Prince of Persia
sorvad
Re: Prince of Persia
Post by sorvad » Sat Nov 24, 2018 1:17 pm
Wow, little late to the congratulations but well... congratulations, looks awesome :)
andrewvideo
Post by andrewvideo » Fri Jun 14, 2019 8:36 pm
I think this might mentioned before. Is any way getting Prince of Persia working off a ADFS hard drive inside a directory? I did try coping it and didnt work.
Post by danielj » Fri Jun 14, 2019 8:38 pm
It uses too much memory IIRC. ADFS won't have the space it needs.
kieranhj
Post by kieranhj » Fri Jun 14, 2019 8:56 pm
Yes, sadly ADFS uses too much of HAZEL RAM which is liberally “borrowed” without permission from the MOS. It would also require a new build because the current version uses a ‘pak’ type file with direct low-level sector access to bundle multiple game assets together to get over the DFS catalogue size limit.
We (well Tom) managed an ADFS version of SCR but sadly POP is a bit more complicated to build, with multiple overlays. I still haven’t got to the bottom of the Master Compact incompatibility bug. :?
Yrrah2
Post by Yrrah2 » Fri Jun 14, 2019 9:37 pm
Was there a VideoNuLa version?
Happy with my BBC Master
www.mybbcmaster.nl
kieranhj
Post by kieranhj » Sat Jun 15, 2019 12:16 am
No. Again it was on the list, particularly when I originally planned MODE 1 so just four colours, but after Dethmunk provided such wonderful eight colour MODE 2 graphics there didn’t seem to be much point in revisiting.
Technically the sprite engine permits three independent colours per sprite from a palette of 16 (stored as 2bpp with mask but displayed as 4bpp, same as Exile) so it would be possible to redo the entire graphics set just for NULA (Ie. choose a unique 16 colour palette.) This could result in something of similar visual quality to the PC VGA version in my estimation (albeit at lower resolution and frame rate) but would be a lot of work. The entire source is up on GitHub if anyone fancies a crack at it!
Post by danielj » Sat Jun 15, 2019 9:54 am
I have to say, for me, one of the glories of this is how it runs beautifully and looks gorgeous on stock hardware. Going the NULA route feels like it would have taken some of that away.
Post by tricky » Mon Jun 17, 2019 7:48 am
And you can still tweak the eight colours if you like without touching the game.
Yrrah2
Post by Yrrah2 » Mon Jun 17, 2019 8:00 am
No I think it's perfect like it is!
Thought I read something about it, thats why I asked.
www.mybbcmaster.nl
aschamberlain
Post by aschamberlain » Thu Mar 12, 2020 4:21 pm
Just completed this - still astounded that you got it to run on a BBC Master! I'd only played the first level before on an Atari ST (I think). It's amazing how many neat little touches there are across the 12 levels considering it's an 8 bit game. The Mode 2 graphics add a certain charm that I think is lacking in the more visually austere versions on other systems. The music over the end credits is great too. Really well done, all of you!
kieranhj
Post by kieranhj » Thu Mar 12, 2020 8:42 pm
I’m glad you enjoyed it and have managed to complete the game. Well done! It gets pretty nails hard towards the last few levels (compounded a bit by the frame rate, which will never be as smooth on an 8-bit machine compared to the 16-bit PC version).
Dethmunk definitely made a great job of the MODE 2 graphics refresh - we wanted it to be the best 8-bit version of the game (although the upcoming Atari 8-bit version based on our BBC port might just pip this due to the better palette) and possibly the best looking Beeb game ever, but that’s more subjective. :)
I must confess I haven’t really got any more BBC game ports in the pipeline, although Paradroid was always on my list. Maybe one day...
jregel
Post by jregel » Thu Mar 12, 2020 9:42 pm
Don't suppose you guys fancy the challenge of porting the Freescape engine to the Beeb (bringing Driller, Total Eclipse, Castle Master etc. over)? Always wondered how well it would compare with the Spectrum, C64 and CPC versions... =P~
aschamberlain
Post by aschamberlain » Fri Mar 13, 2020 11:23 am
There are occasional bits of slow down when there are lots of things moving on screen, but I didn't find it impacted gameplay much. I did have to resort to looking at Youtube videos a couple of times to work out how to get past certain bits!
I saw in the 32 bit section that you were working on something for the Archimedes. Would that be a game perhaps?? It's on my to do list to set up a Raspberry Pi with Risc OS and ADFFS and have a nosy through the Archimedes-era games. I skipped straight from the Beeb to a Risc PC back in the day.
Post by fwibbler » Fri Mar 13, 2020 3:36 pm
Quazatron perhaps?
https://en.wikipedia.org/wiki/Quazatron
Andrew_Waite
Post by Andrew_Waite » Fri Mar 13, 2020 4:03 pm
Just to add to Kieran's to do list of games to port to the BBC :D I enjoyed playing Starglider back in the day on the PC. There is a C64 version of the game, written for the C64's 6510 that could perhaps be ported over to the Master's 6512. The game is in 3D as well, just like Stunt Car Racer. The C64 version chugs abit, so the Beeb's much faster CPU could really make the game.
vanekp
Post by vanekp » Sun Mar 22, 2020 10:53 am
Peter.
Andrew_Waite
Post by Andrew_Waite » Wed Mar 25, 2020 11:38 am
Return to “bitshifters (new bbc master games)”
