Matrix Brandy BASIC VI for console and SDL1.2: V1.22.9 released
Soruk
Re: Matrix Brandy BASIC VI for Linux with SDL: V1.22.3 released
Post by Soruk » Sun Dec 15, 2019 1:26 pm
Richard Russell wrote:
Sun Dec 15, 2019 12:59 pm
Personally I'm not sure that is wise. SDL 1.2 is obsolete and not supported, going forward issues that arise aren't going to be fixed. I think this is already affecting Mac OS, so if you have ambitions of Matrix Brandy running on that platform you will probably have to abandon SDL 1.2.
What I meant is that you could build for SDL1.2 and separately build for SDL2, just as you can separately build for text and Tektronix now.
Soruk
Post by Soruk » Mon Dec 16, 2019 11:37 am
Soruk wrote:
Sun Dec 15, 2019 12:30 pm
In theory it should be able to, however I haven't (yet) exposed the window handle.
I think the only thing the window handle is needed for is the creation of an OpenGL context, but yes it would be necessary for you to expose it.
This is now done, extending Brandy_GetVideoDriver to return this in R5.
Soruk
Post by Soruk » Thu Jan 16, 2020 2:19 pm
Latest updates:
New command line option -swsurface -- this makes SDL use a software surface instead of a hardware surface. This MAY help in some framebuffer situations.
Also - some CLI options are now recognised for BrandyApp builds (Previously none were acted upon).
Soruk
Post by Soruk » Sat Jan 18, 2020 11:23 am
For reference, here's the Matrix Brandy character set (heavily based on RISC OS).
Normal (non-Teletext) mode, take in MODE 6:
MODE 7 (uses a 16x20 character grid):
Soruk
Post by Soruk » Mon Jan 20, 2020 5:12 pm
Latest updates:
- Fixed setjmp() failing sometimes on Win64 (known MinGW issue).
- Fixed a Teletext graphics high-bit translation error.
Post by Richard Russell » Wed Jan 22, 2020 11:50 am
If you are prepared to reveal, how did this error manifest itself? As far as I am aware, setting bit 7 should only have the effect of disabling the £#— character 'shuffle' (which can impact teletext graphics as well as text).
Soruk
Post by Soruk » Wed Jan 22, 2020 12:40 pm
That was exactly it. Text was shuffled - but graphics weren't being. It manifested itself as glitches in the Chalksoft Pirate Adventure game. In the case of Matrix Brandy, the character map layout is as they appear at 32-126, and 255. The shuffling happens when bit 7 is set, but this was glitching the graphics.
Post by Richard Russell » Thu Jan 23, 2020 12:11 pm
Ah. On the BBC Micro only the SAA5050 chip knows whether a character will be rendered as alphanumeric or as graphics, so the OS couldn't do anything different in the two cases even if it wanted to (consider the case when the characters are written right-to-left, when the control character determining the mode hasn't even been seen yet)!
Soruk
Post by Soruk » Thu Jan 23, 2020 12:19 pm
Matrix does handle this one of the reasons for the earlier change from Teletext being handled as a character stream to using a 40x25 array "frame buffer", to allow a line to be recalculated - and addressed as 1000 bytes of memory at &7C00.
Post by Richard Russell » Thu Jan 23, 2020 1:04 pm
Indeed, any MODE 7 emulator has to be independent of the order in which the characters are written (I have tested mine with reverse-order and random-order). However, it's not necessary always to process the entire 40x25 frame at once, because the potential for a change 'propagating' to subsequent characters and rows is limited.
An approximate rule is that a change to a character can impact only on the rest of the row in which it appears, unless that character is a double-height or single-height control code. If it is, it can impact the entire row in which it appears and subsequent rows. How many subsequent rows can be affected depends in turn on whether they contain any double-height control characters.
Probably, with the speed of modern CPUs, one could 'simply' re-process the entire frame every time any character changes, but when I wrote my Videotex emulator for MS-DOS that would have been an unacceptable overhead, so it updated only the minimal amount necessary. My current emulators (as used in BB4W and BBCSDL) have inherited this behaviour.
Soruk
Post by Soruk » Thu Jan 23, 2020 1:42 pm
And, that is actually what I do as well. I also track changed lines, and if a &8D character is found, I mark the next line as changed too, to ensure proper updates. The minimum size update is one complete line. Currently I don't think I'm checking for &8C - but then again, it's been a while since I touched that code :lol:
Post by Richard Russell » Thu Jan 23, 2020 2:19 pm
You probably don't need to; I've not looked at my code for a long time either. I don't currently support the 'black text' and 'black graphics' modes (which I believe Matrix Brandy does) because they're not available on a genuine BBC Micro. For the same reason neither do I offer any control over how the Hold Graphics mode behaves, which by common consent the SAA5050 gets slightly 'wrong'.
The one enhancement I'd ideally like to make to my MODE 7 emulation is support for the full Unicode character set (at least, all the characters present in the Bedstead font), to allow emulation of the various multilingual variants of the SAA5050 (e.g. Cyrillic and Hebrew) plus accented characters etc. Unfortunately it's not easy to retro-fit this capability without breaking compatibility so it will probably never happen.
Soruk
Post by Soruk » Thu Jan 23, 2020 3:44 pm
Alpha and Graphics Black are available, but not enabled by default. VDU23,18,3,<0|1>| will switch it - this VDU code is from RISC OS 5. As for Hold, Matrix Brandy deliberately mimics the SAA5050's slightly errant behaviour (as does RISC OS), and there's no toggle to make it behave "correctly".
Adding other character set support to MODE 7 isn't something that's been on my radar, as it's not something the BBC or RISC OS has ever offered. It would also somewhat complicate the built-in bitmap fonts being used.
dhg2
Post by dhg2 » Fri Feb 07, 2020 6:14 pm
Hello,
I've just noticed that one of my old programs is experiencing a problem when I run it in the most recent version of Matrix Brandy.
This is the program:
PROCinitxrand:i=0:s=0:WHILEi<1495000:s=s EOR FNxrand(i):i=i+1:ENDWHILE:i=i AND255:PRINT i: END
DEFPROCinitxrand
 rand=0
 ranb=0
 ranc=0
ENDPROC
DEF FNxrand(in)
 SWAP rand,ranb
 rand=rand<<15 OR rand>>>16
 rand=NOTrand
 rand=rand<<1 OR rand>>>31
 rand=rand EOR ranb>>>3
 rand=rand<<8 OR rand>>>23
 ranc=(ranc<<1)OR(rand AND1)
 rand=rand EOR(ranc AND256)
IF in<>0 THEN =(rand AND 2147483647) MOD in ELSE =rand
What happens is, this message appears in the terminal window:
Baditem = 0, sp = 0x345ad50, safe=0x345b018, opstop=0x345ae48
and this message appears in the Brandy window:
The interpreter has gone wrong at line 1408 in evaluate at line 14 in FNxrand
PROC/FN call trace:
 FNxrand was called from line 1
- Patrick
Regards,
- Patrick
Soruk
Post by Soruk » Fri Feb 07, 2020 7:24 pm
Hello,
I'll look at this from middle of next week, as I'm going away for a long weekend. Just FYI :)
Do you know which previous version(s) it worked on?
dhg2
Post by dhg2 » Fri Feb 07, 2020 8:14 pm
Hello,
It seems like 1.22.0 is the latest version that I have that it worked on. Actually, that also happens to be the second latest version of Matrix Brandy that I have a binary for (with the latest being the current github version that I compiled just today). I have a number of versions earlier than that ranging from August 2019 to early/mid 2018 and it seems to work on all of those too.
By the way I hope you'll have a good weekend :)
- Patrick
Regards,
- Patrick
Soruk
Post by Soruk » Wed Feb 12, 2020 9:59 am
Hello,
- Patrick
There we go, that should be sorted. Couple of issues, one was an incorrect stack pull (which then breaks the stack alignment) so that's fixed along with some new verification added to the stack pull code. The other was shifts were made 64-bit wide, this has been partially reversed so default behaviour is shifts now are 32-bit but 64-bit shifts can be enabled with SYS "Brandy_BitShift64",1
Post by Richard Russell » Wed Feb 12, 2020 3:43 pm
Does that affect all shifts? If so it would make Matrix Brandy's behaviour different from my BASICs, in which the signed right-shift operator (>>) is not affected by the 32-bit/64-bit switch, because it doesn't need to be to guarantee compatibility with legacy programs.
Soruk
Post by Soruk » Wed Feb 12, 2020 3:48 pm
Right now yes, but if that is erroneous behaviour then I can put that one back to the way it was.
Post by Richard Russell » Wed Feb 12, 2020 4:49 pm
My argument, FWIW, is that's it's useful to be able to perform 64-bit shifts even when in 32-bit mode. This is particularly the case in library functions, when you may not want to switch mode because it may break the program calling the library (a workaround would be to test the current mode on entry, by performing an 'experimental' shift, and then restore it on exit, but that's messy).
The four shift operators in BBC BASIC for Windows and BBC BASIC for SDL 2.0 behave as follows:
<<  32-bit left shift in 32-bit mode, 64-bit left shift in 64-bit mode
<<< 64-bit left shift always
>>  64-bit signed right shift always
>>> 32-bit unsigned right-shift in 32-bit mode, 64-bit unsigned right-shift in 64-bit mode
Soruk
Post by Soruk » Thu Feb 13, 2020 11:12 am
Matrix brandy is following the ARM BBC BASIC shifts as shown at http://www.riscos.com/support/developer ... bases.html - so on reflection I will keep my 32-bit/64-bit switches as they are - in 32-bit mode it'll always return something that can be shoved into a 32-bit integer variable even if the input was a float.
Post by Richard Russell » Thu Feb 13, 2020 12:07 pm
Matrix brandy is following the ARM BBC BASIC shifts... in 32-bit mode it'll always return something that can be shoved into a 32-bit integer variable even if the input was a float.
If your objective is maximum compatibility with ARM BASIC I don't think you've achieved it. If you try running this code (in the default 32-bit mode):
      a% = (2.0 ^ 33) >> 3
it will report 'Number too big' in ARM BASIC, it will set a% to zero in Matrix Brandy, and it will set a% to &40000000 in my BASICs. I would argue that Matrix Brandy's result is the least 'useful'.
My approach has been that compatibility with ARM BASIC cannot extend to reporting errors in exactly the same circumstances, since that would mean you can never extend the language at all! So whilst it's true that my right-shift operator (>>) may return a valid non-zero value when ARM BASIC would report an error, it doesn't concern me, especially when being able to do 64-bit shifts in 32-bit mode has a practical value.
Soruk
Post by Soruk » Thu Feb 13, 2020 12:37 pm
My approach has been that compatibility with ARM BASIC cannot extend to reporting errors in exactly the same circumstances, since that would mean you can never extend the language at all! So whilst it's true that my right-shift operator (>>) may return a valid value when ARM BASIC would report an error, it doesn't concern me, especially when being able to do 64-bit shifts in 32-bit mode has a practical value.
The reason mine was giving zero is in 32-bit mode, the operands are all fitted into 32-bit registers before being operated upon, so (2.0 ^ 33) AND &FFFFFFFF is zero. But I see where you're coming from. Acorn's is saying (2.0 ^ 33) is too big for a 32-bit register - and so the decision I need to make is which way do I go? Out of range (as per Acorn), clamp the inputs to 32 bits (Matrix currently), or calculate at 64-bit width and clamp the output?
Edit: I've decided to go with the third option. In 32-bit mode with some quick tests it gives the same answers as ARM BBC BASIC and BBCSDL, and in the example above it follows BBCSDL.
Soruk
Matrix Brandy BASIC VI for Linux with SDL: V1.22.4 released
Post by Soruk » Tue Mar 10, 2020 12:01 pm
I've just put together a release of version 1.22.4 of Matrix Brandy BASIC. Changes include:
- Enable building on Cygwin 64-bit
- Some more 64-bit fixes
- Bit shifts now 32-bit by default (as per old behaviour and BASIC VI), switchable to 64-bit with SYS "Brandy_BitShift64",1
- Initial steps to allow SYS to call host library functions. Enabled for Linux and Windows (thank you Richard Russell for the code snippet!)
- SDL surface handle now available from Brandy_GetVideoDriver in R5.
- Raise function now handles invalid values gracefully. Range is slightly more permissive than BASIC I-V, but closely matches BASIC VI.
- Add option to use SW surface on command line, and allow brandy-apps to accept some command line options.
- Fix a setjmp crash in Win64.
- Correct a substitution error in MODE 7 high-bit graphics.
- Fix an incorrect stack pull, and add verification to the stack pull code.
Additionally, for the first time a 64-bit Windows release build is available on the website.
Nerdilicious!
Re: Matrix Brandy BASIC VI for Linux with SDL: V1.22.4 released
Post by Nerdilicious! » Sat Mar 14, 2020 2:09 am
Are there any pointers/guides to building on macOS? I’ve tried for half of today and keep getting nowhere. Building on the Raspberry Pi on the other hand is fine with debug information, but ‘make nodebug’ fails with the compiler complaining it cannot find ’SDL.h’, even though compiling with debug info is fine. I’ll admit I don’t have much experience compiling from source, so any help is appreciated!
Soruk
Post by Soruk » Sat Mar 14, 2020 9:53 am
Sorry, no. I don't have a Mac, and any makefile for mac was made long before I picked up this project. Are you using the main top-level makefile (the same one you used for the RPi)? If so, the default build is actually not a debug build (it doesn't have -g or -DDEBUG as part of the build options).
scruss
Post by scruss » Sat Mar 14, 2020 7:51 pm
… Building on the Raspberry Pi on the other hand is fine with debug information, but ‘make nodebug’ fails with the compiler complaining it cannot find ’SDL.h’, even though compiling with debug info is fine. I’ll admit I don’t have much experience compiling from source, so any help is appreciated!
You'll need the SDL 1.2 development library to build it:
sudo apt install libsdl1.2-dev
then the build is pretty much routine:
git clone https://github.com/stardot/MatrixBrandy.git
mkdir -p ~/bin
cd MatrixBrandy/
make -j4
mv brandy ~/bin
make clean
make -j4  -f makefile.text
mv sbrandy tbrandy ~/bin
This puts the brandy executable, along with its textual equivalents tbrandy and sbrandy, in your $HOME/bin folder. $HOME/bin is automatically part of your search path the next time you log in or open a new terminal, so it's a safe place to put the programs.
The above is modified from a process I have running automatically on many Raspberry Pis every morning and it should just work …
Macs I can't help with, sorry.
Nerdilicious!
Post by Nerdilicious! » Sun Mar 15, 2020 5:32 pm
Yes, I used the top level makefile. For the Mac I first tried renaming all references to the SDL.h file in the source files using sed to SDL/SDL.h and when that didn’t work, I deleted, re-extracted and set the CMAKE variable to point at the SDL folder (I actually tried both the Apple framework and the version installed by Homebrew). But no joy. But cheers for replying!
Nerdilicious!
Post by Nerdilicious! » Sun Mar 15, 2020 5:35 pm
mkdir -p ~/bin
cd MatrixBrandy/
make -j4
mv brandy ~/bin
make clean
Many thanks! I will try this later as my Pi is foing double duty as a media centre and my wife is currently rewatching Cabaret…
Post by Richard Russell » Sun Mar 15, 2020 5:54 pm
I found that buying a Mac was unavoidable, in order to build BBC BASIC for SDL 2.0 for Mac OS (I also use it to build the iOS edition). But it wasn't too expensive because I got a Mac Mini and share my keyboard/mouse/monitor using a KVM switch.
I also find the Mac to be a valuable platform for testing 64-bit compatibility because, unlike Windows or Linux, addresses (pointers) really are always outside the 32-bit range. When I first ran BBCSDL on the Mac I was surprised by how many 64-bit compatibility issues I'd missed.
