The C64
The C64
Post by Lardo Boffin » Thu Dec 26, 2019 12:23 pm
Leew wrote:
Thu Dec 26, 2019 9:20 am
Lardo Boffin wrote:
Wed Dec 25, 2019 6:53 pm
Boydie wrote:
Wed Dec 25, 2019 5:06 pm
Snap. This is a GOOD year! :D
Can you post some thoughts / mini-review of The C64 please? Curious as to how good it is, especially around game / disc image compatibility. Thanks!
Seems to be a good recreation of the Commodore 64. It has 64 games built in being a mixture of C64 and Vic20 games. All the disk images I have tried work a treat and I didn't expect otherwise as it has Cloanto logos on the box so assume the emulation is based around the Amiga/C64 Forever Cloanto emulators which I have always found to be very good packages.
I have read reviews of the C64 mini saying that there are lags with input. This new full size machine doesn't seem laggy at all to me and is very responsive to joystick and keyboard input. It's got a good build quality and over all I am impressed and think it was money well spent (by my wife 😊).
Sounds like a good remake! Are the loading times reasonable?
Can you give Wasteland a go please?
Moderator note: Continuation from this thread Mark
Wasteland.zip
(502.58 KiB) Downloaded 20 times
Reason: Edited to add link to the thread where this discussion started.
Adventure Language on GitHub
Atom, issue 5
Elk
markjw
Re: The C64
Post by markjw » Thu Dec 26, 2019 8:04 pm
the 8-bit Guy has done a video on this machine - https://youtu.be/kxx2F4ffmeE - and as part of it tested the input delay which can be found at 8m40s into the video. The joystick he received had proper microswitches unlike the one supplied with the C64 mini. Also he found that it appears the case moulding is based on the VIC20 rather than the C64.
Leew
Re: The C64
Post by Leew » Thu Dec 26, 2019 8:32 pm
I see what you are getting at now. Loading times are not an issue. You mentioned SD2IEC, which I believe uses the disk drive serial port on an original C64 so is effectively as slow as an original 1541 disk drive. This new machine is an emulated C64 running on an ARM processor so the D64 files load as fast as the USB port throughput speed which means for a tiny file like a D64 disk image, almost instantaneously.
That said a lot of the disk image files that I have have been compacted, so after each file loads from the disk you still have to wait for the C64 to uncompress the files.
I haven't figured out how to manage multiple disk images / disk changing yet. When I work it out I will have a look at Wasteland and maybe Last Ninja.
Hope this helps.
Lee W
Proud owner of many Electrons, some Beebs, a couple of Archies, some Commodore 64s, Amigas, Atari STs and an Atari Falcon 030
Lemmings are for life, not just the 90's... https://www.lemmingsworld.me
Re: The C64
Post by Lardo Boffin » Thu Dec 26, 2019 9:22 pm
Thanks Lee.
Multiple discs are always fun. I think Pool of Radiance has 6 or 8 sides!
Yes the SD2IEC uses the serial port and is glacially slow (although an Epyx Fastloader, or similar, cart helps immensely). The Pi1541 does the same. And is as slow. Not sure if a fast loader cart helps with that - might need the full JiffyDOS experience but not got that far yet.
However I can finally run Wasteland with the Pi. :D
I have a .lst (a file containing a list of files) set up and on the Pi and SD2IEC you select that - if this is a convention then maybe The 64 does the same. There should be a .lst file in the Wasteland zip if you get chance to try.
Atom, issue 5
Elk
Re: The C64
Post by Kazzie » Fri Dec 27, 2019 7:22 am
For a brief moment I was thinking "that's one heck of an input delay!" #-o
RiscPC 600 under repair
markjw
Re: The C64
Post by markjw » Fri Dec 27, 2019 7:18 pm
ouch! the price gouging has started for these - they were £109.99 last week, but the only one on Amazon UK today is £227.99 :(
Out of stock everywhere else that is listed on 'The C64' website
Re: The C64
Post by roland » Fri Dec 27, 2019 7:43 pm
I have looked at the video of the 8bit guy. Especially taking it apart .... what a surprise what is in there (or better: what is not in there) :lol:
This way we could also make cheap Atoms (after all, we already have the FPGA stuff for the Atom), but then we will run into my/our problem: where to get an affordable keyboard and housing from?
Boydie
Re: The C64
Post by Boydie » Sat Dec 28, 2019 8:38 am
For anyone who wants one, Menkind has started selling them as an online exclusive, and has them in stock for the normal price.
Leew
Re: The C64
Post by Leew » Sat Dec 28, 2019 9:24 am
Argos are taking orders for the C64 Switched Joystick if you need another stick although it says lead times are 11 days as of today, but they don't appear to have the actual machine as an item for sale.
There are a few reviews out now and Wi-Fi Sheep has done a Q&A video on it, links below...
The 8-Bit Guy
https://www.youtube.com/watch?v=kxx2F4ffmeE - Review
Wi-Fi Sheep
https://www.youtube.com/watch?v=QHUy-89ca88 - Review
https://www.youtube.com/watch?v=pGDfinnfgTQ&t=547s - Q&A
Lee W
Leew
Re: The C64
Post by Leew » Sat Dec 28, 2019 1:13 pm
OK, I have given Wasteland a go and it turns out swapping disks on The C64 is really easy.
However getting Wasteland to actually load was a little tricky as it kept hanging on a black screen.
I eventually figured out that you can add switches to the d64 disk image files by renaming them on the USB drive, eg adding '_M6ADCD' to the file name means 'M6' = Regular C64 configuration, 'AD' = Accurate Disk emulation, and 'CD' = Continuation disk in set
The switch that got Wasteland to load was the 'AD' one and I have found that a couple more games need this too and I do occasionaly get a disk IO error, but I think that this is my cheapo dodgey USB stick.
I have screen captured the loading of Wasteland so you can compare it to SD2IEC on your real C64 for comparative loading times, oh and I left the disk indicator turned on, so you will see a floppy disk image in the top right corner when the disk is being accessed.
https://youtu.be/Pb-0GNDrLvY
Lee
Lee W
Re: The C64
Post by Lardo Boffin » Sat Dec 28, 2019 4:28 pm
Thanks Lee!
Looking at it, the loading speeds look very similar to my C64 with Pi1541. I assume the advanced setting pretty accurately mimics the original hardware, including load times.
The display is quite a lot better than the composite out of my breadbin though. Sadly I don’t have an S-video TV to use.
Atom, issue 5
Elk
scruss
Re: The C64
Post by scruss » Sat Dec 28, 2019 5:03 pm
Disk compatibility should be excellent, 'cos they used VICE but didn't credit the developers. I'm sure the choice of a custom A20 board seemed like a good idea at the time - but again, the developers benefited greatly from open-source hardware like the A20-OLinuXino boards.
Re: The C64
Post by 1024MAK » Sat Dec 28, 2019 5:33 pm
After the Vega+ debacle, I’m very wary of these ‘projects’.
The fact that they are using GPL software but not crediting the original developers and not complying fully with the GPL means I won’t be buying one.
I already have VICE running on my Linux PC :D =D>
zeem
Re: The C64
Post by zeem » Wed Jan 01, 2020 2:49 pm
Reading down the comments reveals that there were two versions of the C64 breadbin case - the original one with the same dimensions as the VIC-20, and a later one which was slimmed down. The 64 is based on the earlier one.
Leew
Re: The C64
Post by Leew » Wed Jan 01, 2020 3:41 pm
8-bit Show and Tell has done a good video on The C64. It is quite long (about 45 minutes) and he compares The C64 and 3 different original Commodore 64s from the 80s and they all had different case sizes! He also says he developed some of the software on The C64. Link below
https://youtu.be/z2GACGEucTI
Lee W
anightin
Re: The C64
Post by anightin » Thu Jan 02, 2020 9:34 am
Got mine working over the Christmas break on my games system.
I had to use an HDMI upscaler to convert the C64 HDMI output into a format my ASUS ROG SWIFT Curved PG348Q, 34 Inch UWQHD (3440 x 1440) Gaming Monitor could read.
After that little hiccup, all was well. The C64 now sits above my gaming keyboard :D
I loaded Commando and a few other titles onto a USB stick, and that worked fine too.
