Separate H & V CPLD)
Wed,08 Apr 2020.20:15:51.402379
Wed,08 Apr 2020.20:15:51.408674 Keycount = 0
Wed,08 Apr 2020.20:15:51.408759
Wed,08 Apr 2020.20:15:51.414387 -----------------------LOOP------------------------
Wed,08 Apr 2020.20:15:51.414527
Wed,08 Apr 2020.20:15:51.417741 Analyze Csync: polarity unchanged (non-inverted)
Wed,08 Apr 2020.20:15:51.417862
Wed,08 Apr 2020.20:15:51.422734 Detected polarity state = 4, Comp (Separate H & V CPLD)
Wed,08 Apr 2020.20:15:51.422866
Wed,08 Apr 2020.20:15:51.430718         clkinfo.clock = 12000000 Hz
Wed,08 Apr 2020.20:15:51.430853
Wed,08 Apr 2020.20:15:51.433246      clkinfo.line_len = 768
Wed,08 Apr 2020.20:15:51.433381
Wed,08 Apr 2020.20:15:51.436237     clkinfo.clock_ppm = 5000 ppm
Wed,08 Apr 2020.20:15:51.436361
Wed,08 Apr 2020.20:15:51.458347     Nominal 100 lines = 6400000 ns
Wed,08 Apr 2020.20:15:51.458463
Wed,08 Apr 2020.20:15:51.461485      Actual 100 lines = 6405276 ns
Wed,08 Apr 2020.20:15:51.461600
Wed,08 Apr 2020.20:15:51.464771           Clock error = 824 PPM
Wed,08 Apr 2020.20:15:51.464904
Wed,08 Apr 2020.20:15:51.467665  Error adjusted clock = 11990115 Hz
Wed,08 Apr 2020.20:15:51.467802
Wed,08 Apr 2020.20:15:51.472945  Target PLL frequency = 2302102200 Hz, prediv = 1, PER = 4
Wed,08 Apr 2020.20:15:51.473089
Wed,08 Apr 2020.20:15:51.476361  Actual PLL frequency = 2302102200 Hz
Wed,08 Apr 2020.20:15:51.476486
Wed,08 Apr 2020.20:15:51.478875         GPCLK Divisor = 6
Wed,08 Apr 2020.20:15:51.479120
Wed,08 Apr 2020.20:15:51.551075       Lines per frame = 625, (624.994)
Wed,08 Apr 2020.20:15:51.551198
Wed,08 Apr 2020.20:15:51.557030 Actual frame time = 40033048 ns (interlaced), line time = 64053 ns
Wed,08 Apr 2020.20:15:51.557113
Wed,08 Apr 2020.20:15:51.562664 Window: H = 63733 to 64373, V = 19916442 to 20116606, S = Comp
Wed,08 Apr 2020.20:15:51.562771
Wed,08 Apr 2020.20:15:51.589848 Width or Height differ from last FB: Setting dummy 64x64 framebuffer
Wed,08 Apr 2020.20:15:51.590053
Wed,08 Apr 2020.20:15:51.592368 Overscan L=0, R=0, T=0, B=0
Wed,08 Apr 2020.20:15:51.592506
Wed,08 Apr 2020.20:15:51.623792 Initialised Framebuffer
Wed,08 Apr 2020.20:15:51.623999
Wed,08 Apr 2020.20:15:51.626912 Size: 576x288 (requested 576x288)
Wed,08 Apr 2020.20:15:51.627189
Wed,08 Apr 2020.20:15:51.628482 Pitch: 288 bytes
Wed,08 Apr 2020.20:15:51.628759
Wed,08 Apr 2020.20:15:51.631290 Framebuffer address: DE000000
Wed,08 Apr 2020.20:15:51.631741
IanB
Post by IanB »
BeebMaster wrote:
Wed Apr 08, 2020 8:19 pm
Can you post the log before and after pressing reset and also your custom profile.
Right. Here it is with 4:3 scaling, where it doesn't display anything on screen, until I press reset. The full whack from Brr Beep to picture:
Thu,09 Apr 2020.12:48:02.944276
Thu,09 Apr 2020.12:48:02.945891 RGB to HDMI booted
Thu,09 Apr 2020.12:48:02.946067
Thu,09 Apr 2020.12:48:02.949291 8 bit board NOT detected
Thu,09 Apr 2020.12:48:02.949435
Thu,09 Apr 2020.12:48:02.952273 Using PLLA as the sampling clock
Thu,09 Apr 2020.12:48:02.952411
Thu,09 Apr 2020.12:48:02.955346 PLLA: 2400.000000 ANA1 = 00144000
Thu,09 Apr 2020.12:48:02.955477
Thu,09 Apr 2020.12:48:02.962494 PLLA: PDIV=1 NDIV=62 CTRL=0002103e FRAC=524288 DSI0=256 CORE=2 PER=256 CCP2=256
Thu,09 Apr 2020.12:48:02.962688
Thu,09 Apr 2020.12:48:02.965541 PLLB: 2000.000024 ANA1 = 00144000
Thu,09 Apr 2020.12:48:02.965675
Thu,09 Apr 2020.12:48:02.972334 PLLB: PDIV=1 NDIV=52 CTRL=00021034 FRAC=87382 ARM=2 SP0=256 SP1=256 SP2=256
Thu,09 Apr 2020.12:48:02.972522
Thu,09 Apr 2020.12:48:02.975494 PLLC: 2400.000000, ANA1 = 00144000
Thu,09 Apr 2020.12:48:02.975695
Thu,09 Apr 2020.12:48:02.982742 PLLC: PDIV=1 NDIV=62 CTRL=0002103e FRAC=524288 CORE2=256 CORE1=256 PER=2 CORE0=2
Thu,09 Apr 2020.12:48:02.982942
Thu,09 Apr 2020.12:48:02.985762 PLLD: 2000.000024 ANA1 = 00144000
Thu,09 Apr 2020.12:48:02.985896
Thu,09 Apr 2020.12:48:02.992632 PLLD: PDIV=1 NDIV=52 CTRL=00021034 FRAC=87382 DSI0=256 CORE=4 PER=4 DSI1=256
Thu,09 Apr 2020.12:48:02.992806
Thu,09 Apr 2020.12:48:02.995596 PLLH: 864.000000 ANA1 = 00144000
Thu,09 Apr 2020.12:48:02.995732
Thu,09 Apr 2020.12:48:03.002427 PLLH: PDIV=1 NDIV=45 CTRL=0002102d FRAC=0 AUX=4 RCAL=256 PIX=256 STS=527597
Thu,09 Apr 2020.12:48:03.002647
Thu,09 Apr 2020.12:48:03.005484 PLLA: 2400.000000 ANA1 = 00144000
Thu,09 Apr 2020.12:48:03.005703
Thu,09 Apr 2020.12:48:03.012630 PLLA: PDIV=1 NDIV=62 CTRL=0002103e FRAC=524288 DSI0=256 CORE=256 PER=4 CCP2=256
Thu,09 Apr 2020.12:48:03.012884
Thu,09 Apr 2020.12:48:03.015562 CPU speed detected as: 1000 Mhz
Thu,09 Apr 2020.12:48:03.015828
Thu,09 Apr 2020.12:48:03.016764 Keycount = 0
Thu,09 Apr 2020.12:48:03.017034
Thu,09 Apr 2020.12:48:03.018800 CPLD  Design: 3BIT_RGB
Thu,09 Apr 2020.12:48:03.018932
Thu,09 Apr 2020.12:48:03.020470 CPLD Version: 6.6
Thu,09 Apr 2020.12:48:03.020606
Thu,09 Apr 2020.12:48:03.534421 EMMC: BCM2708 controller power-cycled
Thu,09 Apr 2020.12:48:03.534658
Thu,09 Apr 2020.12:48:04.210894 Loading file /Palettes/Atom_MKII.bin
Thu,09 Apr 2020.12:48:04.211152
Thu,09 Apr 2020.12:48:04.218262 Loading file /Palettes/Atom_MKII_Full.bin
Thu,09 Apr 2020.12:48:04.218428
Thu,09 Apr 2020.12:48:04.225794 Loading file /Palettes/Atom_MKII_Plus.bin
Thu,09 Apr 2020.12:48:04.226018
Thu,09 Apr 2020.12:48:04.233246 Loading file /Palettes/Colour_Genie_N25.bin
Thu,09 Apr 2020.12:48:04.233397
Thu,09 Apr 2020.12:48:04.241160 Loading file /Palettes/Colour_Genie_S24.bin
Thu,09 Apr 2020.12:48:04.241356
Thu,09 Apr 2020.12:48:04.249104 Loading file /Palettes/Colour_Genie_S25.bin
Thu,09 Apr 2020.12:48:04.249292
Thu,09 Apr 2020.12:48:04.256472 Loading file /Palettes/Dragon-CoCo.bin
Thu,09 Apr 2020.12:48:04.256611
Thu,09 Apr 2020.12:48:04.263673 Loading file /Palettes/Dragon-CoCo_Emu.bin
Thu,09 Apr 2020.12:48:04.263843
Thu,09 Apr 2020.12:48:04.270933 Loading file /Palettes/Dragon-CoCo_Full.bin
Thu,09 Apr 2020.12:48:04.271068
Thu,09 Apr 2020.12:48:04.277894 Loading file /Palettes/MDA-Hercules.bin
Thu,09 Apr 2020.12:48:04.278089
Thu,09 Apr 2020.12:48:04.284987 Loading file /Palettes/Mono_(2_level).bin
Thu,09 Apr 2020.12:48:04.285196
Thu,09 Apr 2020.12:48:04.292376 Loading file /Palettes/Mono_(3_level).bin
Thu,09 Apr 2020.12:48:04.292592
Thu,09 Apr 2020.12:48:04.299796 Loading file /Palettes/Mono_(4_level).bin
Thu,09 Apr 2020.12:48:04.300008
Thu,09 Apr 2020.12:48:04.310912 Loading file /Palettes/Mono_(6_level).bin
Thu,09 Apr 2020.12:48:04.311155
Thu,09 Apr 2020.12:48:04.313999 Loading file /Palettes/RGB.bin
Thu,09 Apr 2020.12:48:04.314262
Thu,09 Apr 2020.12:48:04.319941 Loading file /Palettes/RGBI.bin
Thu,09 Apr 2020.12:48:04.320485
Thu,09 Apr 2020.12:48:04.326365 Loading file /Palettes/RGBI_(CGA).bin
Thu,09 Apr 2020.12:48:04.326571
Thu,09 Apr 2020.12:48:04.333118 Loading file /Palettes/RGBI_(Spectrum).bin
Thu,09 Apr 2020.12:48:04.333251
Thu,09 Apr 2020.12:48:04.340080 Loading file /Palettes/RGBrgb_(Amstrad).bin
Thu,09 Apr 2020.12:48:04.340244
Thu,09 Apr 2020.12:48:04.347255 Loading file /Palettes/RGBrgb_(Spectrum).bin
Thu,09 Apr 2020.12:48:04.347791
Thu,09 Apr 2020.12:48:04.353761 Loading file /Palettes/RrGgBb_(EGA).bin
Thu,09 Apr 2020.12:48:04.353950
Thu,09 Apr 2020.12:48:04.361211 Loading file /Palettes/Spectrum_48K_9Col.bin
Thu,09 Apr 2020.12:48:04.361706
Thu,09 Apr 2020.12:48:04.373663 FOUND RESOLUTION: 1024x600@50Hz
Thu,09 Apr 2020.12:48:04.374135
Thu,09 Apr 2020.12:48:04.376580 FOUND RESOLUTION: 1024x600@60Hz
Thu,09 Apr 2020.12:48:04.376719
Thu,09 Apr 2020.12:48:04.379411 FOUND RESOLUTION: 1024x768@50Hz
Thu,09 Apr 2020.12:48:04.379611
Thu,09 Apr 2020.12:48:04.382306 FOUND RESOLUTION: 1024x768@60Hz
Thu,09 Apr 2020.12:48:04.382427
Thu,09 Apr 2020.12:48:04.385296 FOUND RESOLUTION: 1280x1024@50Hz
Thu,09 Apr 2020.12:48:04.385424
Thu,09 Apr 2020.12:48:04.388274 FOUND RESOLUTION: 1280x1024@60Hz
Thu,09 Apr 2020.12:48:04.388389
Thu,09 Apr 2020.12:48:04.391180 FOUND RESOLUTION: 1280x720@50Hz
Thu,09 Apr 2020.12:48:04.391298
Thu,09 Apr 2020.12:48:04.394143 FOUND RESOLUTION: 1280x720@60Hz
Thu,09 Apr 2020.12:48:04.394383
Thu,09 Apr 2020.12:48:04.397042 FOUND RESOLUTION: 1280x800@50Hz
Thu,09 Apr 2020.12:48:04.397233
Thu,09 Apr 2020.12:48:04.399984 FOUND RESOLUTION: 1280x800@60Hz
Thu,09 Apr 2020.12:48:04.400243
Thu,09 Apr 2020.12:48:04.402791 FOUND RESOLUTION: 1368x768@50Hz
Thu,09 Apr 2020.12:48:04.402919
Thu,09 Apr 2020.12:48:04.405678 FOUND RESOLUTION: 1368x768@60Hz
Thu,09 Apr 2020.12:48:04.405799
Thu,09 Apr 2020.12:48:04.408672 FOUND RESOLUTION: 1600x1200@50Hz
Thu,09 Apr 2020.12:48:04.408793
Thu,09 Apr 2020.12:48:04.411666 FOUND RESOLUTION: 1600x1200@60Hz
Thu,09 Apr 2020.12:48:04.411804
Thu,09 Apr 2020.12:48:04.414649 FOUND RESOLUTION: 1920x1080@50Hz
Thu,09 Apr 2020.12:48:04.414775
Thu,09 Apr 2020.12:48:04.417632 FOUND RESOLUTION: 1920x1080@60Hz
Thu,09 Apr 2020.12:48:04.417759
Thu,09 Apr 2020.12:48:04.420631 FOUND RESOLUTION: 1920x1200@50Hz
Thu,09 Apr 2020.12:48:04.420769
Thu,09 Apr 2020.12:48:04.423606 FOUND RESOLUTION: 1920x1200@60Hz
Thu,09 Apr 2020.12:48:04.423722
Thu,09 Apr 2020.12:48:04.426449 FOUND RESOLUTION: 640x480@50Hz
Thu,09 Apr 2020.12:48:04.426662
Thu,09 Apr 2020.12:48:04.429280 FOUND RESOLUTION: 640x480@60Hz
Thu,09 Apr 2020.12:48:04.429537
Thu,09 Apr 2020.12:48:04.432165 FOUND RESOLUTION: 720x576@50Hz
Thu,09 Apr 2020.12:48:04.432518
Thu,09 Apr 2020.12:48:04.434870 FOUND RESOLUTION: 800x480@50Hz
Thu,09 Apr 2020.12:48:04.434998
Thu,09 Apr 2020.12:48:04.437661 FOUND RESOLUTION: 800x480@60Hz
Thu,09 Apr 2020.12:48:04.437767
Thu,09 Apr 2020.12:48:04.440463 FOUND RESOLUTION: 800x600@50Hz
Thu,09 Apr 2020.12:48:04.440541
Thu,09 Apr 2020.12:48:04.443313 FOUND RESOLUTION: 800x600@60Hz
Thu,09 Apr 2020.12:48:04.443443
Thu,09 Apr 2020.12:48:04.446124 FOUND RESOLUTION: Default@60Hz
Thu,09 Apr 2020.12:48:04.446284
Thu,09 Apr 2020.12:48:04.448671 Loading file /config.txt
Thu,09 Apr 2020.12:48:04.448785
Thu,09 Apr 2020.12:48:04.453470 Read resolution: 800x600@60Hz
Thu,09 Apr 2020.12:48:04.453619
Thu,09 Apr 2020.12:48:04.456528 Match resolution: 24 800x600@60Hz
Thu,09 Apr 2020.12:48:04.456649
Thu,09 Apr 2020.12:48:04.458008 Read scaling: 3
Thu,09 Apr 2020.12:48:04.458100
Thu,09 Apr 2020.12:48:04.471031 Loading file: /Profiles/3BIT_RGB/Default.txt
Thu,09 Apr 2020.12:48:04.471153
Thu,09 Apr 2020.12:48:04.520437 FOUND PROFILE: Atom
Thu,09 Apr 2020.12:48:04.520565
Thu,09 Apr 2020.12:48:04.522695 FOUND PROFILE: BBC_Micro
Thu,09 Apr 2020.12:48:04.522781
Thu,09 Apr 2020.12:48:04.525429 FOUND PROFILE: Camputers_Lynx
Thu,09 Apr 2020.12:48:04.525523
Thu,09 Apr 2020.12:48:04.528141 FOUND SUB-FOLDER: Colour Test
Thu,09 Apr 2020.12:48:04.528228
Thu,09 Apr 2020.12:48:04.530690 FOUND PROFILE: Colour_Genie
Thu,09 Apr 2020.12:48:04.530788
Thu,09 Apr 2020.12:48:04.533270 FOUND PROFILE: Communicator
Thu,09 Apr 2020.12:48:04.533408
Thu,09 Apr 2020.12:48:04.536320 FOUND PROFILE: Communicator_Mode7
Thu,09 Apr 2020.12:48:04.536405
Thu,09 Apr 2020.12:48:04.538372 FOUND PROFILE: Custom
Thu,09 Apr 2020.12:48:04.538486
Thu,09 Apr 2020.12:48:04.540559 FOUND PROFILE: Electron
Thu,09 Apr 2020.12:48:04.540683
Thu,09 Apr 2020.12:48:04.542914 FOUND PROFILE: Master_128
Thu,09 Apr 2020.12:48:04.543005
Thu,09 Apr 2020.12:48:04.545803 FOUND PROFILE: Master_128_24MHz
Thu,09 Apr 2020.12:48:04.545902
Thu,09 Apr 2020.12:48:04.547673 FOUND PROFILE: Oric
Thu,09 Apr 2020.12:48:04.547781
Thu,09 Apr 2020.12:48:04.549322 FOUND PROFILE: QL
Thu,09 Apr 2020.12:48:04.549446
Thu,09 Apr 2020.12:48:04.551723 FOUND PROFILE: Station129
Thu,09 Apr 2020.12:48:04.551867
Thu,09 Apr 2020.12:48:04.553911 FOUND PROFILE: Teletext
Thu,09 Apr 2020.12:48:04.554036
Thu,09 Apr 2020.12:48:04.555757 FOUND PROFILE: ZX80
Thu,09 Apr 2020.12:48:04.555889
Thu,09 Apr 2020.12:48:04.559208 Loading file /profile_3BIT_RGB.txt
Thu,09 Apr 2020.12:48:04.559344
Thu,09 Apr 2020.12:48:04.563758 Setting profile to 13
Thu,09 Apr 2020.12:48:04.563883
Thu,09 Apr 2020.12:48:04.572861 Loading file: /Saved_Profiles/3BIT_RGB/Station129.txt
Thu,09 Apr 2020.12:48:04.573353
Thu,09 Apr 2020.12:48:04.578266 Setting subprofile to 0
Thu,09 Apr 2020.12:48:04.578386
Thu,09 Apr 2020.12:48:04.580211 Profile = Station129
Thu,09 Apr 2020.12:48:04.580338
Thu,09 Apr 2020.12:48:04.584609 Analyze Csync: polarity unchanged (non-inverted)
Thu,09 Apr 2020.12:48:04.584777
Thu,09 Apr 2020.12:48:04.661533 Detected polarity state at startup = Comp (Separate H & V CPLD)
Thu,09 Apr 2020.12:48:04.661664
Thu,09 Apr 2020.12:48:04.681200 Keycount = 0
Thu,09 Apr 2020.12:48:04.681332
Thu,09 Apr 2020.12:48:04.685825 -----------------------LOOP------------------------
Thu,09 Apr 2020.12:48:04.685906
Thu,09 Apr 2020.12:48:04.690235 Analyze Csync: polarity unchanged (non-inverted)
Thu,09 Apr 2020.12:48:04.690349
Thu,09 Apr 2020.12:48:04.695271 Detected polarity state = 4, Comp (Separate H & V CPLD)
Thu,09 Apr 2020.12:48:04.695427
Thu,09 Apr 2020.12:48:04.703213         clkinfo.clock = 12000000 Hz
Thu,09 Apr 2020.12:48:04.703359
Thu,09 Apr 2020.12:48:04.705748      clkinfo.line_len = 768
Thu,09 Apr 2020.12:48:04.705916
Thu,09 Apr 2020.12:48:04.708776     clkinfo.clock_ppm = 5000 ppm
Thu,09 Apr 2020.12:48:04.709071
Thu,09 Apr 2020.12:48:04.730854     Nominal 100 lines = 6400000 ns
Thu,09 Apr 2020.12:48:04.731008
Thu,09 Apr 2020.12:48:04.734001      Actual 100 lines = 6405229 ns
Thu,09 Apr 2020.12:48:04.734121
Thu,09 Apr 2020.12:48:04.736988           Clock error = 817 PPM
Thu,09 Apr 2020.12:48:04.737203
Thu,09 Apr 2020.12:48:04.740195  Error adjusted clock = 11990203 Hz
Thu,09 Apr 2020.12:48:04.740409
Thu,09 Apr 2020.12:48:04.745442  Target PLL frequency = 2302119096 Hz, prediv = 1, PER = 4
Thu,09 Apr 2020.12:48:04.745566
Thu,09 Apr 2020.12:48:04.748845  Actual PLL frequency = 2302119096 Hz
Thu,09 Apr 2020.12:48:04.748945
Thu,09 Apr 2020.12:48:04.751204         GPCLK Divisor = 6
Thu,09 Apr 2020.12:48:04.751294
Thu,09 Apr 2020.12:48:04.823215       Lines per frame = 625, (625)
Thu,09 Apr 2020.12:48:04.823326
Thu,09 Apr 2020.12:48:04.829185 Actual frame time = 40032678 ns (interlaced), line time = 64052 ns
Thu,09 Apr 2020.12:48:04.829277
Thu,09 Apr 2020.12:48:04.834811 Window: H = 63732 to 64372, V = 19916258 to 20116420, S = Comp
Thu,09 Apr 2020.12:48:04.834913
Thu,09 Apr 2020.12:48:04.861986 Width or Height differ from last FB: Setting dummy 64x64 framebuffer
Thu,09 Apr 2020.12:48:04.862150
Thu,09 Apr 2020.12:48:04.864536 Overscan L=0, R=0, T=0, B=0
Thu,09 Apr 2020.12:48:04.864692
Thu,09 Apr 2020.12:48:04.896203 Initialised Framebuffer
Thu,09 Apr 2020.12:48:04.896376
Thu,09 Apr 2020.12:48:04.899462 Size: 1296x288 (requested 1296x288)
Thu,09 Apr 2020.12:48:04.899683
Thu,09 Apr 2020.12:48:04.901038 Pitch: 656 bytes
Thu,09 Apr 2020.12:48:04.901241
Thu,09 Apr 2020.12:48:04.903848 Framebuffer address: DE000000
Thu,09 Apr 2020.12:48:04.904185
Thu,09 Apr 2020.12:48:04.936388 RAM benchmark: Main memory = 801335 ns, Screen memory = 26339574 ns
Thu,09 Apr 2020.12:48:04.936712
Thu,09 Apr 2020.12:48:16.929065 ***********************RESET***********************
Thu,09 Apr 2020.12:48:16.929327
Thu,09 Apr 2020.12:48:16.930828
Thu,09 Apr 2020.12:48:16.934193 8 bit board NOT detected
Thu,09 Apr 2020.12:48:16.934425
Thu,09 Apr 2020.12:48:16.937182 Using PLLA as the sampling clock
Thu,09 Apr 2020.12:48:16.937420
Thu,09 Apr 2020.12:48:16.940231 PLLA: 2400.000000 ANA1 = 00144000
Thu,09 Apr 2020.12:48:16.940450
Thu,09 Apr 2020.12:48:16.947377 PLLA: PDIV=1 NDIV=62 CTRL=0002103e FRAC=524288 DSI0=256 CORE=2 PER=256 CCP2=256
Thu,09 Apr 2020.12:48:16.947637
Thu,09 Apr 2020.12:48:16.950429 PLLB: 2000.000024 ANA1 = 00144000
Thu,09 Apr 2020.12:48:16.950654
Thu,09 Apr 2020.12:48:16.957192 PLLB: PDIV=1 NDIV=52 CTRL=00021034 FRAC=87382 ARM=2 SP0=256 SP1=256 SP2=256
Thu,09 Apr 2020.12:48:16.957382
Thu,09 Apr 2020.12:48:16.960363 PLLC: 2400.000000, ANA1 = 00144000
Thu,09 Apr 2020.12:48:16.960606
Thu,09 Apr 2020.12:48:16.967574 PLLC: PDIV=1 NDIV=62 CTRL=0002103e FRAC=524288 CORE2=256 CORE1=256 PER=2 CORE0=2
Thu,09 Apr 2020.12:48:16.967793
Thu,09 Apr 2020.12:48:16.970631 PLLD: 2000.000024 ANA1 = 00144000
Thu,09 Apr 2020.12:48:16.970826
Thu,09 Apr 2020.12:48:16.977503 PLLD: PDIV=1 NDIV=52 CTRL=00021034 FRAC=87382 DSI0=256 CORE=4 PER=4 DSI1=256
Thu,09 Apr 2020.12:48:16.977728
Thu,09 Apr 2020.12:48:16.980492 PLLH: 800.000006 ANA1 = 00144000
Thu,09 Apr 2020.12:48:16.980744
Thu,09 Apr 2020.12:48:16.987687 PLLH: PDIV=1 NDIV=41 CTRL=00021029 FRAC=699051 AUX=256 RCAL=256 PIX=2 STS=527599
Thu,09 Apr 2020.12:48:16.987890
Thu,09 Apr 2020.12:48:16.990766 PLLA: 2400.000000 ANA1 = 00144000
Thu,09 Apr 2020.12:48:16.990962
Thu,09 Apr 2020.12:48:16.997924 PLLA: PDIV=1 NDIV=62 CTRL=0002103e FRAC=524288 DSI0=256 CORE=256 PER=4 CCP2=256
Thu,09 Apr 2020.12:48:16.998191
Thu,09 Apr 2020.12:48:17.000791 CPU speed detected as: 1000 Mhz
Thu,09 Apr 2020.12:48:17.001073
Thu,09 Apr 2020.12:48:17.002016 Keycount = 0
Thu,09 Apr 2020.12:48:17.002197
Thu,09 Apr 2020.12:48:17.004122 CPLD  Design: 3BIT_RGB
Thu,09 Apr 2020.12:48:17.004351
Thu,09 Apr 2020.12:48:17.005795 CPLD Version: 6.6
Thu,09 Apr 2020.12:48:17.006004
Thu,09 Apr 2020.12:48:17.519636 EMMC: BCM2708 controller power-cycled
Thu,09 Apr 2020.12:48:17.519761
Thu,09 Apr 2020.12:48:18.196286
Thu,09 Apr 2020.12:48:18.203528 Loading file /Palettes/Atom_MKII_Full.bin
Thu,09 Apr 2020.12:48:18.203699
Thu,09 Apr 2020.12:48:18.210959 Loading file /Palettes/Atom_MKII_Plus.bin
Thu,09 Apr 2020.12:48:18.211200
Thu,09 Apr 2020.12:48:18.218535 Loading file /Palettes/Colour_Genie_N25.bin
Thu,09 Apr 2020.12:48:18.218762
Thu,09 Apr 2020.12:48:18.226435 Loading file /Palettes/Colour_Genie_S24.bin
Thu,09 Apr 2020.12:48:18.226669
Thu,09 Apr 2020.12:48:18.234319 Loading file /Palettes/Colour_Genie_S25.bin
Thu,09 Apr 2020.12:48:18.234534
Thu,09 Apr 2020.12:48:18.241761 Loading file /Palettes/Dragon-CoCo.bin
Thu,09 Apr 2020.12:48:18.241964
Thu,09 Apr 2020.12:48:18.248962 Loading file /Palettes/Dragon-CoCo_Emu.bin
Thu,09 Apr 2020.12:48:18.249243
Thu,09 Apr 2020.12:48:18.256238 Loading file /Palettes/Dragon-CoCo_Full.bin
Thu,09 Apr 2020.12:48:18.256476
Thu,09 Apr 2020.12:48:18.263168 Loading file /Palettes/MDA-Hercules.bin
Thu,09 Apr 2020.12:48:18.263426
Thu,09 Apr 2020.12:48:18.270267 Loading file /Palettes/Mono_(2_level).bin
Thu,09 Apr 2020.12:48:18.270516
Thu,09 Apr 2020.12:48:18.277678 Loading file /Palettes/Mono_(3_level).bin
Thu,09 Apr 2020.12:48:18.278157
Thu,09 Apr 2020.12:48:18.285054 Loading file /Palettes/Mono_(4_level).bin
Thu,09 Apr 2020.12:48:18.285266
Thu,09 Apr 2020.12:48:18.292464 Loading file /Palettes/Mono_(6_level).bin
Thu,09 Apr 2020.12:48:18.292686
Thu,09 Apr 2020.12:48:18.299213 Loading file /Palettes/RGB.bin
Thu,09 Apr 2020.12:48:18.299424
Thu,09 Apr 2020.12:48:18.305114 Loading file /Palettes/RGBI.bin
Thu,09 Apr 2020.12:48:18.305323
Thu,09 Apr 2020.12:48:18.311552 Loading file /Palettes/RGBI_(CGA).bin
Thu,09 Apr 2020.12:48:18.311784
Thu,09 Apr 2020.12:48:18.318445 Loading file /Palettes/RGBI_(Spectrum).bin
Thu,09 Apr 2020.12:48:18.318689
Thu,09 Apr 2020.12:48:18.325729 Loading file /Palettes/RGBrgb_(Amstrad).bin
Thu,09 Apr 2020.12:48:18.325955
Thu,09 Apr 2020.12:48:18.332446 Loading file /Palettes/RGBrgb_(Spectrum).bin
Thu,09 Apr 2020.12:48:18.332663
Thu,09 Apr 2020.12:48:18.339141 Loading file /Palettes/RrGgBb_(EGA).bin
Thu,09 Apr 2020.12:48:18.339361
Thu,09 Apr 2020.12:48:18.346393 Loading file /Palettes/Spectrum_48K_9Col.bin
Thu,09 Apr 2020.12:48:18.346577
Thu,09 Apr 2020.12:48:18.358892 FOUND RESOLUTION: 1024x600@50Hz
Thu,09 Apr 2020.12:48:18.359076
Thu,09 Apr 2020.12:48:18.361793 FOUND RESOLUTION: 1024x600@60Hz
Thu,09 Apr 2020.12:48:18.361940
Thu,09 Apr 2020.12:48:18.364681 FOUND RESOLUTION: 1024x768@50Hz
Thu,09 Apr 2020.12:48:18.364810
Thu,09 Apr 2020.12:48:18.367589 FOUND RESOLUTION: 1024x768@60Hz
Thu,09 Apr 2020.12:48:18.367734
Thu,09 Apr 2020.12:48:18.370583 FOUND RESOLUTION: 1280x1024@50Hz
Thu,09 Apr 2020.12:48:18.370724
Thu,09 Apr 2020.12:48:18.373602 FOUND RESOLUTION: 1280x1024@60Hz
Thu,09 Apr 2020.12:48:18.373902
Thu,09 Apr 2020.12:48:18.376501 FOUND RESOLUTION: 1280x720@50Hz
Thu,09 Apr 2020.12:48:18.376740
Thu,09 Apr 2020.12:48:18.379451 FOUND RESOLUTION: 1280x720@60Hz
Thu,09 Apr 2020.12:48:18.379576
Thu,09 Apr 2020.12:48:18.382422 FOUND RESOLUTION: 1280x800@50Hz
Thu,09 Apr 2020.12:48:18.382738
Thu,09 Apr 2020.12:48:18.385165 FOUND RESOLUTION: 1280x800@60Hz
Thu,09 Apr 2020.12:48:18.385302
Thu,09 Apr 2020.12:48:18.388059 FOUND RESOLUTION: 1368x768@50Hz
Thu,09 Apr 2020.12:48:18.388175
Thu,09 Apr 2020.12:48:18.390962 FOUND RESOLUTION: 1368x768@60Hz
Thu,09 Apr 2020.12:48:18.391092
Thu,09 Apr 2020.12:48:18.393970 FOUND RESOLUTION: 1600x1200@50Hz
Thu,09 Apr 2020.12:48:18.394131
Thu,09 Apr 2020.12:48:18.396919 FOUND RESOLUTION: 1600x1200@60Hz
Thu,09 Apr 2020.12:48:18.397018
Thu,09 Apr 2020.12:48:18.399977 FOUND RESOLUTION: 1920x1080@50Hz
Thu,09 Apr 2020.12:48:18.400291
Thu,09 Apr 2020.12:48:18.403061 FOUND RESOLUTION: 1920x1080@60Hz
Thu,09 Apr 2020.12:48:18.403430
Thu,09 Apr 2020.12:48:18.406059 FOUND RESOLUTION: 1920x1200@50Hz
Thu,09 Apr 2020.12:48:18.406314
Thu,09 Apr 2020.12:48:18.409230 FOUND RESOLUTION: 1920x1200@60Hz
Thu,09 Apr 2020.12:48:18.409370
Thu,09 Apr 2020.12:48:18.411698 FOUND RESOLUTION: 640x480@50Hz
Thu,09 Apr 2020.12:48:18.411803
Thu,09 Apr 2020.12:48:18.414509 FOUND RESOLUTION: 640x480@60Hz
Thu,09 Apr 2020.12:48:18.414624
Thu,09 Apr 2020.12:48:18.417327 FOUND RESOLUTION: 720x576@50Hz
Thu,09 Apr 2020.12:48:18.417436
Thu,09 Apr 2020.12:48:18.420124 FOUND RESOLUTION: 800x480@50Hz
Thu,09 Apr 2020.12:48:18.420223
Thu,09 Apr 2020.12:48:18.423006 FOUND RESOLUTION: 800x480@60Hz
Thu,09 Apr 2020.12:48:18.423218
Thu,09 Apr 2020.12:48:18.426149 FOUND RESOLUTION: 800x600@50Hz
Thu,09 Apr 2020.12:48:18.426580
Thu,09 Apr 2020.12:48:18.428730 FOUND RESOLUTION: 800x600@60Hz
Thu,09 Apr 2020.12:48:18.429247
Thu,09 Apr 2020.12:48:18.431380 FOUND RESOLUTION: Default@60Hz
Thu,09 Apr 2020.12:48:18.431490
Thu,09 Apr 2020.12:48:18.433925 Loading file /config.txt
Thu,09 Apr 2020.12:48:18.434027
Thu,09 Apr 2020.12:48:18.438751 Read resolution: 800x600@60Hz
Thu,09 Apr 2020.12:48:18.438917
Thu,09 Apr 2020.12:48:18.441818 Match resolution: 24 800x600@60Hz
Thu,09 Apr 2020.12:48:18.441946
Thu,09 Apr 2020.12:48:18.443306 Read scaling: 3
Thu,09 Apr 2020.12:48:18.443441
Thu,09 Apr 2020.12:48:18.456327 Loading file: /Profiles/3BIT_RGB/Default.txt
Thu,09 Apr 2020.12:48:18.456448
Thu,09 Apr 2020.12:48:18.505698 FOUND PROFILE: Atom
Thu,09 Apr 2020.12:48:18.505822
Thu,09 Apr 2020.12:48:18.507956 FOUND PROFILE: BBC_Micro
Thu,09 Apr 2020.12:48:18.508092
Thu,09 Apr 2020.12:48:18.510692 FOUND PROFILE: Camputers_Lynx
Thu,09 Apr 2020.12:48:18.510920
Thu,09 Apr 2020.12:48:18.513401 FOUND SUB-FOLDER: Colour Test
Thu,09 Apr 2020.12:48:18.513517
Thu,09 Apr 2020.12:48:18.515948 FOUND PROFILE: Colour_Genie
Thu,09 Apr 2020.12:48:18.517715
Thu,09 Apr 2020.12:48:18.518536 FOUND PROFILE: Communicator
Thu,09 Apr 2020.12:48:18.518661
Thu,09 Apr 2020.12:48:18.521592 FOUND PROFILE: Communicator_Mode7
Thu,09 Apr 2020.12:48:18.521687
Thu,09 Apr 2020.12:48:18.523595 FOUND PROFILE: Custom
Thu,09 Apr 2020.12:48:18.523678
Thu,09 Apr 2020.12:48:18.525792 FOUND PROFILE: Electron
Thu,09 Apr 2020.12:48:18.525961
Thu,09 Apr 2020.12:48:18.528168 FOUND PROFILE: Master_128
Thu,09 Apr 2020.12:48:18.528288
Thu,09 Apr 2020.12:48:18.531066 FOUND PROFILE: Master_128_24MHz
Thu,09 Apr 2020.12:48:18.532808
Thu,09 Apr 2020.12:48:18.532959 FOUND PROFILE: Oric
Thu,09 Apr 2020.12:48:18.533018
Thu,09 Apr 2020.12:48:18.534582 FOUND PROFILE: QL
Thu,09 Apr 2020.12:48:18.536102
Thu,09 Apr 2020.12:48:18.536967 FOUND PROFILE: Station129
Thu,09 Apr 2020.12:48:18.537061
Thu,09 Apr 2020.12:48:18.539182 FOUND PROFILE: Teletext
Thu,09 Apr 2020.12:48:18.539323
Thu,09 Apr 2020.12:48:18.541019 FOUND PROFILE: ZX80
Thu,09 Apr 2020.12:48:18.541138
Thu,09 Apr 2020.12:48:18.544495 Loading file /profile_3BIT_RGB.txt
Thu,09 Apr 2020.12:48:18.544650
Thu,09 Apr 2020.12:48:18.549073 Setting profile to 13
Thu,09 Apr 2020.12:48:18.549227
Thu,09 Apr 2020.12:48:18.558171 Loading file: /Saved_Profiles/3BIT_RGB/Station129.txt
Thu,09 Apr 2020.12:48:18.558444
Thu,09 Apr 2020.12:48:18.563524 Setting subprofile to 0
Thu,09 Apr 2020.12:48:18.563646
Thu,09 Apr 2020.12:48:18.565446 Profile = Station129
Thu,09 Apr 2020.12:48:18.565604
Thu,09 Apr 2020.12:48:18.574351 Analyze Csync: polarity unchanged (non-inverted)
Thu,09 Apr 2020.12:48:18.574534
Thu,09 Apr 2020.12:48:18.646785 Detected polarity state at startup = Comp (Separate H & V CPLD)
Thu,09 Apr 2020.12:48:18.646939
Thu,09 Apr 2020.12:48:18.652546 Keycount = 0
Thu,09 Apr 2020.12:48:18.652654
Thu,09 Apr 2020.12:48:18.657200 -----------------------LOOP------------------------
Thu,09 Apr 2020.12:48:18.657284
Thu,09 Apr 2020.12:48:18.661632 Analyze Csync: polarity unchanged (non-inverted)
Thu,09 Apr 2020.12:48:18.661786
Thu,09 Apr 2020.12:48:18.666603 Detected polarity state = 4, Comp (Separate H & V CPLD)
Thu,09 Apr 2020.12:48:18.666686
Thu,09 Apr 2020.12:48:18.674576         clkinfo.clock = 12000000 Hz
Thu,09 Apr 2020.12:48:18.674722
Thu,09 Apr 2020.12:48:18.677147      clkinfo.line_len = 768
Thu,09 Apr 2020.12:48:18.677314
Thu,09 Apr 2020.12:48:18.680113     clkinfo.clock_ppm = 5000 ppm
Thu,09 Apr 2020.12:48:18.680243
Thu,09 Apr 2020.12:48:18.702227     Nominal 100 lines = 6400000 ns
Thu,09 Apr 2020.12:48:18.702369
Thu,09 Apr 2020.12:48:18.705370      Actual 100 lines = 6405213 ns
Thu,09 Apr 2020.12:48:18.705480
Thu,09 Apr 2020.12:48:18.708286           Clock error = 814 PPM
Thu,09 Apr 2020.12:48:18.708483
Thu,09 Apr 2020.12:48:18.711554  Error adjusted clock = 11990233 Hz
Thu,09 Apr 2020.12:48:18.711784
Thu,09 Apr 2020.12:48:18.716811  Target PLL frequency = 2302124832 Hz, prediv = 1, PER = 4
Thu,09 Apr 2020.12:48:18.717011
Thu,09 Apr 2020.12:48:18.720237  Actual PLL frequency = 2302124832 Hz
Thu,09 Apr 2020.12:48:18.720379
Thu,09 Apr 2020.12:48:18.722700         GPCLK Divisor = 6
Thu,09 Apr 2020.12:48:18.722938
Thu,09 Apr 2020.12:48:18.794949       Lines per frame = 625, (625.002)
Thu,09 Apr 2020.12:48:18.795104
Thu,09 Apr 2020.12:48:18.800902 Actual frame time = 40032773 ns (interlaced), line time = 64052 ns
Thu,09 Apr 2020.12:48:18.800995
Thu,09 Apr 2020.12:48:18.806530 Window: H = 63732 to 64372, V = 19916305 to 20116467, S = Comp
Thu,09 Apr 2020.12:48:18.806644
Thu,09 Apr 2020.12:48:18.833730 Width or Height differ from last FB: Setting dummy 64x64 framebuffer
Thu,09 Apr 2020.12:48:18.833938
Thu,09 Apr 2020.12:48:18.836240 Overscan L=0, R=0, T=0, B=0
Thu,09 Apr 2020.12:48:18.836362
Thu,09 Apr 2020.12:48:18.867902 Initialised Framebuffer
Thu,09 Apr 2020.12:48:18.868088
Thu,09 Apr 2020.12:48:18.870991 Size: 576x576 (requested 576x576)
Thu,09 Apr 2020.12:48:18.871211
Thu,09 Apr 2020.12:48:18.872591 Pitch: 288 bytes
Thu,09 Apr 2020.12:48:18.872814
Thu,09 Apr 2020.12:48:18.875368 Framebuffer address: DE000000
Thu,09 Apr 2020.12:48:18.875852
Thu,09 Apr 2020.12:48:18.907956 RAM benchmark: Main memory = 801203 ns, Screen memory = 26364557 ns
Thu,09 Apr 2020.12:48:18.908418
Here's the profile:
sampling7=6,6,6,6,6,6,6,0,8,1,0,0
geometry7=156,26,480,256,576,288,3,4,1,4,12000000,768,5000,312,4,0,1
sampling=4,4,4,4,4,4,4,0,6,5,0,0
geometry=176,29,640,256,768,288,1,2,1,8,16000000,1024,5000,312,4,0,0
auto_switch=2
palette_control=1
screencap_size=0
Post by BeebMaster »
Ahhh...I just tried a completely different card, a 128MB (yes, MB!) one and it's the same, no picture until reset. The Kingston one is a class 4 and I think the 128MB one even predates that system, so it probably is something to do with older or slower cards.
IanB
Post by IanB »
BeebMaster wrote:
Thu Apr 09, 2020 1:08 pm
I think I manage to reproduce the problem, it looks like the internal HDMI registers produce an invalid size of 720x240 when HDMI is not connected or fully initialised.
I've added some code to reboot under such circumstances and that fixes it for me, can you try it:
kernelrpi.zip
(117.83 KiB) Downloaded 31 times
Yes, that fixes it! It does a reboot then the picture appears.
Is it a "slow" card causing it then?
IanB
Post by IanB »
BeebMaster wrote:
Thu Apr 09, 2020 3:47 pm
I assume it must be, the Pi is behaving like the HDMI lead is not connected on the first bootup. HDMI setup is controlled by the Pi firmware so there isn't much that can be done about it other than reboot to work around the problem.
wjnuk
Post by wjnuk »
Firstly may I add my appreciation and thanks to all the effort that has clearly gone into the design of this converter. I have built the 3 bit version and have an issue that I just can't seem to rectify. When first powered on the screen comes alive with the Blank CPLD detected message however the cursor to select the 3 bit firmware version is jumping around up and down. I have checked the CPLD is recognized correctly in Xilinx iMpact and I have also performed the wiring mod to carry out the firmware upload through the Pi. The pull down resistors are all in place and the switches have been checked to function correctly as well. I would be very grateful to anybody who could offer some assistance or advice.
Post by hoglet »
wjnuk wrote:
Mon Apr 20, 2020 2:06 pm
This suggests that one of the GPIOs used for the switches is stuck low, or that the GPIO on the Pi is damaged.
The resistors associated with the switches are pull ups to 3.3V, not pull downs. Check the voltage on pins 35, 36 and 37 of the GPIO connector (these correspond to SW3, SW1 and SW2). It should be ~3.3V, dropping to 0v when the switch is pressed.
If you have already tested this, then the most likely problem is with the Pi itself.
I managed to damage a GPIO pin on a Pi by seperating the Pi from the hat whilst both were still connected up. The Beeb was powered off, and the TV was in standby, but still it broke (and it was one of the GPIOs uses for the switches, resulting in the same symptoms you seem to have).
I now *always* make sure I unplug the HDMI cable first. My point here is just that the GPIO pins on the Pi can be quite fragile.
Do you have a spare Pi you could try?
aotta
Post by aotta »
I had same issue too, but in my case was a bad soldering of CPLD pins 37, 38 or 39 that caused the switches crazily working.
wjnuk
Post by wjnuk »
Many thanks for the quick replies,
I have tried a different pi with the same result. My bad on the pull down remark. I'm was recalling from memory as I am at work and the unit is at home. I will try the other suggestions when I can and report back. Once again thank you for the advice.
IanB
Post by IanB »
As others have said, the likely cause is shorts or bad connections around the Pi header pins 35,36,37 or the CPLD pins 38,39,40 or bad connections on the pullup resistors R1,R2,R3. One other possibility is a damaged CPLD (caused by CMOS latchup on one of the above pins) as I had one like that once.
aotta
Post by aotta »
IanB wrote:
Mon Apr 20, 2020 3:16 pm
.... as I had one like that once.
Only one? you're a pro! i damaged dozens of CPLDs while soldering and testing my RGBtoHD... now i've got two 3bit and two 6bit working ones, but i also ordered some analog boards "smd soldering service" from a chinese supplier: those little ICs are too difficult for me!
wjnuk
Post by wjnuk »
So gpio pins 35 and 37 are 1.6v pin 36 is 3.3v Have checked again pins on cpld all looking good. All drop to 0v when buttons pushed.
Post by hoglet »
wjnuk wrote:
Mon Apr 20, 2020 7:27 pm
1.6v is an ambiguous level, so something is wrong there.
What value resistors have you used for the pullups? Might be worth checking them with a meter.
wjnuk
Post by wjnuk »
Resistor values are correct both visually identified and with a multimeter. I removed them and still have 1.6v on the corresponding gpio pins. Guess I'm going to have to look into this deeper...... Thanks for everybody's help this far!
IanB
Post by IanB »
wjnuk wrote:
Mon Apr 20, 2020 8:45 pm
Can you post a hires closeup photo of the board?
wjnuk
Post by wjnuk »
IanB
Post by IanB »
wjnuk wrote:
Mon Apr 20, 2020 9:38 pm
The soldering on pins 25 and 29 of the GPIO header looks a bit suspect but I don't think that could cause your problem. Also the CPLD pins look a little misaligned with the PCB especially along the bottom so you might want to check for shorts between adjacent CPLD pins.
You could try isolating pins 39 and 40 of the CPLD (follow the tracks from R2 and R3 to those pins). The switches don't actually need to be connected to the CPLD as that was only used in early prototype CPLD designs so you could either lift up those two legs with a pin or needle and soldering iron or you could just cut the tracks to them adjacent to the pins. This would eliminate a defective or incorrectly programmed CPLD as the source of the problem.
aotta
Post by aotta »
I discovered that Olivetti Prodest PC1 has a standard CGA video port, so i tested RGBtoHD 6bit with it, and working with some adjustement from standard CGA.
That's the profile i used:
Olivetti Prodest-PC1.txt
(122 Bytes) Downloaded 32 times
Edit: forgot to mention i used same cable made for the C-128 80 columns mode
And a couple of screenshots:
wjnuk
Post by wjnuk »
IanB wrote:
Mon Apr 20, 2020 10:21 pm
Just a quick update. I had chance this weekend to isolate pins 39 and 40. This did the trick. Cursor now behaving and CPLD programmed through pi fine. Everything now works flawlessly. Thank you so much for the suggestions. I got there in the end with a little help! The whole family are loving it.
