Mainly well done to ctr.
But that's exactly what ctr's program does and that's why it's so brilliant: it saves a picture with flashing colours and then his BASIC program $.ANI animates it!pixelblip wrote: ↑Mon Mar 16, 2020 7:40 pmI did see a problem in this. If you turn these gifs into BBC pics how you gonna know what is colour flashing and what isn't? You could save the frames of course and play 8 back in sequence but it's not the same as saving a picture with the flashing colours and animating it.
For example here's one of your animated GIFs converted back to flashing-colour MODE2 BBC format with img2beeb.exe and then animated using $.ANI. Press the zero key to select the pic:
EDIT: Admittedly the animation there looks a little bit jerky or cyclic for some reason..?
