New Electron AP5 - 2nd Batch
Post by daveejhitchins » Thu Mar 26, 2020 1:43 pm
I'm getting ready for a 2nd batch of the redesigned AP5.
So far, just two changes:
(1) Added a power connector for an optional BeebSCSI
(2) Moved the pull-down resistor from data line 0 on the 1MHz connector to data 0 on the Tube connector.
If anyone has any other changes that 'could' be added quickly (?) please post here.
Thanks - Dave H :D
mr-macrisc
Re: New Electron AP5 - 2nd Batch
Post by mr-macrisc » Thu Mar 26, 2020 10:29 pm
Looking forward to getting one :)
0xC0DE
Post by 0xC0DE » Fri Mar 27, 2020 6:35 am
Same here. Count me in please
0xC0DE
:arrow: Follow me on Twitter
:arrow: Visit my YouTube channel featuring my demos for Acorn Electron and BBC Micro
rmbrowngr
Post by rmbrowngr » Fri Mar 27, 2020 7:29 am
Jumper to disable ROM 13? To save pulling out the ROM chip.
More convient location for the power connector used for the BeebSCSI.
Richard B
Post by daveejhitchins » Fri Mar 27, 2020 7:38 am
Richard - good call on the ROM13 - I’ll see what can be done.
Currently I have the 5V connector on the back. So would moving it to the front - is that what you’re after?
rmbrowngr
Post by rmbrowngr » Fri Mar 27, 2020 7:44 am
Yes, moving it to the front.
Richard B
Post by daveejhitchins » Fri Mar 27, 2020 7:46 am
I'll work on that . . .
dixiestoat
Post by dixiestoat » Fri Mar 27, 2020 9:54 am
You can't improve on a Masterpiece.... :D
Post by daveejhitchins » Fri Mar 27, 2020 11:58 am
Well . . . It look as if you can :D Connector moved to the top of the PCB and we have a spare jumper (J3) that can be used to disable ROM 13.
Post by daveejhitchins » Fri Mar 27, 2020 1:15 pm
Here's an image of the changes. Note: A reprogram of the CPLD will add the ROM 13 inhibit, for those that want it.
Post by daveejhitchins » Fri Mar 27, 2020 3:56 pm
Well . . . That didn't take long! An updated .jed file is available here with thanks to Dave (Hoglet) for such a speedy change =D>
If you are going to reprogram you AP5 CPLD than you may need to fit a 2 pin header (J3) and a 10K resistor (R12). This will then give you a way to disable ROM 13 by fitting a jumper to J3.
Post by daveejhitchins » Wed Oct 28, 2020 5:33 pm
5 x PCBs arriving this Friday :D
Dave H.
rharper
Post by rharper » Thu Oct 29, 2020 12:06 pm
Hi Dave,
Is it possible to modify the first AP5 so that it has a 5v output?
Ray
Raycomp
Post by daveejhitchins » Thu Oct 29, 2020 2:38 pm
Hi Dave,
Ray
Yes . . . I'll see if I can get you a photo.
Dave H.
Post by daveejhitchins » Thu Oct 29, 2020 3:26 pm
Aaaaaaaaaaaaaaarrrrrrrrr!
What idiot at JLCPCB thought this was correct?
I'm just about to have a cup of tea and a biscuit so I have chance to calm down . . .
I've had thousands of PCBs made with exactly the same DRAWING details, even from JLBPCB, and they've not used the Dimensional DRAWING layer as the outline and then used that drawing to put a slot in the PCB :twisted: :twisted: :twisted: :twisted: :twisted: :twisted: :twisted:
98, 99,100 . . . and breath . . .
Dave H :twisted:
If anyone wants one of these boards (?) the hole could probably be filled with silver loaded epoxy to form the +'ve connection. Let me know - FOC - I'll even provide P&P . . .
rharper
Post by rharper » Fri Oct 30, 2020 12:39 pm
Silver and copper powder appears to be available for a few pounds - not sure which would be best, probably doesn't matter.
I'm happy to try one rather than them go to waste.
Will pay postage.
Ray
Raycomp
