evening from york
philbo34
evening from york
Post by philbo34 » Fri Apr 03, 2020 8:39 pm
hi im phil from york
just been given an a3000 , as usual cant stand having anything that doesnt appear to work .
so i appologise now for stupid questions.
i have no acorn experience at all was all spekkies and st's
so go gently
phil
Re: evening from york
Post by tricky » Fri Apr 03, 2020 8:46 pm
Welcome, we have quite varied interests here.
philbo34
Post by philbo34 » Fri Apr 03, 2020 8:50 pm
1 stupid question as i have brought it in to work to clean up, inspect
after checking the battery ,using the mono video connector should i get picture on an lcd tv.
it looks like its ouputting something to my tv cant seem to lock onto it fully.
my scart lead arrives tomorrow , but im on nights .
cheers
Multiwizard
Post by Multiwizard » Fri Apr 03, 2020 8:55 pm
Hi Phil,
Greetings from my little Dutch Atomic Attic, Wim... :-)
trixster
Post by trixster » Fri Apr 03, 2020 9:19 pm
Hello also from York :)
philbo34
Post by philbo34 » Fri Apr 03, 2020 9:37 pm
small world
Post by davidb » Fri Apr 03, 2020 11:21 pm
Welcome! :D
Post by daveejhitchins » Sat Apr 04, 2020 8:25 am
Welcome to the Forum, phil . . . Enjoy . . .
Good luck with your A3000.
Diminished
Post by Diminished » Sat Apr 04, 2020 8:53 am
Hello!
This is the correct attitude!
Post by flaxcottage » Sat Apr 04, 2020 11:19 am
Welcome, Phil. :D
The mono output from the A3000 should work via the video (yellow) RCA input on a modern TV. It should work OK, not like an analogue TV signal.
First thing to do is remove the battery and clean any mess and check if any circuit tracks have corroded away.
Next you could try to do a Power-On-Delete boot up, which will reset all the saved CMOS settings and use default values (definitely needed if the battery is missing). If the keyboard connectors are corroded though you'll not be able to do that until they are fixed. :?
After that it could be a long haul. There are lots of threads on here about resurrecting A3000s. Good luck!
philbo34
Post by philbo34 » Sat Apr 04, 2020 7:15 pm
cheers for advice
will try lead tomorrow after finishing nights.
managed to open it up
and with my limited knowhow it appears to have an arm 3 board,4 meg ran and and ide card with drive in.
battery has been replaced with a single aa battery holder but no diode ( so i guess it need a rechargable battery)
roobarb!
Post by roobarb! » Sun Apr 12, 2020 2:34 am
Nice find! :)
Always loved the A3000, good luck with it.
BBC Model B - 32K, Issue 4, IFEL RAM/ROM, Speech System, Turbo MMC
A3010 - Unknown condition, hiding in the loft!
Risc PC - Fine last time I saw it!
jonnyboy
Post by jonnyboy » Tue Apr 21, 2020 11:49 pm
Hello and welcome, I'm new here myself.
