- BASIC Interpreter / Run Time Engine
User-defined characters may be used even if *FONT is active (improving compatibility with BB4W).
Removed a workaround (for Linux only) which was supposed to fix a bug in SDL2, but didn't (and hopefully SDL will be fixed one day).
Fixed a couple of minor bugs in the antialiased 2D graphics extension.
- IDEs and Utilities
Modified the Cross Reference utility to make use of the updated Treeview library.
The speed with which the mouse wheel scrolls SDLIDE's editing pane is controllable by adding e.g. 'wheelspeed=3' to sdlide.ini. If you prefer Mac-style 'backwards' scrolling you can specify a negative value (listboxes are unaffected however).
The Help Topics and Tutorial menu selections in SDLIDE link to BBCSDL-specific pages at the website, allowing customisation if required.
- Libraries
Modified 'dlglib.bbc' so listboxes can be scrolled by dragging the list (as well as using the scrollbar).
Svein's Treeview library has been updated to support a vertical scroll bar.
Modified 'aagfxlib.bbc' to support dotted and dashed (straight) lines.
- Example Programs
Added 'SkyBaby.bbc' (in the examples/general folder) which is a simple Planetarium program showing positions of stars, planets etc. in the sky. Loosely based on an old BBC Micro program.
Modified 'aagfxdem.bbc' to demonstrate a dot-dashed straight line.
Modified 'lemmings.bbc' and 'tower.bbc' to protect against a potential (but unlikely) sound-effect crash.
Please remember that if you use the Android Application Generator you should download a new APK template to ensure that any updates to the run-time engine are incorporated in your own apps.
