Ribbon cable for 5.25" dual drive
wanted ads for physical hardware, software + literature
Forum rules
You're welcome to trade Acorn-related stuff with other forum members here - the rule of thumb to follow when trading, is that items or services offered should be of interest to our Acorn community. Do NOT use multiple accounts - please trade with your regular (and only) forum account. If you're giving items away, please make it clear if you would be unhappy with the recipient selling on some or all of the items. Similarly, please ensure that the giver is comfortable with you re-selling items you have accepted as a gift. We cannot be held responsible for what happens in these trading forums or for deals done via PM. This must be done at your own risk. If you aren't comfortable with this - make the trade via an alternative site which can apply safeguards of their own. Be sensible - if someone approaches you to trade via PM who is not posting in the public forums, this may be a sign that they are not entirely what they seem. Please report it to the moderators if you receive an unsolicited message from anyone suspicious, so that it can be investigated and hopefully stop anyone being taken advantage of.
DavidK
Post by DavidK » Thu Nov 07, 2019 3:30 pm
Hi All,
The ribbon cable on my Cumana CDX 800S dual drive has a break in it. If I jiggle the cable in to the right position I can get it to work, but would like to replace it with a new one.
I've had a good search on the internet and am struggling to find one that's fit for purpose. I've found one that looks as though it'll do the job, but as it's over in America the shipping costs are prohibitively expensive.
Can anyone recommend a UK seller that would be able to supply a new cable for a dual 5.25" drive?
geraldholdsworth
Re: Ribbon cable for 5.25" dual drive
Post by geraldholdsworth » Thu Nov 07, 2019 4:20 pm
If you can get hold of a reel of cable, and the connectors, it is fairly easy to make up - I used to use a vice to crimp the connectors, BITD.
Gerald Holdsworth
Repton Resource Page
www.reptonresourcepage.co.uk
Lardo Boffin
Post by Lardo Boffin » Thu Nov 07, 2019 4:41 pm
Mark at Retroclinic may be able to help.
Atom, issue 5
Elk
USA Model B
DavidK
Post by DavidK » Thu Nov 07, 2019 4:43 pm
Good idea, I've just had a quick search on eBay and the parts seem reasonable enough..
Post by tricky » Thu Nov 07, 2019 5:14 pm
I guess it would be too short to move one of the connectors to the other side of the break. You might get lucky and be able to reuse the existing cable - I have repurposed several PC cables Luke this, but they would have been a little younger ;)
DavidK
Post by DavidK » Thu Nov 07, 2019 7:08 pm
Yeah, the break's pretty much in the middle of the cable. Looking at it, it's had a bit of a tough life, so a nice new one is in order.
I've just ordered all the components from eBay for less than a tenner, and even splashed out on a small vice from Amazon (£4.14).. if I'm lucky enough the vice will stay in one piece long enough to crimp the connectors on :D
geraldholdsworth
Post by geraldholdsworth » Thu Nov 07, 2019 8:03 pm
Nice...one other thing is to be careful when you cut the ribbon cable as sometimes you get stray wires venturing across to neighbouring wires. I used to cut them with scissors (if I recall correctly), but a good sharp knife is probably a better bet.
Oh, and before you crimp, check, check and check again that the connector is the correct orientation, etc. Once crimped, it is a faff to remove.
Gerald Holdsworth
Return to “wanted”
